Is there a handheld device I can plug into an unpowered hard disk to get the SMART info like hours of operation, bad sectors, etc?
SMART data reading device?
Re: SMART data reading device?
Any ROM chip responds to software commands only when is powered up. -
I suppose. I'm assuming the controller board only needs the 5V while the 12V is for the spindle?
Or if there is no device that does this, is there a bootable program that is soley for checking the SMART data on a drive hooked to a PC?Presonus Audiobox USB, Schiit Magni 3, Sony MDR-V700Comment
there are many different pieces of software for reading smart data.. i use intel ssd toolbox, hdtune, sometimes seagate seatools, you name it.
As for hooking up 3,5 drive to my laptop over esata and not supplying 12V, the computer didn't see the drive at all, so i don't think this is possible.Comment
In modern drives pcb contains just a bootstrap code
that load the full firwmare from the platters and
allows the disk to full initialize.
SMART data are usually stored in a firmware module
so you won't get any info if disk is not spinning.
If you need to quickly test lot of disk for SMART
parameters i would suggest to download MHDD from here
http://hddguru.com/software/2005.10.02-MHDD/
http://hddguru.com/download/software...2ver4.5iso.zip
and use an old board with true ATA support.
It's just a matter of seconds to boot and check data.Comment
by mrdevilHi all,
Wanted to share this as I couldn't find anything on the internet about this problem, so pulled one apart and found the problem myself. Years ago I bought approx 20 or so Crest Smart Home Single Power Adapter smart switches - small 240v Tuya-compatible (rebranded) smart switch devices with power monitoring, which Big W had on sale for half price. Paid $7.50 each for these, and they've been incredibly useful for turning things on and off remotely... and monitoring how much power each device uses.
However, after about 12 months, I had a number of these stop working... -
by camisaoHello there,
I have a issue with a tower UPS 3000XL with also an external battery tower that has almost new batteries and very little use.
A week ago it started entering boost mode because the read line voltage was below 210VAC, when it was in fact near 225 VAC.
The battery voltage was also low (48 or 49), when in fact the batteries are fully charged to 55.1 VDC.
I opened it up up, cleaned and tried a reset.
I updated lower transfer voltage to 196 with apctest and then used the serial port to adjust the configuration with a terminal in Prog mode... -
This specification for the HP EliteDesk 800 G5 + Fitbit Versa Smart Fitness Watch can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G5 + Fitbit Versa Smart Fitness Watch boardview and EliteDesk 800 G5 + Fitbit Versa Smart Fitness Watch schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...09-12-2024, 02:30 PM
This specification for the HP ProDesk 600 G5 + Fitbit Versa Smart Fitness Watch can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + Fitbit Versa Smart Fitness Watch boardview and ProDesk 600 G5 + Fitbit Versa Smart Fitness Watch schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...09-12-2024, 02:30 PM
- Loading...
