Hack: MPC Clientpro 424 GPU upgrade
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Awhile back I scored a clientpro 424 for peanuts:
    https://www.badcaps.net/forum/showpo...&postcount=696
    but even with the RAM maxed to 2GB it's a bit of a dog... intel graphics seem to be the bottleneck (it runs 7 with SLIC'd BIOS)
    I opened it up to find that despite that all of the GPU parts are there minus the GPU. Heatsink, fan, and all (no thermal pads, but I have some sheet stock I can cut from).
    what came out was this:
    (ignore the crap in the background, yes IK my desk is a mess)
    the chipset heatsink also had similar contacts for lower RAM chips.
    sadly these units are rare and "identical" GPU modules nearly impossible to obtain and they're pretty pricey (like $90 out of Taiwan).
    The mod:
    http://www.ebay.com/itm/400761557640
    IMHO it's not bad for $30... it's a Quadro FX 770 aka a OpenGL optimized Geforce 9600. 512mb too. a far cry from the 256MB ATI x1600's it was designed for.
    It's a mod because I'll have to remove the 4 studs that used to hold the HP heatsink... nothing I can't do as they're usually press fit with a back bracket which I bet I could remove without too much trouble. I once removed some pressed studs from some socket 604 coolers (Ratdude's main rig V2) so IIRC some careful punch work will do the trick.
    Once removed, all I should have to do is cut new thermal pads and AS5 the die... and screw it on to the heatsink.
    To check before I purchased, I scaled the image to the dimensions of the dummy and HS and then compared them... the holes match up allright.
    My svideo out probably won't work after this but honestly, who gives a shit?
    Wish me luck...
    PS- before somebody screams "BIOS WHITELIST!!!", the bios was cool with me cheating in a spare intel 5100 A/G/N card into the TV tuner's mini PCIe slot /o any complaints... it's basically a desktop BIOS as far as I can tell.
    sigpic
    (Insert witty quote here)
  • goontron
    5000!
    • Dec 2011
    • 4108
    • US
    Re: Hack: MPC Clientpro 424 GPU upgrade
    meh, why not resurrect an unnoticed thread...
    i got an HP thin client with an AMD geode NX 1500 1.0ghz, 2gb ram, Desktop BIOS (even PXE), and truly crap onboard audio. it didnt have SATA but instead an IDE 26mb SSD.
    i replaced the SSD with a 10gb spinner, added an audio card, added a SATA raid card into the mix, and it is now the audio server for my AM transmitter.
    it has 2x2tb in RAID 1 for data, a $30 audio card, 10Gb IDE laptop drive for the OS, and is sitting in my crawl space. its running openSUSE 13.1, the music player is called MOCP, and the system management is all done over SSH using YaST, file uploads are using Samba. the broadcaster is just the usual "talking house" system.
    the hostname? dubstep-broadcast.
    Follow the white rabbit.
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      FYI the mod was a fail... BEEP BEEP BEEP says the bios...
      sigpic
      • RJARRRPCGP
        • Jul 2004
        • 6304
        Maybe a missing SMD component or a bad connector on the card.....
        ASRock B550 PG Velocita
        Ryzen 9 "Vermeer" 5900X
        Arc A770 16 GB
        eVGA Supernova G3 750W
        Alienware AW3423DWF OLED
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          Yeah, IDK, the thing is cool but sorta slow (a waste of a pentium D IMHO)... I'll recheck the card. I wish I had a good way to test (short of swapping it for the similar card in my asus x83V).
          sigpic
          • brethin
            • Dec 2008
            • 1907
            What Pentium D does it have?
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              2.8GHz, EMT64 capable (beyond that I'd have to check). Obviously Socket 775.
              sigpic
              • brethin
                • Dec 2008
                • 1907
                That is why it runs like shit not the video. I do a lot of socket 775 Pentium D stuff still and nothing under the 3.4 goes in them. It is night and day between a 2.8 and 3.4 Pentium D on these older machines.
                • ratdude747
                  Black Sheep
                  • Nov 2008
                  • 17136
                  Probably, but still for something not a laptop integrated video is kinda sucky IMHO.
                  sigpic
                  • macabook
                    by macabook
                    🧩 Initial Issue
                    07-24-2025, 02:17 PM
                  • cr4zychriss
                    by cr4zychriss
                    • Rebrand: PC Specialist
                    Yesterday, 04:04 PM
                  • pirati
                    by pirati
                    10-27-2025, 04:20 PM
                  • Vesko356
                    by Vesko356
                    08-11-2023, 03:27 AM
                  • jbonavita
                    by jbonavita
                    Some issues
                    Things I tried
                    04-29-2025, 09:38 PM
