Predator power
  • pentium
    • Mar 2006
    • 2778
    Predator power
    I finally found a power supply for my Predator cd-rw drive but now I need to mod the plug to accept the power cord.
    I found the ground but for the 5v and 12v pins I am still lost. I don't dare want to try just going pin by pin. I would rather not burn the drive out.
    Find Nedry!
    Check the Vending machines!!
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: Predator power
    sunseeker predator power
    • pentium
      • Mar 2006
      • 2778
      Re: Predator power
      I knew that would mess people up.
      Here is an image if the Predator drive:
      It's great for laptops.
      Find Nedry!
      • willawake
        Super Modulator
        • Nov 2003
        • 8457
        • Greece
        Re: Predator power
        • pentium
          • Mar 2006
          • 2778
          Re: Predator power
          Will, are you drunk again?
          Find Nedry!
          • pentium
            • Mar 2006
            • 2778
            Re: Predator power
            Seriously?
            Nobody knows the pinout?
            Find Nedry!
            • willawake
              Super Modulator
              • Nov 2003
              • 8457
              • Greece
              Re: Predator power
              are you serious that the external power would be both 5v and 12v?
              • pentium
                • Mar 2006
                • 2778
                Re: Predator power
                Originally posted by label
                5V/12Vdc 1.0/.75A
                That's what it says.
                Find Nedry!
                • willawake
                  Super Modulator
                  • Nov 2003
                  • 8457
                  • Greece
                  Re: Predator power
                  i googled this but cant find the pinout
                  • pentium
                    • Mar 2006
                    • 2778
                    Re: Predator power
                    The soclet looks familiar to that on the external jazz drives. They might have the same pinout.
                    Find Nedry!
                    • WNG
                      • Sep 2006
                      • 354
                      Re: Predator power
                      looking at my old JAZ drive's Lite-On power supply....
                      Model # PA-2150-1
                      p/n: 02426901
                      Can't believe I still have this thing sitting around. Craigslist here I come.
                      “We the willing, led by the unknowing, are doing the impossible for the ungrateful.
                      We have done so much, with so little, for so long, we are now qualified to do anything, with nothing.”
                      • Tynan Dill
                        by Tynan Dill
                        Assuming...
                        11-22-2024, 01:46 PM
                      • PantherDave
                        by PantherDave
                        Hi all!
                        05-29-2024, 02:01 PM
                      • GLISIT
                        by GLISIT
                        01-16-2025, 02:29 PM
                        03-31-2024, 02:12 PM
                      • survivalbloke
                        Acer Predator Helios 300 - will not power up if battery is CONNECTED
                        by survivalbloke
                        This was a no power initially. Thanks to your help, I discovered it was the first mosfet, so I replaced. Now, the device will power up only if the battery is NOT connected. As soon as I connect the battery, it shuts off. If I connected the battery while the device is off, it simply will not respond to the power button. I replaced the battery, and while I suppose the new battery could be faulty, I'm assuming it is not. I'm having the same behavior with the new battery. I measure .2v at the charging coil. Manually applying power to the + and - at the battery header, there is no charging happening....
                        06-25-2025, 12:20 PM
