I have a inspiron 1521 AMD dual core with Radeon Xpress 1270 graphics, I was browsing the web in chrome and all of a sudden chrome says a tab is unresponsive so i close it and keep browsing ebay about 10 seconds later it looks up and the screen goes grey and fans to high speed, now it wont even power up. goes on for a second then shuts off. I found their are alot of bad logic boards for sale on ebay and it makes me wonder if the ati chipset is defective. I tried all to revive it removed cmos battery, reseated processor tried different ram etc, nothing. i even removed the ram as I was told dells beep if you do so and nothing. I have since bought another parts machine off ebay that boots and hope this doesn't happen again.
defective ati chipset?
My Computer: AMD Ryzen 9 3900X, Asrock X370 Killer SLI/AC, 32GB G.SKILL TRIDENT Z RGB DDR4 3200, 500GB WD Black NVME and 2TB Toshiba HD,Geforce RTX 3080 FOUNDERS Edition, In-Win 303 White, EVGA SuperNova 750 G3, Windows 10 ProTags: None -
Re: defective ati chipset?
it might be a BGA issue. I've ran into one bad balled modern AMD chipset, and it wasn't overheated or anything (didn't produce much heat)
did a full reflow, customer has said it still works now over a year laterCap Datasheet Depot: http://www.paullinebarger.net/DS/
^If you have datasheets not listed PM me -
Don't think it's a BGA issue. These old chipsets rarely failed. Some power supply went short. Or maybe even the CPU. I've had older AMD CPUs short out before.
If the chipset BGA had bad soldering it would have still powered on afterwards, giving distorted or no video.Originally posted by PeteS in CARemember that by the time consequences of a short-sighted decision are experienced, the idiot who made the bad decision may have already been promoted or moved on to a better job at another company.Comment
Thanks for the advice guys. I got my parts unit 1521 today and put it back together, using a AMD Turion 64 x2 TL-60, the chipset temp gets higher then the cpu, gets up to about 69. I noticed on the logic board it has two amd chips I think one is the x1270 and the other the chipset, the chipset is a naked chip and has no heatsink where the other one shares with the cpu's heatpipeMy Computer: AMD Ryzen 9 3900X, Asrock X370 Killer SLI/AC, 32GB G.SKILL TRIDENT Z RGB DDR4 3200, 500GB WD Black NVME and 2TB Toshiba HD,Geforce RTX 3080 FOUNDERS Edition, In-Win 303 White, EVGA SuperNova 750 G3, Windows 10 ProComment
The other chipset is the southbridge and does not require a heatsink.Originally posted by PeteS in CARemember that by the time consequences of a short-sighted decision are experienced, the idiot who made the bad decision may have already been promoted or moved on to a better job at another company.Comment
by DynaxSCHi, i have an ASUS PRIME Z590M-PLUS board, which had an shorted Z590 chipset. I have succesfully exchanged the chipset to a factory new one, however there is a serious problem with the Intel Management Engine (later on: ME) not beeing activated after the chipset device replacement.
For lower chipset families (on ASUS boards) it worked to program the oldest bios version into the SPI rom, and the bios had activated the Management Engine itself by default - there was a message on the screen prior booting - "BIOS is updating Management Engine ..... . Do not shut down to prevent... -
by piernovJust archiving everything related to bumpgate since most stuff has disappeared from Google. Maybe people will finally take the time to read some of it and stop shouting "reflow gpu" at every occasion but rather try to understand what the real issue is…
Interesting parts about the failure analysis are "Why Nvidia's chips are defective" and "Why Nvidia's duff chips are due to shoddy engineering"
May complete this post at a later date with more details.
Basically issue is a combination of thermal dissipation of the chip with hotspot,... -
by DXseekerMOHello everyone!
Recently I've noticed that some ShopJimmy backlight strips don't have double-sided tape installed upon them when an application calls for it, and I must purchase the tape separately. In a recent chat conversation with a customer service agent I told them if this tape wasn't applied when it was called for I would begin to consider ordering my backlight strips elsewhere. It looks like this time may have come.
I recently got a TCL 65S4 with bad backlights. After looking at the SJ listing here: https://www.shopjimmy.com/tcl-jl-d65...365as-m-led-ba...Yes0%1All backlight strips are the same quality0%1No0%0 -
by qayyum786...*MOST COMMON I.C FOR LAPTOP*
*YOU SHOULD HAVE IN STOCK*
*Charging IC
8682L OZ8682L OZ8682LN QFN-16 Chipset
OZ8681LN OZ8681L OZ8681 8681 8681L QFN-16 Chipset
ISL88731CHRTZ ISL88731C 88731C QFN-28 Chipset
ISL88731HRZ ISL88731QFN-28 Chipset
ISL6251AHAZ ISL6251A ISL6251 SOP-24
ISL95521HRZ ISL95521 95521HRZ QFN-32 Chipset
AXP288 QFN-76
AXP288C QFN-76
CD3301 CD3301RHHR QFN-36 Chipset
CD3301BRHHR CD3301B QFN-36
BQ24705
BQ24707 BQ707
BQ07A BQ24707A QFN-20
BQ715 BQ24715 BQ24715RGRR -
by sikocanI believe Chip 2 is BIN is the main one as it contained the Windows product key, marked with XXXXX for now.
SN: PF3G1REP
MODEL: 20KW-00J1AU
PROBLEM: Turns on blank screen, charging circuitry motherboard looks good. I have tried another firmware here - but resulted in 5V will not go to 20v due to different PD firmware I believe - using the current firmware it does go to 20V.
Requesting a firmware clean/BIOS region cleaned. Here is output from ME Analyzer:
Channel: BIOS Requests ONLY!
- Loading...
