Intel's 45-nm Technology Breakthrough Will Impact Future Microprocessor Power-Supply
  • PeteS in CA
    • Aug 2005
    • 3581
    • USA, Unsure of Planet
    Intel's 45-nm Technology Breakthrough Will Impact Future Microprocessor Power-Supply Designs
    Sam Davis
    ED Online ID #14830
    February 4, 2007
    In what is touted as one of the biggest advancements in fundamental transistor design, Intel Corporation is now using dramatically new materials to make 45-nm devices that allow faster processor speeds and enhanced PC performance. However, this technological breakthrough will require a reconfiguration of the microprocessor power supply.
    A microprocessor's operating voltage usually comes from a VRM (voltage regulator module) or a circuit on the motherboard, the VRD (voltage regulator down). A 5- to 8-bit voltage identity code (VID) controls the VRM/VRD output voltage. These VID pins connect to corresponding pins on the microprocessor, which adjusts the VRM/VRD output to optimize the microprocessor's operating voltage.
    According to the 2006 International Technology Roadmap for Semiconductors (ITRS), the 45-nm feature size will require as low as a 0.7-V operating voltage with a maximum of 198 W. Intel's present 8-bit VR11 specification for the VRM/VRD has an operating range of 0.5 to 1.6 V in 6.25-mV increments. This needs to be changed to a narrower operating voltage adjustment range with smaller increments for tighter voltage regulation. And 45-nm microprocessors may require up to 200 A, depending on the number of transistors employed and the power dissipation per transistor.
    PeteS in CA
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: Intel's 45-nm Technology Breakthrough Will Impact Future Microprocessor Power-Sup
    AMD is working on this as well.
    200A is insane.......guess this will be some kickass digital vrm
    another item of interest :
    Intel Readies Processor with Integrated Memory Controller, I/O Functions.
    Intel Tolapai with Built-In North and South Bridges to Emerge in 2007
    http://www.xbitlabs.com/news/cpu/dis...205043526.html
    for budget systems
    • PeteS in CA
      • Aug 2005
      • 3581
      Re: Intel's 45-nm Technology Breakthrough Will Impact Future Microprocessor Power-Supply
      The uP developers at Sun were projecting core voltages as low as .5V at internal info meetings back in 1996. And that was at a time when electronic loads were rated for voltages as low as 1 or 2 volts! I don't want to think about how 200A will get bussed into the uP chip! Nor the current slew rates that might obtain when the uP wakes from sleep mode - hundreds or thousands of amps per microsecond?
      PeteS in CA
      • pentium
        • Mar 2006
        • 2778
        So pretty much we will have cpu's that will run cooler?
        W00T!
        Find Nedry!
        Check the Vending machines!!
        • willawake
          Super Modulator
          • Nov 2003
          • 8457
          • Greece
          yeah but the VRM will be roasting
          • stretch0069
            Screwed Up Super Moderator
            • Oct 2003
            • 2658
            • oooo ess aaaaaaaaa
            crap....we just decommissioned a system that has a 5Vdc PS........350A.
            i hate to have one in my house.....
            "Its all about the boom....."
            Guns kill people like spoons made Rosie O'Donnell fat.
            We now return you to your regularly scheduled drinking.
            "Fear accompanies the possibility of death.....calm shepherds its certainty"
            Originally posted by Topcat
            AWD is just training wheels for RWD.
            • gonzo0815
              • Feb 2006
              • 1600
              350a would make a nice arcing fire .....but vrm efficiency will go furbar with voltages that low.
              Even with synchornouse rectification there would be either a lot or a few very very speciall mosfets be necesarry. the Boars would have to have a lot more layers to conduct that current.
              But probably the whole board will then be a superconductor and thus absolut zero resistance.
              • Topcat
                The Boss Stooge
                • Oct 2003
                • 16956
                ...And 45-nm microprocessors may require up to 200 A...
                I really hope thats a blip, typo, or falsity! A 200A draw on any part of a PC would cause immediate meltdown. A cable capable of 200A is about 3/4" in diameter, the type of cable that actually brings power into your house. Many homes don't even have 200A electrical service.
                <--- Badcaps.net Founder
                Badcaps.net Services:
                Motherboard Repair Services
                http://folding.stanford.edu/
                Team : 49813
                Join in!!
                Team Stats
                • Per Hansson
                  • Jul 2005
                  • 5895
                  • Sweden
                  Many homes?!
