3Ware BBU Replacement
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    The BBU in my 3ware 9500S is reportedly dead...
    Has anybody had luck with 3rd party batteries? Or should I save up for a $$$ OEM one?
    sigpic
    (Insert witty quote here)
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: 3Ware BBU Replacement
    Anybody?
    sigpic
    • rhomanski
      nowhere man
      • 5157
      • U S of A
      Doo de do de doo de do. Don't know but didn't want you to get lonely.
      sigpicThe Sky Is Falling
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        picture?
        might be able to rebuild it on the cheap.
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16959
          OEM. You'll pay more for the batt, but it will save a lot of aggravation. The cheap shinese one I tried lasted about 2 months. Replaced it with an OEM, its been fine since, going on 3 years.
          Did the dead batt throw the controller into panic mode, and disable all write caching? Mine did on both controllers, it performed like absolute crap till that silly batt was replaced.
          <--- Badcaps.net Founder
          Badcaps.net Services:
          Motherboard Repair Services
          http://folding.stanford.edu/
          Team : 49813
          Join in!!
          Team Stats
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            It causes the status screen on bootup to display "bbu status: failed battery". Not sure if write caching was affected.
            edit- I thought I had a BBU pic, but I don't (that's uploaded and on a camera I can access)... so google it and you'll see.
            sigpic
            • RJARRRPCGP
              • Jul 2004
              • 6304
              I hope that it's not just a sensor like laptops sometimes falsely reporting a bad battery.
              ASRock B550 PG Velocita
              Ryzen 9 "Vermeer" 5900X
              Arc A770 16 GB
              eVGA Supernova G3 750W
              Alienware AW3423DWF OLED
              • ratdude747
                Black Sheep
                • Nov 2008
                • 17136
                Still haven't replaced the battery
                from the stock image on LSI's listing for a $60 replacement battery, it's an LI103450E battery, which also was used by dell for stuff.
                I know OEM is the way to go, but $60 is out of budget. (I know, I should have used a consumer crap board with no RAID card blah blah blah...)
                Edit- it's a 3.7V 1800mAH cell... I wonder if I could get a cell in the same form factor for cheaper and solder on the wires from the old one?
                edit- made an offer:
                http://www.ebay.com/itm/LSI-3ware-95...item20da74eee7
                it's got a newer battery , and given the hackjob my card is (been resoldered a few times), I figure that may be a better deal?
                sigpic
                • domas
                  News Hater
                  • May 2013
                  • 323
                  • Denmark
                  why not soldering in any random li-ion battery you have laying around? just another somewhat functional battery, will do the job. If it is a totally different shaped one it is actually an advantage, as you can zip-tie it ti the board, take a picture, and upload it to ghetto mod thread.
                  somebody will definitely say: "but it is li-ion, it can explode, i've seen macbooks going on fire"
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    Why? I'm not sure if the charging circuit will like a different battery. I have done this for other RAID cards (my GF's dad is the IT manager at Caterpillar's Lafayette Engine plant, and he had me "fix" some blown RAID batteries)... but in that case, it was a was a like for like battery swap with the controller on the battery. With my card, the controller appears to be in the BBU module itself, the battery a raw cell.
                    It's not like I have a 3.7V battery sitting (well, i might in a dead cellphone, maybe).
                    sigpic
                    • reformatt
                      by reformatt
                      07-31-2025, 08:37 PM
                    • the_rem
                      Unknown transformer : how to find a good replacement part ?
                      by the_rem
                      Hello guys,
                      I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
                      I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
                      04-23-2025, 01:48 AM
                    • ezenia
                      PS4 controller left stick potentiometer replacement issue
                      by ezenia
                      Not sure if this is the correct section, but I have a PS4 controller that I am trying to fix. It developed stick drift on the left stick and the usual simpler methods did not fix the problem.
                      So I went on eBay and ordered some replacement potentiometers. https://www.ebay.co.uk/itm/174967976757 is where I got them from.
                      I took the green potentiometers off the replacement sticks and soldered them onto the PCB. Assembled the controller and ran some tests. The drifting was somewhat fixed (not fully in center, but way better than before). However,...
                      09-30-2023, 02:19 PM
                    • boosti45
                      Macbook pro logic board replacement parts quesion
                      by boosti45
                      i have a 2020 macbook pro 13" A2251 with 820-09149 logic board so i found an issue with chip labeled U6903 according to schem. boardview using flexBV software, so i removed it from the board and the issue im having is that the chip says "07A08FI ELC180​" on top of it but when searching for a replacement chip, i can find tons of identical looking chips that also have "ELC180" printed on them but the first set of digits is never the same so im trying to find out if i need this exact chip with these same numbers as mine and if not which ones are compatible as a replacement?...
                      08-21-2024, 05:23 AM
                    • r2digital
                      klipsch kda-500 amplifier suitable power supply capacitor replacement ?
                      by r2digital
                      I have a klipsch kda-500 that would turn on and allow me to get into the web management but it was picking up a lot of noise from audio sources so i decided to replace the smd caps on the power supply along with radial one. Some one was in here before me and they basically burned the bottom side of the traces off for the radial cap but i was able to repair it without any real problem. I thought i did a good job sourcing out replacement caps but apparently not and now i can't get the power supply to turn on it just constantly try's to keep turning on. Attached is a picture of the power supply before...
                      04-18-2024, 03:50 PM
