best vp6 overclock of all time?
  • Shodan486
    • Nov 2009
    • 203
    Re: best vp6 overclock of all time?
    It's worth of seeing the raw READ / WRITE bandwidth test results when sometimes SDR beats DDR. Not speaking about the extremly low latencies at such clocks...Anyways Pyro, at what clock is your RAM ? Don't know if that board supports asynchronous, but I assume it does.
    Mobo: MSI K8N Master2-FAR CPU: 2x Opteron 265 OC'd @ 2,25GHz RAM: 2x2GB Crucial DDR400 CL3 ECC/Buff. (ECC OFF), VGA: ASUS HD6950 2GB Reference edition FLASHED TO HD6970 HDD: 80GB ATA133 Seagate ,OnBoard: 2xGLAN, 8-Ch. Realtek audio, USB2.0/Firewire, PCIe Physx card PSU: 850W Corsair AX Case: Cooler Master HAF932 + NZXT 5 Fan Controller.
    • Pyr0Beast
      • Feb 2009
      • 406
      Heh. Could do some loops on sandra, yes.
      Ram. Hmm. At ~185 CL3
      I think it could go to 200 at ease. Chips are rated 142MHz CL2 anyway
      • Shodan486
        • Nov 2009
        • 203
        interesting....what brand? I got my 173,5 at CL2
        • Pyr0Beast
          • Feb 2009
          • 406
          Compaq something
          • titomno2
            Gaming Laptop Zephyrus S17 TFT not detected every time !
            by titomno2
            Hi guys,
            I post my problem here because I think it could be a capacitor related issue (Asus support on this particular subject is non-existing).
            So the computer is a Zephyrus-S17-GX735LXS-26T and the strange behavior is seen.
            On cold start most of the time the internal screen is detected and a picture it works fine until shutdown, sleep or deep sleep.
            Then the screen won't work for a long period of time.
            If I wait 1 or 2 hours it work again most of the time.
            When it doesn't work the batterie indicator blink 3 times white stop and the same schematic is repeated...
            01-19-2025, 08:27 AM
          • flat-earther
            Adding a clock battery to action camera to retain date&time when changing batteries Campark X25
            by flat-earther
            I have a cheap action camera with an annoying trait, every time I change batteries the date & time gets reset and I have to set it again.
            To solve this problem I want to add a small internal battery inside it which will keep supplying power to the camera for a while while I change batteries so the date & time is retained.
            I have opened the camera and I think there is enough room to add something inside to accomplish this:
            The camera is powered by a 3.7V nominal single cell lithium ion battery.
            So I need to connect another battery in...
            06-08-2025, 02:00 AM
          • OscarAV
            HP Pavilion dm4-1065dx long time to get the power led on
            by OscarAV
            I just came here to see if someone has had the same problem I have, and if he or she solved It, to know how to do It.
            I have made a quick search for my laptop but I have not seen anything similar.
            I have an old laptop, an HP Pavilion dm4-1065dx which takes a lot of time to be ready to start if the laptop has been unplugged for a while. It has no battery. The battery failed long time ago. It needs to be plugged to work. But as I said, It can take a lot of time until the charging led gets on, and I can switch on the laptop. I am using an external monitor...
            09-23-2024, 05:53 PM
          • l0lhaxz1
            QN65QN90A - Mainboard MLCC failed - now bootloop
            by l0lhaxz1
            Hi
            I have a QN65QN90A which was purchased around launch I guess making it about 1.5-2 years old... had been working fine until a few days ago, simply went black and would no longer turn on (at all). No standby light and no typical PSU relay click etc. Absolutely dead.
            Pulled it apart without doing much research first, suspecting the power supply as it had a faint buzz (I guess due to the forthcoming found short), investigated PSU for some time and concluded there was no fault that I could spot with the board removed.
            Came to learn after a bit more research...
            02-06-2023, 08:59 AM
          • BigOof
            Pioneer RM-07 Active monitors cutting out from time to time
            by BigOof
            I have a pair of Pioneer RM-07 monitors that I bought a while ago. When I was testing them I noticed that one speaker would cut out and I thought it was just a bad cable connection. At the price they were being sold for I was willing to take a risk on them. However, 6 months later and the one monitor still has the same issue. Most of the time it works, but there are times that the power LED is on but I get absolutely no sound. I can hear the relay clicking on/off sometimes and then it will/won't work depending on what it feels like. I've tried XLR and RCA inputs with the same issue. There's no...
            12-18-2024, 04:35 AM
