Which laptop battery pins are used for charging?
  • Klevjetack
    • 12
    I have a laptop battery and I am curious on which of the pins are responsible for charging the battery and which ones are responsible for outputting power to your computer. Are there any websites that I can use to find this information or manuals that will tell me?
    • 31303
    check the laptop schematics,
    the 2 big terminals are both for output and charging,
    BUT
    the other pins are serial communication to a microcontroller in the pack that does the "guage" funcftion but may also allow/block charging
    • Klevjetack
      • 12
      BUT
      Do you think that if I directly applied power to two of the pins that it would charge the laptop battery?
        • 31303
        maybe - you will know if you monitor the current
        • Klevjetack
          • 12
          Okay I will give it a try thank you for the responses.
          • Julian Bailey
            HP ProBook 445 G8 Battery not charging
            by Julian Bailey
            Hi all
            We have in a HP ProBook 445 G8 laptop with AMD Ryzen 7 CPU. When power is connected the power LED light blinks 5 times then stops. Normally HP laptops will blink this LED 10 times as it does a self test when the AC adaptor is inserted. So there must be some sort of short somewhere.
            The battery doesn't charge, and is erratic on the MM voltage. Bench PSU LED pulsates when the battery is connected also. So the fault must be on the charging circuit?
            I have gone around the board with a MM and cant find anything
            Windows shows the battery fine,...
            10-11-2024, 10:34 AM
          • mferna14
            Samsung NP750XDA not charging battery
            by mferna14
            Dear gentlemen., today working on a Samsung Galaxy NP750XDA Laptop (NB3586-NB3587_PCBN_MB_V5), not charging battery. The laptop came with a dead battery & upon testing the battery Ouput coil getting around 6v, assuming that the battery circuit is ok & only the battery has to be replaced. I ordered a new battery, received & installed it but still same, NOT CHARGING. In the start, on the battery + pin I get 17v which is perfect for a 15.4V battery & then the volts drops down to 6v approx & does not charge or work on the battery & the charge LED comes on & then off. I...
            11-23-2025, 12:31 PM
          • piernov
            Laptop battery charging circuit
            by piernov
            1. Some theory
            1.1. Introduction
            Almost every laptop has a charging circuit of some sort, that does a few things:
            • Manages switching between AC adapter and battery power
            • Manages battery charging and generates power rail to charge battery
            There are 2 different designs to handle switching between AC adapter and battery power and feeding the system:
            • Hybrid power boost (HPB) and traditional circuits without power boost (see Warning in HPB section)
            • Narrow VDC (NVDC)
            Texas instrument has a nice overview of these technologies with some more details at https:...
            11-15-2020, 01:31 PM
          • Shinju
            Razor Blade Steath 13" RZ09-01963 plugged in Not Charging (new battery)
            by Shinju
            Hey All!
            Long time forum member here with a problematic laptop issue!
            I got a RZ09-0196 with a bloated battery (still worked and charged fine) I pulled the old cell pack out and installed a new cell pack in its place.
            The laptop would not power on with the new battery installed without the power supply being plugged in.
            When booting into Win10 (all up to date BTW) I saw the battery icon with 49% plugged in not charging.
            TL;Dr version, old battery worked, charged but was bloated, installed a new non OEM replacement, laptop/windows...
            10-20-2021, 04:58 PM
          • Iherduleikgemz
            Asus FX505DY - Battery not charging - BQ24780S
            by Iherduleikgemz
            Hello everyone
            I have been working on this laptop mentioned in the title, it initially had a shorted capacitor. After I replaced it, the thing started working again, but there is still another problem. The laptop was running off a charger, the battery was reporting 96% charge... but when I unplugged the charger, the laptop died. I've measured the battery voltage - 0V. I think it is locked. (Screenshot from batterymon, below).
            I've ordered a new 3rd-party battery, but I think there's something wrong with it too - the laptop boots, but the battery isn't charging. Also,...
            01-13-2025, 03:54 PM
