Hi guys; can you please tell me what is this 10Gb hard drive is this? i know that this Pentium 4 dell has an 80 Gb hard drive,
10GB Hdd and 80GB HDD?
Re: 10GB Hdd and 80GB HDD?
Also someone explain this;this is an pentium 4 but i took this screenshot of this!Attached Filesif you find these attachements useful please consider making a small donation to the site
Seagate U-series http://www.google.com.au/url?sa=t&rc...56643336,d.dGI
Second item looks like something from one of those CPU comparision sitesbetter to keep quiet and be thought a fool, than to open your mouth and remove all doubtComment
It's a 10 GB hard disk.. duh. Just google the ST3... code and you'll find more information.
For example this : https://cdn.badcaps-static.com/pdfs/...41a8d8bf91.pdf
The second picture... you're doing a benchmark, Blowfish if i remember correctly is an encryption algorithm.
So the software tries to encrypt some data and measures how fast it does it, then compares it to other processors. The software just tells you that for this particular purpose (encrypting some data), your processor is as fast as a particular Intel Celeron M 1.5 Ghz.
That is possible. The Pentium 4 is old and supports a set of instructions. The Celeron M may be newer and may support some additional instructions which make encrypting stuff faster, so even though the Celeron M may be slower in some things and run at lower frequency, due to those additional instructions it may encrypt faster than the Pentium 4.
The Celeron M may be slower at video encoding for example, compared to Pentium 4.
Last.. your statement in the last post above makes me think you don't really understand what that software tells you. Next time try not to rush to drawing conclusions and maybe check the Help menu to see if there's some explanation to what you see.Comment
Yes it looks like someone slipped in a 10GB HDD into your computer without you knowing about it... but it should have shown up during BIOS enumeration (unless you have the OEM logo turned on, possibly it gets hidden.)
From what I've played with, a Celeron-M at 1500 MHz (HP Pavillion DV4000) is sometimes faster than a Pentium-4M 2000MHz (Dell Inspiron 1100) but they are generally similar.Comment
Well this PC was not mine i got it on the side of the street ready to be picked up by the trash truck,if i were 2 minutes later it would go in the dumpster, lucky me cause i installedYes it looks like someone slipped in a 10GB HDD into your computer without you knowing about it... but it should have shown up during BIOS enumeration (unless you have the OEM logo turned on, possibly it gets hidden.)
Mint14 Nadia and now a have a great PC,Attached Filesif you find these attachements useful please consider making a small donation to the site
frank@frank ~ $ sudo fdisk -l /dev/sdb
[sudo] password for frank:
Disk /dev/sdb: 10.0 GB, 10005037056 bytes
255 heads, 63 sectors/track, 1216 cylinders, total 19541088 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x263a2639
Device Boot Start End Blocks Id System
/dev/sdb1 * 63 19518974 9759456 7 HPFS/NTFS/exFAT
frank@frank ~ $Comment
The HDD may be HPA'ed.
HPA= host protected area, a feature you can configure to prevent an OS from accessing more than a certain amount of the HDD.
In another words, tell the computer that there's less LBAs than they're actually are. Thus, reporting a smaller size to the BIOS than the HDD really is.Last edited by RJARRRPCGP; 11-19-2013, 10:36 PM.ASRock B550 PG Velocita
Ryzen 9 "Vermeer" 5900X
Arc A770 16 GB
eVGA Supernova G3 750W
Alienware AW3423DWF OLED
"¡Me encanta "Me Encanta o Enlistarlo con Hilary Farr!" -Mà mismo
"did I see a chair fly? I think I did! Time for popcorn!" -ratdude747Comment
It's not... his first screenshot clearly shows one is a Maxtor and one is a Seagate. The model corresponds correctly to a 10gb drive - http://www.driveparameters.com/Seagate/ST310211A/The HDD may be HPA'ed.
The 6L080J4 was a 7200RPM drive. Assuming it's still healthy (no bad sectors), it would be the better choice for the OS drive than the 10GB Seagate.Last edited by dood; 11-19-2013, 11:16 PM.Ludicrous gibs!
im afraid with the invention of GPT and 1TB+ drives, yes the day has come
Follow the white rabbit.Comment
They have for ages... Most laptops have only been able to do one HDD (although it's mostly a space/praticality thing). I've come across P4 era Dells, such as some versions of the Dimension 2400, with only one HDD cage (the second cage omitted) and a single port IDE cable. USFF boxes have almost always been single HDD. Pretty much every AIW (all in one) is the same story.
