Looking For Drivers
  • canadaboy25
    What is normal?
    • May 2013
    • 509
    Looking For Drivers
    Hi, I was wondering if someone could help me find drivers for my Seanix Technology ASI 9000 PC.
    I am running Windows 95 on it and am using it for reading floppies and playing old, old games on.
    The drivers for my cards are not being detected in Windows so I was hoping somone could give me some or some advice.
    The graphics card is PCI here are all of the numbers on the board...
    ---Front---(Component side)
    The board says - "Designed and Assembled by ATL in Canada Rev. 1.0 1996"
    and the biggest IC says -
    Cirrus Logic
    CL-GD5446-HC-A
    68838-740AC
    9629 A
    JAPAN-U
    ---Back---
    003 94V-0
    E117895 NO:164018
    and on a sticker - ARV 244727
    Sound Card - Uses ISA
    ---Front---
    FCC ID:L6NS611
    48.S611H.002
    P/N:S611-SB
    ---Back---
    on a sticker - WN61463206231A
    Fax Card - uses ISA Not as important to find drivers for
    ---Back---
    Sticker -
    53645 REV.C
    DMEX60817WO0724
    So that is all of the info on the cards.
    I looked on google some but found no drivers so any help will be appreciated.
    canadaboy25
    -Sometimes the light at the end of a tunnel is an on-coming train
  • lti
    • May 2011
    • 2545
    Re: Looking For Drivers
    What chips are on the cards?
    • pfrcom
      Oldbie
      • Jun 2006
      • 1230
      For graphics, try
      http://support.lenovo.com/en_US/down...ID=YAST-3JKNBZ
      or
      https://downloadcenter.intel.com/Det...e&DwnldID=1770
      For sound, your FCC ID Googles as a ES1869F, so Google ES1869F WIN95 and take your pick
      better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
      • canadaboy25
        What is normal?
        • May 2013
        • 509
        Thanks for those I have got the drivers downloaded and will try installing them today
        canadaboy25
        • canadaboy25
          What is normal?
          • May 2013
          • 509
          Thanks for the graphics driver.
          I ran the program and it set up a floppy driver disk that worked flawlessly.
          I am havving a difficult time finding any working drivers for my sound card.
          I like how the one you provided let me make an install disk.
          Do you have any for my sound card?
          canadaboy25
          • canadaboy25
            What is normal?
            • May 2013
            • 509
            I also have an PCI ethernet card
            The front of the board says
            37NB-12270-313 REV:1.3
            and on the chip - The RMC "Crab"
            RTL8139D
            56136Q1
            5293 TAIWAN
            I would really like to get this one working.
            canadaboy25
            • pfrcom
              Oldbie
              • Jun 2006
              • 1230
              http://download.cnet.com/es1869-zip/..._4-161595.html
              RTL8139D
              http://download.cnet.com/Realtek-RTL..._4-150004.html
              • canadaboy25
                What is normal?
                • May 2013
                • 509
                well my sound card is an es1868 and both of them are asking for install disks which i dont have.
                canadaboy25
                • Elysarian
                  • Mar 2013
                  • 200
                  http://www.realtek.com.tw/downloads/...&GetDown=false - network card driver
                  • mariushm
                    • May 2011
                    • 3799
                    The install disk it asks for may be part of the Windows 95 installation.
                    Put the Windows 95 CD or browse to the folder where you have Windows 95 setup folder on the hard disk and if it's a file from the Windows CD it should auto pick it.
                    • dtonline
                      • Apr 2014
                      • 30
                      • VietNam
                      for the es1868 sound driver for windows 95, please download from this http://www.mediafire.com/download/if...g9k3/WIN95.rar
                      • japlytic
                        DRIVER_PNP_WATCHDOG error re. old drivers in Windows 11 install image
                        by japlytic
                        In a Beelink GTR mini PC, mine has an Intel AX200NGW WLAN module.
                        Tried (only with keyboard/mouse connected):
                        • BIOS + database update
                        • Using latest Windows 11 image built with official image creation tool
                        • Previous setup version for Windows 11 installer
                        • Replacing SSD without a slow block (the previous SSD had a slow block with access time > 500 mS)
                        • TPM reset (worked to the point where DRIVER_PNP_WATCHDOG error message is displayed briefly after the point of stalling)
                        • Disabling power to WLAN and LAN modules in BIOS (Advanced > AMD PBS > PCI Express Configuration)
                        06-19-2025, 04:59 PM
                      • pavithra
                        LC6685 based LED drivers
                        by pavithra
                        I have 50 Chinese constant current isolated LED drivers based on LC6685 IC. 35 drivers are working fine, but there is a slight flickering in the rest of the drivers.
                        I have checked the output with oscilloscope and found that there is a slight random voltage fluctuation.
                        Is it possible to get the datasheet of LC6685 IC?
                        Also highly appreciate if you could let me know what could go wrong....
                        04-16-2024, 02:46 AM
                      • kuba2102
                        Alienware m15 R4 CPU or CPU drivers issue
                        by kuba2102
                        Hi. I had a problem with this laptop that under a load it would crash the system, meaning the screen would go black and unresponsive. I have noticed that CPU drivers surrounding area of PCB has changed colour due to high temperature. I have tried to reball the Drivers, but after it laptop wouldn't turn on at all and it would trigger over current protection in the PSU. I ordered and replaced 3 of of 5 Drivers (3 CPU, 2 IGPU?), and it started producing 1.2V again but just for a second. I get led flashing out the CPU failure code. Now I'm not sure whether there is still a problem with the drivers...
                        01-04-2023, 09:05 AM
                      • kotel studios
                        Intel D865PERL - no Vcore after replacing MOSFETs and MOSFET drivers
                        by kotel studios
                        Finally got time to fix this board up.
                        At first it didn't give any POST codes. Turns out it was an unsupported Celeron D cpu. After dropping in an Celery 2.6gHz the CPU came out of reset with clock signal, but still no post codes. For a while it did work when I applied pressure to the ADP3168 chip, but on next reboot the MOSFETs started to burn. Then I left it as is for months.
                        Now I came back prepared. Replaced the bad MOSFETs and the ADPxx18k drivers. Now I don't get any MOSFETs blowing up issues anymore. But sadly, the Vcore is missing. The whole VRM isn't...
                        04-22-2025, 05:08 AM
                      • YOUCEF4787
                        Installation Issue with AMD Radeon 520 Graphics Drivers on Dell inspiron 15 3576
                        by YOUCEF4787
                        I am writing to seek assistance regarding a problem I encountered while attempting to install the AMD Radeon 520 graphics drivers on my Dell Inspiron 15 3576 laptop running Windows 10.
                        Upon installing the graphics drivers, my system freezes, and I am left with a black screen. Unfortunately, this issue has prevented me from utilizing the full capabilities of my AMD Radeon 520 graphics card.
                        Laptop Model: Dell Inspiron 15 3576
                        Operating System: Windows 10
                        Graphics Card: AMD Radeon 520
                        Steps I have taken:
                        Downloaded the latest AMD...
                        07-08-2023, 05:23 AM
