Another poorly done recap job
  • Dan81
    SNES-powered
    • Oct 2013
    • 1865
    Re: Another poorly done recap job
    Nah...I forgot about that old card.It has just 64mb VRAM,and I don't think it is supported under Windows 7.
    Also,no,it's not Nichicon.The name of that cap is made of three words.
    Main rig:
    Gigabyte B75M-D3H
    Core i5-3470 3.60GHz
    16GB DDR3-1600
    Samsung SH-224AB DVD-RW
    Delux MG760 case
    • ben7
      Capaholic
      • Jan 2011
      • 4059
      Originally posted by Dan81
      ...(I let you all guess what company made the 1500uf 6.3v caps on it.The name starts with N and ends with -on)...
      Also,no,it's not Nichicon. The name of that cap is made of three words.
      Nippon Chemi-Con
      Muh-soggy-knee
      • Dan81
        SNES-powered
        • Oct 2013
        • 1865
        Right.
        All the small 1500uf 6.3v caps were Chemicon KZGs.Now I use 3 caps for that ASUS A7V8X-X recap,all with the same specs:Sanyo WG,Nichicon HD (2000 datecode,safe) and some S.W caps from a Slot 1 board that was shot.
        Main rig:
        Gigabyte B75M-D3H
        16GB DDR3-1600
        Delux MG760 case
        • c_hegge
          • Sep 2009
          • 5219
          Nichicon HD was never affected by the HM/HN disaster. All Nichicon HDs are safe.
          That said, though, they are NOT a suitable replacement for KZG, as they have a higher ESR. The Sanyo WG caps are fine, though.
          • Dan81
            SNES-powered
            • Oct 2013
            • 1865
            Originally posted by c_hegge
            That dais, though, they are NOT a suitable replacement for KZG, as they have a higher ESR. The Sanyo WG caps are fine, though.
            ASUS used them on the CUSL2-C,so I don't see anything bad in using them.All are of the same ratings.Same uF and same voltage.
            I noticed that a PS2 50W PSU was posted on the PSU build pictorial.I got the same PSU and a Matushita built PS2 PSU,and I was surprised that on the Matushita,there wasn't any Panasonic cap,but all caps were Nippon Chemicon.
            Main rig:
            Gigabyte B75M-D3H
            16GB DDR3-1600
            Delux MG760 case
            • c_hegge
              • Sep 2009
              • 5219
              Pentium 3 boards generally had much lower power requirements for the CPUs, and thus didn't require the caps to be as low ESR as subsequent boards. HD might might be perfectly fine for a P3 board, but I wouldn't use them for anything later.
                master hoarder
                • May 2008
                • 12170
                #27
                Generally yes, but it also depends on the motherboard, too. For example, I have an ECS P4IBMS motherboard - that thing has IIRC either 8 or 10 cap spots on CPU VRM low side - all meant for 10 mm caps. The original caps in there were G-Luxon LZ, 6.3V 3300uF, and I believe there were only 6 or 8 of them on the board originally. A 6.3V 2700uF Chemicon KY in 10 mm diameter can already exceeds the specs of those G-Luxon LZs by a decent amount (0.031 Ohms ESR and 1910 mA ripple for the KY vs. 0.043 Ohms and 1400 mA for the LZ). So technically, I could have used just Chemicon KY (but of course, I used used 4x Nichicon HZ 6.3V 2200uF and 4x Rubycon MFZ 6.3V 2700uF instead because I have too many. Overkill for a 60-80W TDP Willamate/Northwood P4 CPU... maybe ).
                • Dan81
                  SNES-powered
                  • Oct 2013
                  • 1865
                  #28
                  Well,that's all I have.
                  When I'll have time I'll add the last 2 caps on the board,and see if it boots.
                  Also,is it good to replace a Teapo with a Rubycon YXG?
                  Main rig:
                  Gigabyte B75M-D3H
                  16GB DDR3-1600
                  Delux MG760 case
                  • c_hegge
                    • Sep 2009
                    • 5219
                    It depends on what series the Teapo was. Ruby YXG are on par with Nichicon HE and Chemi-con KY.
                    • Dan81
                      SNES-powered
                      • Oct 2013
                      • 1865
                      #30
                      I couldn't find any series written on that TEAPO.Anyways,I couldn't solder the cap to the video card.Strange thing is,the card still works!
                      Anyways,I scrapped on recapping the A7V8X-X and bought a complete pack consisting of a P4P800-VM (T-Systems OEM,caps are Rubycon and Panny everywhere!),a 2.4GHz Celeron D,and 4x 256MB DDR400 Kingston RAM.
                      I reinstalled 7 on the old 10GB HDD,as it wouldn't boot on the new system.Also,reflashed the BIOS to the latest retail BIOS(original was reading T-Systems BIOS 1015 LHM),but that after having a hard time installing 98 that didn't work on my 8GB old HDD,and ended up installing XP SP2 on FAT32 so I could access the drive from DOS.
                      Still,the CPU runs INSANELY HOT(81-85*C)yet it doesn't die at all.
                      Main rig:
                      Gigabyte B75M-D3H
                      16GB DDR3-1600
                      Delux MG760 case
                        master hoarder
                        • May 2008
                        • 12170
                        #31
                        Sounds like either sensor error (if you are absolutely sure the heatsink is on the right way and there is thermal compound under it) or something is wrong with the heatsink installation and the CPU is thermal-throttling.
                        • Dan81
                          SNES-powered
                          • Oct 2013
                          • 1865
                          #32
                          I am very sure I installed thermal compound under the heatsink and it is placed correctly.
                          It gets very hot,along with the northbridge heatsink,but I think the NB heatsink gets hot because it's very close to the HSF.
                          Main rig:
                          Gigabyte B75M-D3H
                          16GB DDR3-1600
                          Delux MG760 case
