la-3691p charging problem
  • rajeshkumar
    • Oct 2014
    • 44
    • india
    hii frnd in facing charging problem in these motherboard
    change charging ic check regist io not out adp id
    iref plz reply
  • Scoff
    HP Probook 470 G4 - Power and Charging Problem
    by Scoff
    Looking for some help with this one if anybody can assist please? I have an HP Probook 470 G4 Laptop which recently started to intermittently failing to turn on, with intermittent white LED light(charging LED) by the charging port when it should have been charging and showing an orange LED instead. Definitely some sort of gradual failure. Now the laptop fails to power on at all, no charging LED, no Power Button LED either - seemingly dead.
    Stripped down to the bare motherboard. The original HP battery, when disconnected from the motherboard, is reading 0.00v - possibly some sort of protection...
    07-03-2023, 09:28 AM
  • ahmarzo
    Hp laptop charging problem
    by ahmarzo
    Have hp laptop motherboard part no opp 17 diner skl/kbl 15289-2 with charging problem.the laptop shows plug in charging but percentage doen not increases.the schematic or boardview is not available.
    Charging ic is bq737 with voltages on pin no
    1&2 -19v
    34&5 -0v
    6 -2.56 v
    7- 0v
    8&9 -3.15v
    10 -0v
    11 -0.18v
    12 & 13 -13v
    14&15 -0v
    16 -6v
    17;18&19 -13v
    20 - 19v
    Voltages on battery connector are
    1&2. -13v
    3&4 -3.14 v
    5&6 -0v
    8&9 are ground...
    03-20-2025, 05:13 AM
  • roman728
    Lenovo E15 / NM-C421 Charging Problem
    by roman728
    Hello guys,
    I have a problem with charging circuit in this laptop. Unit came with no power at all (USB-C meter was cycling turning off and on). I discovered that when I unplug battery laptop works on charger only. So after few measurements I found shorted 1st dual mosfet AONY36324. Unfortunately i was not able to order exact this one, so i ordered AONY36352 which i believe is the similar one. Now the problem is, when i connect battery and charger USB-C meter is not cycling anymore, it starts charging (reading 20V@2,7A) but after few seconds it is going down to 20V@0,20A and laptop...
    02-20-2024, 03:40 AM
  • kity92
    Edifier x3 Earbuds Blue Light Problem (Charging Problem)
    by kity92
    I ordered a Bluetooth earbud one and half year ago, and right earbud broke. The light that should have been red when you put it in the charging case started to turn blue continuously(which means earbud is not charging) and after 1 week the earbud completely died. I disassembled right earbud because the warranty finished. I diagnosed the battery was dead, so I charged it with TP4056 and revived the battery.
    Right earbud is working now but I still didn't solve charging problem. I checked the charging box with a multimeter. There is 5V. I checked the headphone pins and they are working....
    01-13-2022, 01:49 PM
  • delphi_firebird
    Toshiba Qosmio X755 Charging problem
    by delphi_firebird
    Hello Guys,
    I received Toshiba Qosmio X755 that has a charging problem and I'm stuck trying to figure out the problem.
    - When battery is unplugged i works without any problem.
    - When I plug in the battery after plugging in the charger, it works correctly and the battery is charging.
    - When I plug in the charger after inserting the battery, it stops working. ( voltage dropped and consumed 8A, reaching the maximum capacity of my bench power supply for 5 seconds, and stop working after )
    Can you help me diagnose the problem? I have attached...
    10-16-2023, 03:04 AM
