Memory slot removal
  • lezsimply
    The Wanderer
    • 657
    • Philippines
    Memory slot removal
    Good day. Does anybody here tried to repair memory slot by removing it? I was thinking a way how I could replace memory slots. I've got at least 22 desktop motherboards here that got slot problems. All boards have power but constantly beeps because it can't detect memory. Already found burnt marks on the gaps between ram slot and motherboard but cannot reach it.
    • 31293
    Re: Memory slot removal
    got a foto of that?
    • lezsimply
      The Wanderer
      • 657
      • Philippines
      I'll try my best to get a clear image. I don't have any microscope but magnifying glass usually helps.
        Where can I find a DD3 128000 type memory but 32 MGB in one module because this laptop has only one slot
        This Dell computer is a pain in the a** because of it only has one memory slot this computer only had 4 megabytes of memory and slower than shit I found a 8 megabyte memory module and it is better but still slow as shit the maximum is 32 megabytes of RAM but I was not able to find one I found some that are 16 megabytes but they are 1600/128000 type and I am not sure if this computer will work with this type of memory or not
        Dose anyone knows where I can find a 32 megabytes memory module for this computer because the battery still works fairly well still I would like to use it on my...
        07-07-2024, 02:34 PM
      • Byte_76
        Faulty memory slot on Tekram Slot 1 motherboard
        by Byte_76
        I have a Tekram P6PRO-A5 Rev. 1.01 which has an issue with one of the memory slots and with the floppy port.
        When a memory module is installed into the slot which is closest to the north bridge, the board will beep and won't post. The same memory module works in the two remaining slots.
        Also, the floppy drive does not work regardless of bios settings.
        Please help me to identify the possible cause of the faulty memory slot and the floppy drive port as well.
        I have examined the board under my digital microscope and did not find any broken traces....
        04-12-2025, 06:58 AM
      • szepesif
        Lenovo Ideapad 3 15IIL05 working perfectly with onboard RAM but it doesn't start when I add a memory into the RAM slot
        by szepesif
        Hey guys!
        I don't know the solution to this problem, but this is definitely not unique and I would like to figure out the solution to fix these in the future.
        I have two identical Lenovo Ideapad 3 15IIL05 laptops with integrated 4GB DDR4 memory. Both work perfectly with that. BUT... if I add any extra memory to the single RAM slot, it never gives a picture. I thought the RAM slot pins would be the problem but no, all pins are solid (I checked them under the microscope). The RAM in the slot has 1.2V, so the voltage is present on the module. I flashed the latest BIOS, so
        04-19-2025, 10:18 PM
      • Roli
        Lenovo C440 CIH61S1 motherboard , wont post with 1 slot of memory
        by Roli
        Hello , i got this lenovo C440 , with moderboard CIH61S1 , the problem is that when i put 1 memory in slot 1 the system wont post , ocasionaly it works but most of the time it doesnt and when it works , it gives BSOD-s and freezez a lot , if i put memory in 2nd slot , the system will work fine , if 2 put 2 memories again system will crash /freeze /bsod / or it wont post .
        I tried changinc CPU , other memory .
        05-01-2025, 08:48 AM
      • kokodin
        memory mod for amd radeon r7 260x
        by kokodin
        Hello, for almost a year i been trying to make something that seems impossible, or my testing software is lying to me and it works only i can't see that.
        I been trying to mod a memory on radeon hd7790 or 260x from 2 to 4 gb, but it doesn't seems to be as simple as i first thought.
        In theory 2 workstation graphic cards using the same graphical processor have 4gb of memory firepro w4300 has 4 256x32b layout and W5100 has 8x 128x16b layout all use gddr5 memory and internals of the bioses seems to be very similar so i was trying to wing it , but so far it seems either tserver can't show...
        03-28-2024, 03:48 PM
