PPC install success at last
  • ivtec
    • Dec 2008
    • 1967
    Hi guys;got good news, i was able to install a PPC imac g5 from a Mini Debian 7.1( WEEZY)32bit Kernel Linux
    3.2.04-PowerPC64 Gerome .3.4.2. after almost giving up as i said i'm a hard ass and quit is not my thing may pacience is.
    Now i have a Dbian desktop and everything runs ok exept no flash player and id a litle slow it might be due low mem ram
  • japlytic
    DRIVER_PNP_WATCHDOG error re. old drivers in Windows 11 install image
    by japlytic
    In a Beelink GTR mini PC, mine has an Intel AX200NGW WLAN module.
    Tried (only with keyboard/mouse connected):
    • BIOS + database update
    • Using latest Windows 11 image built with official image creation tool
    • Previous setup version for Windows 11 installer
    • Replacing SSD without a slow block (the previous SSD had a slow block with access time > 500 mS)
    • TPM reset (worked to the point where DRIVER_PNP_WATCHDOG error message is displayed briefly after the point of stalling)
    • Disabling power to WLAN and LAN modules in BIOS (Advanced > AMD PBS > PCI Express Configuration)
    06-19-2025, 04:59 PM
  • 24gsm
    MacBook Pro A1708 install macos fail
    by 24gsm
    hi to all
    i have MacBook Pro (13-inch, 2017, Two Thunderbolt 3 ports)
    after enter to recovery and format hdd 1to .
    after try to install macos online . its frezz at loading install in boot and i waiting few hour but nothing i ty install by boot using flash disk but same issu
    can help please
    Serial Number: FVFXP0U0HV2J
    Config Code: HV2J
    Find My Mac: OFF
    04-16-2025, 03:57 AM
  • duwane
    A2141 (2019 16" MB Pro) Strange macOS install issues. NAND? WIFI? FIRMWARE?
    by duwane
    Hi All.
    Sorry ahead of time for the text wall. This is a strange problem and I have tried to explain it as best I can. I realise this is a hardware forum (mostly), but I am still not sure if this is even a hardware fault! I am hoping that someone more knowledgeable than me in the area of understanding installation logs, or someone that has had a similar issue in the past may have some ideas of what might be causing this.
    The issue:
    Unable to do a clean install of any macOS versions supported for this model, even after fully erasing and formatting the internal SSD,...
    10-26-2022, 07:02 AM
  • tommy97
    ASUS FA507R - BLOD, cannot install windows
    by tommy97
    I have an ASUS FA507R in for repair where I’m unable to install any operating system. The laptop works fine when booted from an external Windows or Linux drive, but any attempt to install on an NVMe SSD fails.
    I’ve already tested with three different SSDs (Gen 3 and older), and the issue persists. The laptop originally came in with a faulty SSD showing 0% health....
    08-22-2025, 07:55 AM
  • TrumanHW
    MacOS: R|W Programmers like CH341x BINs..?
    by TrumanHW
    For years I tried figuring out how to R|W BINs from my CH341x programmer.
    From FTDI's pkg, Apps specifically claiming they work, I failed for ~8 years.
    I'd expect many here figured it out (easily), but in case not ...
    It's one of the few forms of "how-to" remuneration I can GIVE BACK.
    This group is both GENEROUS & literally BRILLIANT / GENIUS!!!
    This may be the easiest means to copy-paste:
    Code:
    SERIAL -to- USB - CH341 ROM (MacOS):
    Install xcode:				xcode-select --install
    Relocate
    04-08-2022, 02:33 PM
