I was recently given a Radeon 9550 256MB AGP card to play around with. Would it be better for use in my HTPC (for playing DVD) than the Geforce 6200 that is in there now? I'm looking for the sharpest 2D output and best video decoding acceleration, not gaming performance.
Radeon 9550 vs. Geforce 6200?
Tags: None
Re: Radeon 9550 vs. Geforce 6200?
I did recently give a Saphire Radeon 9550 256MB for a spin, but I could'nt tell the difference in 2D between it and my Geforce FX5500.
Gaming performance though improved with the 9550. Especially under CS: Source. :-)CPU: Sempron 2500+ / P4 2.8E / P4 2.6C / A64 x2 4000+ / E6420 / E8500 / i5-3470 / i7-3770
GPU: TNT2 M64 / Radeon 9000 / MX 440-SE / 7300GT / Radeon 4670 / GTS 250 / Radeon 7950 / 660 Ti / GTS 450
Main Driver: Intel i7 3770 | Asus P8H61-MX | MSI GTS 450 | 8GB of NO NAME DDR3 RAM (2x4GB) | 1TB SATA HDD (W.D. Blue) | ASUS DVD-RW | 22" HP Compaq LE2202x (1920x1080) | Seasonic S12II-620 PSU | Antec 300 | Windows 7 Ultimate with SP1 -
Well I tried the 9550 in my HTPC and I couldn't get MCE to work right, and the TV kept crashing. The drivers (Catalyst 7.12) are a real nightmare. The card worked better in an old HP system. Maybe it just doesn't like AMD boards.
Also tried the 9550 in my Athlon XP system, because I wanted to try out Need For Speed Pro Street. It kept crashing when I tried to load the game, so I ended up using a Geforce FX5900XT.Comment
With all the constant bad press received by the ATi cards, I'd think the nVidia card would be the natural choice.
I'm not a gamer at all, but I've read enough negative comments to opt for the nVidia cards no matter what.Comment
All ATI 9xxx cards do support DX9 per specification. Just make sure, you disable fas writes in BIOS or driver for any other AMD chipset then SIS.
I would suggest to check the real decoding performance and abilities for both cards.
It might be the case, that the GF6200 could be better in this respect, but i am not that sure as any Radeon 9xxx card does have a working decoding accelerator build in.Comment
I guess I was thinking of the 9250 card.
It is not true that all 9xxx cards support DirectX 9. The 9250 does not, see the specs at the ATI web site. It is listed as supporting only DirectX 8.
http://ati.amd.com/products/radeon92...200/specs.html
I was running the Media Portal media center application, and they require a Radeon >=9600. They say because of DirectX 9 support, so that is where I got my info from.http://wiki.team-mediaportal.com/Med...alRequirements
Yes your right, i stand corrected. The Dx 9 support starts with Radeon9500, the lower 9000 series are slightly improved or just renamed Radeon 8x00 chips which only do support dx8.1.
Source: http://www.hardware-mag.de/hardware.php?id=141Comment
I now agree. nVidia is better, especially if you want to use Linux. I built a few systems before I started using Linux. I put expensive ATI cards in them, 'cause they were suppose to be the best.
Even the 8xxx nVidia cards don't have full function support in the Linux driver. (This is what I heard).
I have seen developement in a Linux ATI driver since AMD took them over. They released the specs so that a driver could be developed.Last edited by Paul S; 12-24-2007, 12:12 PM.Comment
Re: Radeon 9550 vs. Geforce 6200 and driver issues...
Ya the Geforce ended up working great. I was just hoping to use the ATI in the HTPC so I could use that 6200 in another computer for games.
The 9550 was listed as being supported in Windows MCE, so I don't know what the deal is.
One thing that really, really bugs me about the Nvidia drivers, is every time I try to make a custom resolution, it says "custom mode test failed".
I need to find a way to tell Windows to keep the sync polarities at negative all the time, because that is what my projector needs.
From what I've read, I need to make an .INF file for the projector, giving all the supported timings. I have no idea how to do this though.Comment
Well, I just read somewhere that Powerstrip can generate custom monitor INF files. I'll give that a try I guess.
All I want is to be able to have the proper timings for my projector after a fresh install of Windows MCE, without fumbling with the video card drivers. If Windows changes the resolution on the fly and the sync polarity is wrong, the picture blanks out, and I have to connect a PC monitor to get it set back.Comment
AMD Radeon R9 290 / R9 380 / R9 390
The Radeon R9 290 was a high-end graphics card by AMD, launched on November 5th, 2013. Built on the 28 nm process, and based on the Hawaii graphics processor, in its Hawaii PRO variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon R9 290. The Hawaii graphics processor is a large chip with a die area of 438 mm² and 6,200 million transistors. Unlike the fully unlocked Radeon R9 290X, which uses the same GPU but has all 2816 shaders enabled, AMD has disabled some shading units on the Radeon R9 290 to reach the...-
Channel: Schematics and Boardviews
NVIDIA GeForce RTX 3080 / RTX 3090 Schematic & Board View
The GeForce RTX 3080 is an enthusiast-class graphics card by NVIDIA, launched on September 1st, 2020. Built on the 8 nm process, and based on the GA102 graphics processor, in its GA102-200-KD-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 3080. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The GA102 graphics processor is a large chip with a die area of 628...-
NVIDIA GeForce RTX 2060 / RTX 2070 Schematic & Board View
The GeForce RTX 2060 is a performance-segment graphics card by NVIDIA, launched on January 7th, 2019. Built on the 12 nm process, and based on the TU106 graphics processor, in its TU106-200A-KA-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 2060. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The TU106 graphics processor is a large chip with a die area of 445...-
NVIDIA GeForce GTX 950 / GTX 960 Schematic & Board View
The GeForce GTX 950 was a mid-range graphics card by NVIDIA, launched on August 20th, 2015. Built on the 28 nm process, and based on the GM206 graphics processor, in its GM206-250-A1 variant, the card supports DirectX 12. This ensures that all modern games will run on GeForce GTX 950. The GM206 graphics processor is an average sized chip with a die area of 228 mm² and 2,940 million transistors. Unlike the fully unlocked GeForce GTX 960, which uses the same GPU but has all 1024 shaders enabled, NVIDIA has disabled some shading...-
10-01-2024, 01:54 PM -
AMD Radeon RX Vega 56 / RX Vega 64 Schematic & Board View
The Radeon RX Vega 56 is a high-end graphics card by AMD, launched on August 14th, 2017. Built on the 14 nm process, and based on the Vega 10 graphics processor, in its Vega 10 XL variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon RX Vega 56. The Vega 10 graphics processor is a large chip with a die area of 495 mm² and 12,500 million transistors. Unlike the fully unlocked Radeon RX Vega 64, which uses the same GPU but has all 4096 shaders enabled, AMD has disabled some shading...-
10-01-2024, 01:07 PM -
- Loading...
