Fed up with clients being rough on connectors and cables
  • japlytic
    • Oct 2005
    • 2086
    With a client of ours, it was the fifth time that I had noticed damage to connectors occured since someone was literally forcing a plug into its connector - they have still not learned their lesson yet despite being told that.
    This time, it was a front panel USB connector where a barcode scanner was being forced in, which then bent the USB port pins causing the BIOS to shut down the computer after 15 seconds since it detected a short on the 5V line on the USB connector which was damaged.
    Other jobs from this particular client included a POS keyboard with a damaged plug since again, it was being forced in along with the same keyboard cable plug being broken off since they were literally yanking the cable out.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Fed up with clients being rough on connectors and cables
    I agree, I see it all the time the most common is that people seem to think that hdmi cables especially the cheap ones can be bent 90d........ well they can always ends up with the whole metal bit stuck inside of the tv causing issues :L
    • CapLeaker
      Crimping CAT7 connectors high failure rates
      by CapLeaker
      I’ve had and got a few projects using quality CAT6 and CAT7 23awg solid copper, shielded, direct burial cable. Each time I use CAT7 connectors, most of them fail making good connections to the 4 wire pairs after crimping. I tied a couple of crimping tools, thinking my crimper is bad. Also used different CAT7 RJ45 connector manufacturers. Same thing. I kinda calculate 6 connectors to make one cable!
      Get this: I use CAT5 or CAT6 connectors, no problem. Very rare I have a miss crimp with those. So what gives?! ...
      11-09-2024, 04:11 PM
    • Eniaro
      Are USB C connectors standard
      by Eniaro
      I have a number of laptops with damaged USB-C connectors.
      I wonder if I can buy a few replacement connectors from Mouser to keep, as it seems like the wafer in the middle breaks easily and oftentimes causes shorts.
      I do know there are multiple connectors out there, but I'm curious to know which are most commonly used and how can I identify and purchase the correct ones.
      I purchased USB mini-B connectors in the past, only to find out that the connector was flipped (Lenovo smh).
      07-24-2023, 03:07 PM
      RJ45 Block Diagram / Schematic
      RJ45 network connectors are most commonly found at either end of an Ethernet (wired internet) connection. At first glance, they appear similar to the familiar telephone plugs and jacks which connect landlines to walls or switchboards. However, RJ45 connectors are typically slightly larger.
      The term RJ45 connector is widely used today to describe both male RJ45 plugs and female RJ45 sockets. The plugs, sometimes called modular connectors, are usually found on the end of Ethernet cables. The sockets or jacks are generally embedded in the device...
      10-31-2024, 04:18 AM
      KingWin ABT-650MM 650 Watt ATX PSU [PCB: SW8835REV:A]
      by momaka
      For today's thread, I have a KingWin ABT-650MM ATX PSU. Official web page with the PSU specs is still up and can be found here:
      http://www.rmac.kingwin.com/products.../abt_650MM.asp
      I just can't help it when I see a broken / for parts PSU on eBay that's listed for cheap and looks at least somewhat interesting. Well, OK, I won't lie – on the outside, this PSU looks anything but interesting. It's a plain gray box with colorful “spaghetti cables”.
      What mostly drew me into buying it is its 2x PCI-E power connectors...
      03-29-2022, 11:34 PM
    • corrize
      Desoldering - soldering BGA chip close plastic mini fpc connectors ?
      by corrize
      Hello, I need your advise please ? I need to remove and replace the BGA black chip with fpc connectors around. The PCB is small, from camera.
      There is no plastic component directly under, on the other face, (only fuse and oscillator I can remove if they are sensitives to heat), but there is a lot of very small smd components I don't want to desolder by mistake.
      I have :
      - hot air, and a
      ll stuff around
      - true kapton tape
      - 140 and 180 degree soldering paste
      - bismuth
      - little hot plate 250 degree max
      - the new BGA chip with probably
      05-20-2025, 01:26 AM
