Lenovo C440 CIH61S1 motherboard , wont post with 1 slot of memory
  • Roli
    • Jun 2010
    • 42
    Hello , i got this lenovo C440 , with moderboard CIH61S1 , the problem is that when i put 1 memory in slot 1 the system wont post , ocasionaly it works but most of the time it doesnt and when it works , it gives BSOD-s and freezez a lot , if i put memory in 2nd slot , the system will work fine , if 2 put 2 memories again system will crash /freeze /bsod / or it wont post .
    I tried changinc CPU , other memory .
  • Roli
    • Jun 2010
    • 42
    Update : I relflowed the the Controller " SLJ4B " untill i could move it just a little bit with a tweezer ( to check if balls were melted ) , again , it posted with slot 1 , after that it didnt post at all again ...
    • Roli
      • Jun 2010
      • 42
      Update 2 : Re wrote the bios with RTH809 programmer , still the same .
      • szepesif
        Lenovo Ideapad 3 15IIL05 working perfectly with onboard RAM but it doesn't start when I add a memory into the RAM slot
        by szepesif
        Hey guys!
        I don't know the solution to this problem, but this is definitely not unique and I would like to figure out the solution to fix these in the future.
        I have two identical Lenovo Ideapad 3 15IIL05 laptops with integrated 4GB DDR4 memory. Both work perfectly with that. BUT... if I add any extra memory to the single RAM slot, it never gives a picture. I thought the RAM slot pins would be the problem but no, all pins are solid (I checked them under the microscope). The RAM in the slot has 1.2V, so the voltage is present on the module. I flashed the latest BIOS, so
        04-19-2025, 10:18 PM
      • Byte_76
        Faulty memory slot on Tekram Slot 1 motherboard
        by Byte_76
        I have a Tekram P6PRO-A5 Rev. 1.01 which has an issue with one of the memory slots and with the floppy port.
        When a memory module is installed into the slot which is closest to the north bridge, the board will beep and won't post. The same memory module works in the two remaining slots.
        Also, the floppy drive does not work regardless of bios settings.
        Please help me to identify the possible cause of the faulty memory slot and the floppy drive port as well.
        I have examined the board under my digital microscope and did not find any broken traces....
        04-12-2025, 06:58 AM
        Lenovo ThinkPad P1 Mobile workstation P Specification for Upgrade or Repair
        This specification for the Lenovo ThinkPad P1 Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P1 boardview and P1 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...
        09-06-2024, 07:11 AM