                  Err, many homes don't have 20aH, most are wired for 16aH 3 phase
                  200aH is for industrial use only, and a heavy industry at that
                  But that current draw is not so insane, do the math on current high-end P4 processors and you will understand (130w/1.5v=87aH)
                  • willawake
                    Super Modulator
                    • Nov 2003
                    • 8457
                    • Greece
                    is this to be powered by solutions from volterra ??? buy shares now!!!!
                    • PeteS in CA
                      • Aug 2005
                      • 3581
                      200A requires a lot of copper! I wonder whether bus bars will be necessary.
                      PeteS in CA
                      • stretch0069
                        • Oct 2003
                        • 2658
                        Hmmmm....now I'm going to have to check out the old DARC system to see how they ran that 350A.
                        • PeteS in CA
                          • Aug 2005
                          • 3581
                          Think 2-0 or 3-0 (double or triple ought) welding cable. Or a large bundle of AWG #10 or #12 wires.
                          PeteS in CA
                          • Topcat
                            The Boss Stooge
                            • Oct 2003
                            • 16956
                            ...most are wired for 16aH 3 phase...
                            LOL not in the US they aren't.... If you want 3-phase in your home here, bend over to have it installed.
                            Team : 49813
                            Join in!!
                            Team Stats
                            • Per Hansson
                              • Jul 2005
                              • 5895
                              • Sweden
                              Hah, yea sorry, I meant for Europe, silly me :P
                              • tbsmith
                                Ninja DCT401 Double oven/air fryer Possible microprocessor issue?
                                by tbsmith
                                I'm having a random issue with this otherwise nice double oven/air fryer. It sometimes does not respond to the controls. Sometimes only the upper control buttons work, sometimes they all work and sometimes none of them work. The power supply is good as the control board has a steady 5V and 3.3V. The pushbutton switches are all good as tested with multimeter. When the buttons are working, there is about 2.5V to the high side of the pushbutton. I'm assuming pressing a button grounds the input pin to the microprocessor. When the buttons are not working, there is about 0.3 volts on the high side....
                                07-12-2025, 11:40 AM
                              • Pier
                                ASUS MAXIMUS VIII IMPACT Boardview, Schematic & Repair Guide
                                by Pier
                                As the title states i am looking for a schematic and boardview for the ASUS MAXIMUS VIII IMPACT motherboard.
                                I know that the boardview exists (ASUS MAXIMUS VIII IMPACT REV1.01.fz) but cannot find it free of charge, the schematic however might not be leaked.
                                For anyone interested, the repair guide is attached to this post.
                                Thanks....
                                09-23-2023, 07:21 AM
                              • Pfloyd36069
                                Nikon Z8 - No power after impact
                                by Pfloyd36069
                                Good afternoon everyone,
                                This is my first real post here. I am very new to a lot of this, so bear with me. I recently acquired a Nikon Z8 that had been dropped and will not power up. After removing the back of the camera, I found a large FPC cable that was half out of the connector. Great, I though I'd found the problem and reseated the cable and tested. Still no power. I started digging further and found an inductor that had overheated, bulged, and left a residue on the heatsink. I removed the inductor and retested, thinking maybe I would have some functionality, but still nothing....
                                07-07-2025, 11:56 AM
                              • flat-earther
                                help repair Scorpion SC-6989 12v cordless impact driver
                                by flat-earther
                                Hi I got this Scorpion High Quality Products model SC-6989 12v impact driver and the problem is it only runs on full speed and LED light doesn't light up.
                                I got the tool with two dead batteries and I already using the good 18650 cells from the two made one working battery.
                                Initially when I got it I once hooked up a good 12v battery to it and it powered up and LED worked but now depressing the trigger only makes it run on full speed or nothing so there's no variable speed, but to be honest I'm not sure if this tool has a variable speed trigger. Also LED doesn't light up anymore....
                                03-06-2023, 06:57 AM
                              • Keshenatech1
                                Question on microprocessor crystal oscillator circuit
                                by Keshenatech1
                                I'm troubleshooting a reel controller board for an IGT slot machine. The digital section seems to be dead. There is no USB communication, PC or utility program for flashing firmware do not see it but they do see good/working boards. I noticed the waveform on the crystal is very erratic/asymmetrical/glitchy on the bad one compared to the nice even waveform on a good board. My question is would this most likely be caused by a bad crystal or something gone bad in the circuit loading it down? I'm attaching a couple pictures of my scope probing the good and bad boads.
                                02-26-2024, 11:05 AM
