defective ati chipset?
  • BigTroll
    • Sep 2010
    • 1317
    • LAMBDA SOND
    I have a inspiron 1521 AMD dual core with Radeon Xpress 1270 graphics, I was browsing the web in chrome and all of a sudden chrome says a tab is unresponsive so i close it and keep browsing ebay about 10 seconds later it looks up and the screen goes grey and fans to high speed, now it wont even power up. goes on for a second then shuts off. I found their are alot of bad logic boards for sale on ebay and it makes me wonder if the ati chipset is defective. I tried all to revive it removed cmos battery, reseated processor tried different ram etc, nothing. i even removed the ram as I was told dells beep if you do so and nothing. I have since bought another parts machine off ebay that boots and hope this doesn't happen again.
    My Computer: AMD Ryzen 9 3900X, Asrock X370 Killer SLI/AC, 32GB G.SKILL TRIDENT Z RGB DDR4 3200, 500GB WD Black NVME and 2TB Toshiba HD,Geforce RTX 3080 FOUNDERS Edition, In-Win 303 White, EVGA SuperNova 750 G3, Windows 10 Pro
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5042
    • US
    Re: defective ati chipset?
    it might be a BGA issue. I've ran into one bad balled modern AMD chipset, and it wasn't overheated or anything (didn't produce much heat)
    did a full reflow, customer has said it still works now over a year later
    • Th3_uN1Qu3
      Believe in
      • Jul 2010
      • 6031
      • Romania
      Don't think it's a BGA issue. These old chipsets rarely failed. Some power supply went short. Or maybe even the CPU. I've had older AMD CPUs short out before.
      If the chipset BGA had bad soldering it would have still powered on afterwards, giving distorted or no video.
      A working TV? How boring!
      • BigTroll
        • Sep 2010
        • 1317
        • LAMBDA SOND
        Thanks for the advice guys. I got my parts unit 1521 today and put it back together, using a AMD Turion 64 x2 TL-60, the chipset temp gets higher then the cpu, gets up to about 69. I noticed on the logic board it has two amd chips I think one is the x1270 and the other the chipset, the chipset is a naked chip and has no heatsink where the other one shares with the cpu's heatpipe
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          • Romania
          The other chipset is the southbridge and does not require a heatsink.
          • DynaxSC
            Activation of Management Engine after exchange Z590 chipset - ASUS PRIME Z590M-PLUS
            by DynaxSC
            Hi, i have an ASUS PRIME Z590M-PLUS board, which had an shorted Z590 chipset. I have succesfully exchanged the chipset to a factory new one, however there is a serious problem with the Intel Management Engine (later on: ME) not beeing activated after the chipset device replacement.
            For lower chipset families (on ASUS boards) it worked to program the oldest bios version into the SPI rom, and the bios had activated the Management Engine itself by default - there was a message on the screen prior booting - "BIOS is updating Management Engine ..... . Do not shut down to prevent...
            06-10-2023, 11:30 AM
          • piernov
            NVidia bumpgate
            by piernov
            Just archiving everything related to bumpgate since most stuff has disappeared from Google. Maybe people will finally take the time to read some of it and stop shouting "reflow gpu" at every occasion but rather try to understand what the real issue is…
            Interesting parts about the failure analysis are "Why Nvidia's chips are defective" and "Why Nvidia's duff chips are due to shoddy engineering"
            May complete this post at a later date with more details.
            Basically issue is a combination of thermal dissipation of the chip with hotspot,...
            03-27-2021, 10:34 AM
          • DXseekerMO
            Backlight strip quality, Amazon vs Ebay vs ShopJimmy. Is there really a difference?
            by DXseekerMO
            Hello everyone!
            Recently I've noticed that some ShopJimmy backlight strips don't have double-sided tape installed upon them when an application calls for it, and I must purchase the tape separately. In a recent chat conversation with a customer service agent I told them if this tape wasn't applied when it was called for I would begin to consider ordering my backlight strips elsewhere. It looks like this time may have come.
            I recently got a TCL 65S4 with bad backlights. After looking at the SJ listing here: https://www.shopjimmy.com/tcl-jl-d65...365as-m-led-ba...
            Yes
            0%
            1
            All backlight strips are the same quality
            0%
            1
            No
            0%
            0
            12-16-2021, 03:58 PM
          • qayyum786
            *Use Full MOST COMMON I.C FOR LAPTOP YOU SHOULD HAVE IN STOCK*
            by qayyum786
            *MOST COMMON I.C FOR LAPTOP*
            *YOU SHOULD HAVE IN STOCK*
            *Charging IC
            8682L OZ8682L OZ8682LN QFN-16 Chipset
            OZ8681LN OZ8681L OZ8681 8681 8681L QFN-16 Chipset
            ISL88731CHRTZ ISL88731C 88731C QFN-28 Chipset
            ISL88731HRZ ISL88731QFN-28 Chipset
            ISL6251AHAZ ISL6251A ISL6251 SOP-24
            ISL95521HRZ ISL95521 95521HRZ QFN-32 Chipset
            AXP288 QFN-76
            AXP288C QFN-76
            CD3301 CD3301RHHR QFN-36 Chipset
            CD3301BRHHR CD3301B QFN-36
            BQ24705
            BQ24707 BQ707
            BQ07A BQ24707A QFN-20
            BQ715 BQ24715 BQ24715RGRR
            05-26-2020, 06:13 AM
          • Pize92
            Defective BIOS chip
            by Pize92
            Hello everyone.
            I have a problem.
            The BIOS chip on my Lenovo Legion 5 17ACH6H appears to be defective. I wanted to read the chip first with the ch431a programmer and then with the t48 and create a dump. However, it always threw an error during verification.
            I then bought a new BIOS chip from Aliexpress and loaded an existing dump onto the chip. With the corresponding DMI.
            Unfortunately, the laptop now keeps restarting.
            My question is, can you simply use the DMI from a foreign dump, or is the motherboard completely lost due to the defective BIOS chip?
            08-19-2025, 10:59 AM