I think for consumer desktops (a dying market) it's more of a "add the feature if it's convenient" thing. All it usually means is some extra holes added to the stamping die at the sheet metal plant and possibly an additional PSU plug (which may be omittable thanks to the availability of cable splitters)sigpic
(Insert witty quote here)Comment
I'm going to have to boggle peoples' minds with a desktop computer that has five hard drives installed! With the fact that one of them is not being accessed at all (at the moment) because it's the hot spare for the RAID!
(and that other machine I decided to put all my spare/retired hdds in. That one has 7 HDDs in it currently (4x120G, 250G, 750G, and a 40G boot), all PATA. Course that wouldn't be possible without additional IDE cards...)Comment
And I thought my 4 10K RAID array in my main rig was unusual...I'm going to have to boggle peoples' minds with a desktop computer that has five hard drives installed! With the fact that one of them is not being accessed at all (at the moment) because it's the hot spare for the RAID!
(and that other machine I decided to put all my spare/retired hdds in. That one has 7 HDDs in it currently (4x120G, 250G, 750G, and a 40G boot), all PATA. Course that wouldn't be possible without additional IDE cards...)sigpic
Thanks mariushm; today i opened it up and disconnected the 10gb HDD and left the 80Gb connected but it did not boot,so i need to do what you suggested but how do i know what is the right position?, Guess i will try one position at a time and see! and post back.Comment
From what i see root (the linux installl) is on the 10gb driveThings I've fixed: anything from semis to crappy Chinese $2 radios, and now an IoT Dildo....
thanks again maiushm for your tip, i just reopened up the PC,and( how easy this Dell PC to be opened never had one like this)< and disconnected the 10gb hdd and jumped the pins from the second to the first pins closest to the tape connector and restarted and it booted up perfectly,
so is one less hardware running besides i did not need it for anything, it was there just to confuse the machine, like it did when i had the Xubuntu installed
remember i posted about <Grub Rescue>thanks, you guys in this Forum just rock, love it here,my favorite of all forums, can't get by without it.Comment
This specification for the ACER Veriton Veriton 2800 - Intel Pentium 4 530, 512MB, 80GB, DVD-ROM, Win XP Pro can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Veriton Veriton 2800 - Intel Pentium 4 530, 512MB, 80GB, DVD-ROM, Win XP Pro boardview and Veriton Veriton 2800 - Intel Pentium 4 530, 512MB, 80GB, DVD-ROM, Win XP Pro schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...09-12-2024, 03:36 PM
This specification for the Acer Aspire Acer Aspire 3 A317-33 17.3 inch Laptop - (Intel Pentium N6000, 4GB, 256GB SSD, HD+ Display, Windows 10, Silver) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 3 A317-33 17.3 inch Laptop - (Intel Pentium N6000, 4GB, 256GB SSD, HD+ Display, Windows 10, Silver) boardview and Acer Aspire 3 A317-33 17.3 inch Laptop - (Intel Pentium N6000, 4GB, 256GB SSD, HD+ Display, Windows 10, Silver) schematic. Our users have donated over 1 million...09-07-2024, 02:50 AM
This specification for the ASUS 14.0 FHD 1920x1080 Pentium Gold 7505 4GB 128GB with M365 1 Year Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14.0 FHD 1920x1080 Pentium Gold 7505 4GB 128GB with M365 1 Year boardview and 14.0 FHD 1920x1080 Pentium Gold 7505 4GB 128GB with M365 1 Year schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional...09-07-2024, 01:30 AM
This specification for the Acer Spin Intel Pentium N6000, 4GB, 128GB SSD, Full HD Touchscreen Display, Microsoft Office 365, Windows 10 in S Mode, Silver Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Intel Pentium N6000, 4GB, 128GB SSD, Full HD Touchscreen Display, Microsoft Office 365, Windows 10 in S Mode, Silver boardview and Intel Pentium N6000, 4GB, 128GB SSD, Full HD Touchscreen Display, Microsoft Office 365, Windows 10 in S Mode, Silver schematic. Our users have...09-07-2024, 01:00 AM
This specification for the Acer Chromebook (Intel Pentium N6000, 4GB, 128GB eMMC, 17.3 inch Full HD Display, Google Chrome OS, Silver) Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the (Intel Pentium N6000, 4GB, 128GB eMMC, 17.3 inch Full HD Display, Google Chrome OS, Silver) boardview and (Intel Pentium N6000, 4GB, 128GB eMMC, 17.3 inch Full HD Display, Google Chrome OS, Silver) schematic. Our users have donated over 1 million documents which are being added to the site. This...09-07-2024, 01:00 AM
- Loading...
