Need to make the internal PC speaker louder...
  • Maxxarcade
    • Jul 2006
    • 973
    I need to find a way to make the PC speaker louder in two of my servers, so I can hear it through the floor (servers are in the basement right below my bedroom).
    Reason is, the internal PC speaker is used for server status audible prompts, and to warn if a fan has stopped or the system is overheating. The speaker that is currently being used is just a small piezo that came with the case. I can barely hear it over the fans, even when standing right in front of the server rack.
    Is there any way I can get it to be louder without using external amplification? I was thinking of trying a horn speaker similar to what is used for alarm sirens, but I wasn't sure if it would overload the driver circuit on the motherboard.
    Funny thing is, a lot of newer cases don't even have the speaker in them at all, because nobody uses it anymore. I remember when some DOS games actually came with a bigger speaker that you would install in the PC to get better sound. That was back in the day before the common sound card that we now take for granted came around. And I think I paid a good couple hundred for my old 8 bit, mono Sound Blaster 2.0, even when there were newer cards out
  • shadow
    • Feb 2007
    • 732
    Re: Need to make the internal PC speaker louder...
    Hmmm I dunno what to do in this case. A larger speaker has the huge problem in that it will draw too much current from the motherboard head connector. You can certainly try.
    The way to go seems to be to amplify the signal. I know that you do not want to do this, however I think it would work out well.
    What if you connect your motherboards PC speaker output to your sound cards auxiliary input (even if it is the inbuilt sound chip on the motherboard). That way the sound card could in theory amplify the signal and output it via a set of external speakers. This can be your horn speaker used in alarm sirens or possibly just a pair of $10 speakers that you may have lying around. This should work, I have seen it being done in the past. The sound card should be able to handle quite a lot more powerful speakers. However I am not sure if this is a path you are willing to take.
    • Maxxarcade
      • Jul 2006
      • 973
      Neither of the servers have sound cards, but I do have a small (~5 watts) rackmount amp that I may be able to use. The only problem is, I still have to figure out what to do with the second one, since I only have one amp with one channel, and using a Y adapter to hook up both systems might cause problems.
      Another thing- anyone know how much current can be drawn from a fan header on an older motherboard? The 80mm fans I'm using right now draw about 0.35a or so. I remember burning out a header on my Epox socket 7 board when I was using a 60mm 38CFM Delta fan. Well, not the header itself, the circuit that drives it
      • RoadWarrior
        • Feb 2007
        • 10
        Some soundcards had a header you could connect the speaker output to, can't remember seeing it on anything recent though. Wouldn't hook up too large a speaker directly to the board though, back EMF might kill it.
        I had one out of an old 60s or 70s radio, paper cone 4 inch, that was still rated under half a watt, but that was a lot louder and crisper than the regular sized ones. Had that hooked up on my 486 before I could afford a soundcard lol.
        Maybe just using some PCV plumbing parts jammed on top of the "squeaker" and brought outside the case to a small funnel might make enough of a difference.
        • RoadWarrior
          • Feb 2007
          • 10
          Fan headers used to be considered safe only to 500mA, (circa mid/late socket A era) dunno if they've beefed that rating on newer boards.
          • WNG
            • Sep 2006
            • 354
            Can't you pipe the PC speaker output through a resistor to reduce its wattage and route it to the soundcard's line in or CD in?
            I know some Windows-based drivers for sound include the PC Speaker as a mixed input.
            Have you did such a search, unless you're running a non-windows server.
            “We the willing, led by the unknowing, are doing the impossible for the ungrateful.
            We have done so much, with so little, for so long, we are now qualified to do anything, with nothing.”
            • willawake
              Super Modulator
              • Nov 2003
              • 8457
              • Greece
              why cant you use some server monitoring utility, there are so many....
              by the way heres an interesting diy temperature monitoring solution
              • Maxxarcade
                • Jul 2006
                • 973
                Both servers are Linux, one is NASLite 2, the other is running a cut down Mandriva 2006 for a dedicated Zoneminder DVR system. Neither server has a sound card.
                • Per Hansson
                  • Jul 2005
                  • 5895
                  • Sweden
                  You could try scavanging a speaker from an old 286/386
                  Many of them came with pretty big speakers... If it kills the circuit don't blame me though
                  • Maxxarcade
                    • Jul 2006
                    • 973
                    Sweet, I'll look into this. Though I wouldn't be able to use it with NASLite...
                    • MD Willington
                      • Sep 2004
                      • 702
                      Have the speaker header connected to a relay that can activate a door bell...
                      "who the hell is ringing the bell"
                      "the server"
                      LOL
                      Ya'll think us folk from the country's real funny-like, dontcha?
                      The opinions expressed above do not represent those of BADCAPS.NET or any of their affiliates.
                      • toastygoodness
                        • Jul 2005
                        • 813
                        nice one, MD. Seriously, it might work.
                        • Maxxarcade
                          • Jul 2006
                          • 973
                          LOL, that would be cool. Speaking of doorbells, I've always wanted to build one of the ones that uses the big chime tubes (~5-6ft in length). I like the big full sound those have, especially when compared to the electronic ones
                          • Christos Tsiligiannis
                            Marian Trace Alpha sound card repair help
                            by Christos Tsiligiannis
                            Hello to the forum.
                            My name is Christos, I am new to the forum here and i am posting from Greece.
                            So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
                            To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
                            So i tried asking for a schematic from the company and they would not give me one. Instead they...
                            11-18-2024, 05:26 AM
                            HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500 Specification for Upgrade or Repair
                            This specification for the HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar boardview and ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                            09-12-2024, 02:30 PM
                            HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i7-9700 Specification for Upgrade or Repair
                            HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500T Specification for Upgrade or Repair
                            HP ProDesk 600 G5 + Bluetooth Speaker 400 ProDesk 600 i7-9700 Specification for Upgrade or Repair
                            This specification for the HP ProDesk 600 G5 + Bluetooth Speaker 400 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + Bluetooth Speaker 400 boardview and ProDesk 600 G5 + Bluetooth Speaker 400 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
