Bios update from hell!!!!11!
  • pentium
    • Mar 2006
    • 2778
    I finally manage to revive my prized DECpc 433dxLP system (it is also was built under the model PC473) and immediately I know what I want to use as an os:
    OS/2 2.0
    I begin the install and suddenly the install aborts with an error. I scan through the OS/2 docuuments and I see that it is a problem with an older bios.
    My phoenix bios is version 1.01.02 and the minimum OS/2 needs is 1.02.05D.
    So I begin to search. Compaq has a library of information on the DECpc but no matter where I go and no matter what site I visit I can't find that update!
    I know it exists because other owners have mentioned OS/2 2.1 worked fine after a bios update.
    Can anyone assist in finding this elusive update?
    "GAAA!"
    ---->|D|I|G|I|T|A|L|
    Find Nedry!
    Check the Vending machines!!
  • pfrcom
    Oldbie
    • Jun 2006
    • 1230
    Re: Bios update from hell!!!!11!
    http://h18000.www1.hp.com/legacysupp...l/epid115.html
    better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
    • pentium
      • Mar 2006
      • 2778
      I already went through there and the closest I can see to my system is the two at the bottom. Even then I am still a whole series off.
      Find Nedry!
      • Topcat
        The Boss Stooge
        • Oct 2003
        • 16956
        Have you tried emailing their support? If you get the right tech, who's not being an asshole, they should be able to email you the firmware you need. A similar thing happened with me and Adaptec over an ancient SCSI controller.
        <--- Badcaps.net Founder
        Badcaps.net Services:
        Motherboard Repair Services
        http://folding.stanford.edu/
        Team : 49813
        Join in!!
        Team Stats
        • pentium
          • Mar 2006
          • 2778
          I just did that.
          Now we wait and see what their excude is.
          That is if they ever reply to my message.
          Find Nedry!
          • tazwegion
            • Jun 2006
            • 444
            Did you try asking one of the other DEC owners if they still had the BIOS update (and if they could send it to you)?
            Last resort would be these guys @ e-Support most likely they've got it... however they charge $29.99USD for their BIOS repository service!
            Could you hit the pause/break key during bootup & post the entire BIOS id string here thanks... might help some
            Additionally, according to the DECpc LP service manual I found HERE, the DECpc 433dxLP is also referrred to as the PC743-xx
            Viva LA Retro!
            • pentium
              • Mar 2006
              • 2778
              I have the genuine service manual but thanks fr the link.
              Holding break at startup gives nothing new.
              Not even a Bios ID string.
              Find Nedry!
              • mikeybass
                by mikeybass
                04-23-2025, 04:30 PM
              • akwky
                by akwky
                Hi!
                04-14-2025, 01:56 PM
              • al3m0di
                Update bios EFCN58WW to EFCN59WW
                by al3m0di
                Update bios EFCN58WW to EFCN59WW for solving The Connected AC adapter has a lower wattage than the recommended AC adapter
                I have a Lenovo Legion 5 15imh05a device that I bought used online. It came with a 20V 8.5A 170W charger.
                The BIOS version is EFCN58WW.
                When I turn on the device, it displays the message:
                "The Connected AC adapter has a lower wattage than the recommended AC adapter..."
                The device rarely charges the battery, and even when it does, it doesn't show that it's charging.
                I've tried
                07-29-2024, 10:32 AM
              • trix11
                Dell Precision T1650 MT Workstation bricked after BIOS update
                by trix11
                I have a Dell Precision T1650 MT workstation (of the following spec.) that was bricked yesterday when attempting to update the BIOS from A27 to A28 per:
                - https://www.dell.com/support/home/en...-t1650/drivers > Dell Precision T1650 System BIOS
                - Dell Precision T1650 mid tower Workstation
                - Xeon E3-1225 V2
                - 32Gb PC3-12800E RAM
                - 4Tb SATA HDD
                - motherboard: Dell part: 0C3YXR CN-0C3YXR-72200-39C-01GR-A02
                I see now that others have experienced like issues e.g.:
                - https://www.dell.com/community/Prec...
                10-24-2022, 10:35 PM
              • Julian Bailey
                BIOS update wont complete - Dell Latitude 7420
                by Julian Bailey
                Hi all
                Anyone come across this issue where a BIOS flash will only part complete?
                It will update the system BIOS and Primary EC BIOS fine but fails to update the Intel TBT Retimer, Intel TBT Retimer 2 and ME Firmware.
                NVMe m.2 drive isnt detected in the BIOS, but you can get into the BIOS fine and it all works in there as intended.
                The drive works fine in another laptop.
                Link to a video I made of what its doing here:
                Any ideas on how to overcome this?
                Cheers...
                06-02-2025, 01:39 PM
