How to Measure True Laptop Battery Output?
  • TractorGear
    • Mar 2015
    • 40
    We just bought a new battery for my wife's laptop. The standard, OEM battery was a 6-cell and on eBay I found a 12-cell battery that claimed 10,500 mAh (I think that's the number) for $20.00. One of those "If it sounds too good to be true..." type of moments. I confess. I was weak. I paid that $20.00 and bought that cheap battery hoping to get something for nothing.
    Anyways it showed up incredibly fast (2 days, priority mail, which I didn't ask for or pay for) and it fits perfectly. Super large it causes the laptop to slant forward now because it's almost twice as thick as the previous, factory battery.
    So far I've done 2 full, 100% charge, @ 3% discharge cycles (until the computer just switches off) and now I realize I have no objective way to measure how many hours of "life" the laptop gets, due to all the various power savings mechanisms involved (screen turning off, hard drive turning off, hibernate, standby, etc...)
    Other than manually turning everything ON and making a big deal about force-testing battery A, comparing it to battery B, etc... is there an easy way to get a good, workable idea of how much "life" each battery gives? I want to say "This battery is good for 4 hours, and this one is good for 8 hours." or something along those lines.
    Is there a downloadable, freeware utility that "tracks" power consumption and battery life? It's Win7, so a "gadget" would be ideal.
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: How to Measure True Laptop Battery Output?
    http://www.nirsoft.net/utils/battery...tion_view.html
    • domas
      News Hater
      • May 2013
      • 323
      • Denmark
      this is my favorite
      w7 gadget
      http://addgadgets.com/battery_meter/
      • serious_electron
        Strange! Acer laptop not powering on but charging the battery (orange light on when charger and battery plugged in).
        by serious_electron
        Hello Everyone!
        I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died.
        06-28-2025, 02:57 PM
        NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
        I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
        I bought this from an eBay seller but unfortunately they only had one
        I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
        I bought three of from them to also make battery packs with this output power limit in mind
        I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
        04-23-2025, 05:50 AM
      • ahmarzo
        Acer TMX314-51 laptop battery problem
        by ahmarzo
        I have acer laptop tmx314-51 with part no 6050A3020501.
        The laptop is working fine on adapter and battery is also charging and when adapter is disconnected in on state the laptop gives backup on battery and gives good backup.
        But when laptop is powered on through battery only the laptop does not power on and there is 0 voltage on battery connector.
        I have not not tried another battery as it is not available locally could this be a battery problem.have checked discharging mosfet and there is no shorting to ground on any pin of battery connector.
        The schematic is not available...
        04-11-2025, 09:14 AM
        NVDC charger configuration...
        11-05-2024, 03:28 PM
      • doboka98
        Satellite C55-A-142 Laptop boots only without battery
        by doboka98
        Hello! I am fixing a Toshiba Satellite C55-A-142 (model no PSCG8E).
        It came with an old battery. Laptop was rebooting every 5 sec with black screen, not even entering BIOS. If battery was removed it worked perfectly only on charger. I thought it's a shorted battery so I ordered a new one.
        Now with the new one it wont even reboot, but the red battery light is blinking on the laptop. Pressing the power button does nothing. Laptop still works with battery removed.
        So to summarize:
        1. there is no short
        2. Laptop starts only with battery disconnected....
        10-26-2023, 07:09 AM
