In Win Commander III PSU
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    I've got that PSU running my main system - as far as I know it uses this fan:
    https://cdn.badcaps-static.com/pdfs/...f2b197fbca.pdf
    it's really noisy, what can I do?
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    Re: In Win Commander III PSU
    It's a death adda. Replace it
    Muh-soggy-knee
    • Pentium4
      CapXon Be Gone
      • Sep 2011
      • 3741
      He probably doesn't want to void the warranty on it. But honestly it shouldn't be that loud at all. Loud as in it's spinning fast or loud as in it sounds like the bearing is going bad??
      • c_hegge
        • Sep 2009
        • 5219
        The warranty is already voided. It's Oklahoma Wolf's review sample.
        It's a ball bearing fan, so I doubt if the bearings are wrecked yet. It could well be the fan curve. Another fan may very well be just as loud.
        • shovenose
          Send Doge Memes
          • Aug 2010
          • 6575
          it is rhythmical and loud
          • Pentium4
            CapXon Be Gone
            • Sep 2011
            • 3741
            Ohhh Wolf's sample, awesome just replace it. I may get crap for this but I love Yate Loon's 120/140mm fans, I would replace it with one of those
            • c_hegge
              • Sep 2009
              • 5219
              http://www.newegg.com/Product/Produc...d=1&name=135mm
              Those three are probably about your only options as 135mm fans are very hard to source. I always try to avoid PSUs with 135mm fans specifically for that reason. If you go with a sleeve bearing fan, then I'd make sure it has plenty of lubricant (and top it up if necessary) before installing it.
              • aidanmo
                Philips 43PUS7506/12 - Loud blown out sound
                by aidanmo
                I've got a really strange issue with the speakers on my Philips 43PUS7506/12. It makes this awful loud buzzing now. It happened after it was attempted to be wall mounted - I think the back got squeezed and something broke.
                I thought maybe the speakers got damaged, so I replaced them - no dice.
                • Using the internal speakers, it always happens.
                • Using the headphone jack, it never happens.
                • Using the digital/optical out with a soundbar - it happens after about 2h/movie runtime - it's never as drastic, it just pops in and out, but I didn't want it to damage the sound bar
                02-28-2025, 03:13 PM
              • mon2
                Crate guitar amp with extremely loud static on power on (no input)
                by mon2
                Hi. Not our mainstream line of work - we work with digital mostly. Will study the schematic found on the internet. The output darlington transistors appear to be ok. Even with no input, the output is extremely loud with static / crackle / pop. Any ideas? Will post more details and fix as we continue the review. Have not checked the main power supply rails yet (+-40V and +-16V).
                07-18-2025, 06:40 AM
              • justice171
                Lenovo E15 Gen 2 Keeps Beeping Loud Noise
                by justice171
                Hello Badcaps Members,
                I'm experiencing an issue with my Lenovo ThinkPad E15 Gen 2, and I'm hoping someone here might have some insight. The laptop charges to full capacity, but as soon as I power it up, I get a loud sound, and there's no POST.
                I disconnected the battery and connected a USB meter, which shows 20V 0.23A when the sound occurs. I've already tried changing the screen, but it didn't resolve the issue.
                When I use Lenovo PC Diagnostics App I get results as 01000
                Here are the details:
                • Model: Lenovo ThinkPad E15 Gen 2
                • Board Numbe
                10-01-2024, 09:19 PM
              • eliemgh
                lenovo t14 i7 10 gen : I press the power button and there is a loud fan noise
                by eliemgh
                lenovo t14 i7 10 gen : I press the power button and there is a loud fan noise for about 3 seconds and power light is on. Nothing on display screen. i have removed the battery and bios battery still the same. i have put yesterday on update and charger ,i have leave and back and see this problem. Any One Can help Me ?
                09-27-2024, 02:40 AM
              • Carm99
                Citronic AC-1USB Output Too Loud
                by Carm99
                Hi
                I have a Citronic AC-1USB.
                When I run a turntable into it and then try to record it. The volume is too loud and distorting. In the red. Mainly 12” Singles. I haven’t tried a CD into it yet. I’m wondering if there is any way to bring the volume down inside the unit itself. Change a part or two. Put a small pot somewhere as there are no adjustments at all in there. I’m looking for the schematic but not found one yet.
                Heres the circuit board inside.
                Cheers
                04-30-2024, 06:17 AM
