Landparty Abit Nf7s v2 motherboard
  • ivtec
    • Dec 2008
    • 1967
    Hi guys; i went to a Flee market and got this brand new mother board, DFI Landparty Abit Nf7s v2 for 10 bucks,the guy even did throw a Cpu 1 think it's a 1.6ghz i don't know for sure i will get the Cpu tomorrow,hope he will honor his word since i already payed for it,and as they say when one pays in advance we will mostly not be well served, any way this is the Board in question, i know this is very old but i hope to do with it better then my Emachines that is very bad!
    which of these CPus are the best for it.
    The board supports following CPUs
    - AMD Athlon XP 266/333/400MHz FSB
    - AMD Athlon 200/266MHz FSB
    - AMD Duron 200/266MHz FSB
    http://www.aoaforums.com/frontpage/c...y-ultra-b.html
    • 31204
    Re: Landparty Abit Nf7s v2 motherboard
    E-machines??
    you know the psu in them is often a killer right?
    open it and check it before you put it on a new board.
    • ivtec
      • Dec 2008
      • 1967
      Originally posted by stj
      E-machines??
      hi stj;I know i have too of those Bestecs Atx-250-12E, i don't use those Bestec ps anymore,it killed the 2.7 cpu that was there, i changed it for a An HP ps that is 90 times better.
      You say to open it to check the PSU,what should i look for,
      to check the 5v and 12 rails?
      but what i think these Bestecs PS kills the CPu and mothers board is the poor Filtering circuit!
        • 31204
        check for bad caps and replace the 5v standby caps even if they look o.k.
        that pretty much goes for any psu.
        • c_hegge
          • Sep 2009
          • 5219
          It's either an Abit NF7 or a DFI Lanparty. Abit and DFI were two completely separate companies.
          • ivtec
            • Dec 2008
            • 1967
            Thanks_hegge; it's a DFI Landparty 462 socket, my mistake.
            • ziplock
              Abit BE6-II motherboard
              by ziplock
              Greetings,
              I have an Abit BE6-II motherboard that posts sporadically with the bare minimum components installed - CPU, RAM, PSU, and a Keyboard. I know it posts when the speaker beeps. Re-seating the components has no effect.
              I thought the sporadic posting might be capacitor related. Upon inspection, non of the caps are bulged or leaking and they are all original. So, I pulled them ALL. While the ESR is OK, over half of them are leaking current between 1 and 2 mA. The biggest offenders are way out of spec, like a 1500uf / 6.3V measuring 2600uF and many of the 820uF caps...
              04-20-2025, 02:09 PM
              ABit IP35 Pro Motherboard Schematic
              ABit IP35 ProABit IP35 Pro Motherboard Schematic
              A motherboard based on the Intel P35 Bearlake-P+ RAID chipset....
              10-31-2024, 02:06 PM
            • glovecaps
              by glovecaps
              11-25-2024, 04:23 PM
            • Docus
              Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
              by Docus
              Hi everyone 😀,
              I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
              To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
              Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
              1. I already own the exact same model, but its plastic chassis is badly damaged.
              06-10-2025, 04:24 PM
            • Archimedes
              HP Envy 17-3290NR 3D Blank Screen - motherboard Louis V1.1 6050A2489901
              by Archimedes
              Subject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
              Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
              Fans are spinning. Blindly could install windows11 and got the device manager...
              07-30-2024, 05:14 PM
