install ubuntu along side Win?
  • ivtec
    • Dec 2008
    • 1967
    Hi guys;i've been trying to install Ubuntu along side Win 10TP in my Lenovo ThinkCenter71; Intel (core)tm) I5 2400 CPU 3.10GHZ,
    Mem 3.8GB,Socket 1155, Video card ATI 6450, HDD Sata 500.
    i try to follow instructions bellow link,
    i wonder why in the auto partitions it doesn't show ''install along side '' as it should like in this Picture, see pic.
    http://postimg.org/image/3xjcazr07/93d96835/
    already used LVM and others but can't get a boot menu.
    linux.about.com/od/LinuxNewbieDesktopGuide/ss/The-Ultimate-Windows-7-And-Ubuntu-Linux-Dual-Boot-Guide.htm#step-heading
  • diif
    • Feb 2014
    • 6978
    • England
    Re: install ubuntu along side Win?
    You need to find instructions for Windows 8/8.1 not 7. The partition structure on 10 with a GPT partition is not like 7.
    • ivtec
      • Dec 2008
      • 1967
      Thanks diff.
      • ivtec
        • Dec 2008
        • 1967
        Originally posted by ivtec
        Thanks diff.
        Also what is the difference,between win 7 and 8/8.1,
        doesn't DVD iso works?does it have to be an bootable USB!
        • diif
          • Feb 2014
          • 6978
          • England
          You're welcome ivtec. The partition structure is different of 8/8.1, an iso is a disc image and has to be burn to a DVD before it can be used to install Windows 8/8.1.
          From experience i've had to use a Windows 8.1 PC to read another Windows 8 hard drive i'd inserted as a slave, my Windows 7 PC would recognise but not read the disc.
          • ivtec
            install Linux on Windows 10 | Install Ubuntu on Windows 10 using Virtualbox ?
            by ivtec
            Has anybody installed Linux on Windows 10 using Virtualbox? and since my old PC will have support after oct 25 and won't update to 11 , i just want to use win 10 for Music notation program and use Progdvb iptv player .
            01-17-2025, 12:54 PM
          • howardc64
            by howardc64
            Problem
            08-04-2024, 10:36 PM
          • flibidy
            Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
            by flibidy
            I have here a Magnum IA.100 which belongs to my parents.
            The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
            Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
            What Ive done........
            01-01-2025, 01:26 PM
          • japlytic
            DRIVER_PNP_WATCHDOG error re. old drivers in Windows 11 install image
            by japlytic
            In a Beelink GTR mini PC, mine has an Intel AX200NGW WLAN module.
            Tried (only with keyboard/mouse connected):
            • BIOS + database update
            • Using latest Windows 11 image built with official image creation tool
            • Previous setup version for Windows 11 installer
            • Replacing SSD without a slow block (the previous SSD had a slow block with access time > 500 mS)
            • TPM reset (worked to the point where DRIVER_PNP_WATCHDOG error message is displayed briefly after the point of stalling)
            • Disabling power to WLAN and LAN modules in BIOS (Advanced > AMD PBS > PCI Express Configuration)
            06-19-2025, 04:59 PM
          • 24gsm
            MacBook Pro A1708 install macos fail
            by 24gsm
            hi to all
            i have MacBook Pro (13-inch, 2017, Two Thunderbolt 3 ports)
            after enter to recovery and format hdd 1to .
            after try to install macos online . its frezz at loading install in boot and i waiting few hour but nothing i ty install by boot using flash disk but same issu
            can help please
            Serial Number: FVFXP0U0HV2J
            Config Code: HV2J
            Find My Mac: OFF
            04-16-2025, 03:57 AM
