Happened again. Resistor go short!
  • CapLeaker
    Leaking Member
    • 8146
    That's now the second time in my repair career that a through hole resistor go short!
    it was a Vishay CPF124K900FHB14 1W resistor measuring new 24.9kohm. <- notice the KILO ohm. Well now it measures 28.1 Ohm! See picture and PDF attached. This is something very rare happening, but apparently it does happen!
    • 31015
    carbon type?
    i'v seen carbon resistors go down in value when run at their voltage limit.
    i only buy metal film because of that.
    • CapLeaker
      Leaking Member
      • 8146
      Originally posted by stj
      carbon type?
      Read the PDF. It’s a METAL FILM, flame proof resistor!
        • 31015
        strange.
        unless there is rust under the paint, but that usually only effects wirewound parts.
        • CapLeaker
          Leaking Member
          • 8146
          strange.
          Strange all right! This should not be happening, but yet it does! What’s making it worse is look at the prices of these… you’d think you should get quality.
          • redwire
            • 3907
            I have only seen TO-220 style power resistors drop in value if they get overloaded. Bourns PWR220T 20W thick film resistors, which is scary. They are only rated for 200% surge. I tried to take one apart and there seems to be a short between the loops that happens when the metallization spatters inside.
            • CapLeaker
              Leaking Member
              • 8146
              Nice. TBH I haven’t seen your fault with these big power resistors. But even then these power resistors don’t have a high ohms rating like 24.9kOhm. Interesting case though and it’s not a cheap resistor either. Given, it is a rare thing to happen, but it did happen twice for me now that are extreme.
              • redwire
                • 3907
                Your resistor fail is really wierd - something inside must have carbonized? Either the core (ceramic) or an arc inside that made it across all turns of the element. Or you multimeter is baked.
                I would crack that resistor apart, for the science lol. I'd bet a good blast of say 24V would "fix" it" if the internal short is a bit weak.
                • CapLeaker
                  Leaking Member
                  • 8146
                  Nah, my Fluke DMM’s are O.k.
                  crack that resistor apart? Hmm… I have to find it in my electronic trash bin. Maybe something for a rainy day.
                  • gaelican
                    Asus ROG ga401IV motherboard - AC Short Protection resistor getting hot
                    by gaelican
                    I am working on an Asus ROG laptop repair. I was able to find that there is a short on the motherboard, and the 20 volts from the charger only gets to the first mosfet before disappearing.
                    When looking around with a thermal camera, I noticed the chip marked "14C" in the picture was getting warm. Nothing else was receiving heat.
                    I found a boardview diagram and schematic for a motherboard that looks nearly identical, that has the same component. This appears to be marked as "AC Short Protection" with a value of 13.7KOhms.
                    02-21-2025, 01:51 PM
                  • jinu_j
                    by jinu_j
                    Hi
                    05-03-2025, 10:51 PM
                  • mikey5791
                    Need help to replace burned resistor in 350w atx psu
                    by mikey5791
                    Hi to all forum members,
                    Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
                    The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
                    Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
                    Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
                    12-26-2024, 04:55 AM
                  • Stephen
                    MacBook Pro 14" A2442 Short on PPBUS_AON but no short present when injecting voltage!
                    by Stephen
                    I check PPBUS_AON and there is a short present on the line, the computer shows a short when testing for short to ground, so when I inject voltage into the line, I get 0AMPS so no short is showing up. I have replaced a blown cap on this board that exploded and tested for the short and it is now removed. Any suggestions? I tested voltage at the line when the fuses are connected and I am getting 1.2 Volts at the line.
                    02-06-2025, 12:03 PM
                  • artvandalai
                    What resistor ohm will work better to repair this waterpik?
                    by artvandalai
                    The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
                    01-05-2025, 04:10 PM
