windows 8 key embedded in the bios of a windows 7 compaq presario cq57
  • goontron
    5000!
    • Dec 2011
    • 4108
    • US
    can i download windows 8 and use the key in the bios? i'm guessing this is because the laptop was made in 2012 just before the release of windows 8.
    Follow the white rabbit.
  • c_hegge
    • Sep 2009
    • 5219
    Re: windows 8 key embedded in the bios of a windows 7 compaq presario cq57
    If it originally came with 7, then no, it won't have a hate product key in the BIOS.
    • Uranium-235
      Comrade Glimmer
      • Aug 2007
      • 5042
      • US
      is the opposite ever true?
      • goontron
        5000!
        • Dec 2011
        • 4108
        • US
        well its written like an 8 key but it doesn't work and it doesn't seem to work with 7 either!
        • spleenharvester
          • Mar 2010
          • 903
          It's probably a SLP OEM key, if that's the case it will only work on a manufacturer's install disk (or one that's been modified).
          Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
          • Topcat
            The Boss Stooge
            • Oct 2003
            • 16958
            The Gods are looking out for you, because win8 didn't work...
            <--- Badcaps.net Founder
            Badcaps.net Services:
            Motherboard Repair Services
            http://folding.stanford.edu/
            Team : 49813
            Join in!!
            Team Stats
            • goontron
              5000!
              • Dec 2011
              • 4108
              • US
              oh shite!
              • Mad_Professor
                A Mech Warrior
                • Feb 2011
                • 1587
                Not true, you can use any Microsoft media disc, as long you know the OEM SLP Product key which can be obtain here.
                http://forums.mydigitallife.info/thr...Key-Collection
                http://www.digital-forums.com/showth...Key-Collection
                http://forums.mydigitallife.info/thr...a-OEM-SLP-keys
                or here, but it exports it out to a xml file.
                http://d-fault.nl/Keys.aspx
                But also you need SLP windows 8 slic table in the bios for it to work and links I posted above only work for vista or 7.
                • goontron
                  5000!
                  • Dec 2011
                  • 4108
                  • US
                  here is the MSDM table
                  Code:
                  MS Digital Marker Table: 0x00000000DFEDB000
                  4D 53 44 4D 55 00 00 00 03 97 48 50 20 20 20 20	MSDMU.....HP
                  49 4E 53 59 44 45 20 20 01 00 00 00 41 43 50 49	INSYDE ....ACPI
                  00 00 04 00 01 00 00 00 00 00 00 00 01 00 00 00	................
                  00 00 00 00 1D 00 00 00 42 48 33 52 4E 2D 42 37	........BH3RN-B7
                  46 44 4D 2D 43 37 57 47 54 2D 34 43 52 34 58 2D	FDM-C7WGT-4CR4X-
                  36 43 4B 48 4D                 	6CKHM
                  Signature	"MSDM"
                  Length	0x00000055 (85)
                  Revision	0x03 (3)
                  Checksum	0x97 (151)
                  OEM ID	"HP  "
                  OEM Table ID	"INSYDE "
                  OEM Revision	0x00000001 (1)
                  Creator ID	"ACPI"
                  Creator Revision	0x00040000 (262144)
                  Version	0x00000001 (1)
                  Reserved	0x00000000 (0)
                  Data Type	0x00000001 (1)
                  Data Reserved	0x00000000 (0)
                  Data Length	0x0000001D (29)
                  Data	BH3RN-B7FDM-C7WGT-4CR4X-6CKHM
                  and the SLIC table
                  Code:
                  Signature	"SLIC"
                  Length	0x00000176 (374)
                  Revision	0x01 (1)
                  Checksum	0x94 (148)
                  OEM ID	"HPQOEM"
                  OEM Table ID	"SLIC-MPC"
                  Creator ID	"ACPI"
                  OEM Public Key Structure
                   Type	0x00000000 (0)
                   Length	0x0000009C (156)
                   Key Type	0x06 (6)
                   Version	0x02 (2)
                   Reserved	0x0000 (0)
                   Algorithm	0x00002400 (9216)
                   Magic	"RSA1"
                   Bit Length	0x00000400 (1024)
                   Exponent	0x00010001 (65537)
                   Modulus	0x5B 0xAB 0x60 0x56 0xBC 0x58 0x1E 0xE8 0xC1 0xD2 0xA1 0x5C 0xE5 0x4F 0xBB 0xFD
                       	0x1D 0xA9 0x8C 0x94 0xB4 0xAE 0x08 0x11 0xDC 0x13 0x59 0xD3 0x7F 0xF6 0x3E 0x87
                       	0x31 0xB9 0x95 0x74 0x10 0xDA 0x3B 0xA4 0x5B 0xB5 0x19 0x82 0x7C 0x39 0xD7 0x0D
                       	0x7C 0x22 0xAC 0x1C 0x2A 0x84 0xE9 0x0A 0x88 0x6D 0xFA 0xB1 0xE2 0xD8 0xE8 0x21
                       	0x96 0xE1 0x2E 0x68 0x9A 0xBF 0x44 0x45 0x3E 0x3C 0x8E 0x99 0x90 0xDE 0x37 0x38
                       	0x57 0x0B 0x92 0x15 0xBC 0xDE 0xFF 0xF2 0x07 0x7E 0xB5 0x40 0x8C 0x51 0x3A 0xC3
                       	0x02 0x48 0xF6 0x13 0x12 0x72 0xFB 0x42 0x78 0xE6 0x47 0x88 0x54 0xC7 0xB0 0xF0
                       	0x93 0x9E 0xFB 0x04 0xB7 0xB8 0xB8 0x90 0xDE 0xDB 0xED 0x32 0xE1 0xFB 0x54 0xA6
                  SLIC Marker Structure
                   Type	0x00000001 (1)
                   Length	0x000000B6 (182)
                   Version	0x00020000 (131072)
                   OEM ID	"HPQOEM"
                   Windows Flag	"WINDOWS "
                   SLIC Ver	0x00020001 (v2.1)
                   Reserved	0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
                   Signature	0x30 0x90 0x1F 0xB4 0xA4 0xBE 0x80 0x1E 0xE9 0x33 0xEC 0x7F 0xFC 0xB1 0x28 0x0E
                        	0xA6 0xCE 0x43 0x72 0x8C 0x79 0x30 0xB4 0xF4 0x59 0xEA 0x7D 0xCF 0xB7 0x11 0x8B
                        	0xDA 0x70 0xC5 0xC8 0x3F 0x79 0x20 0x08 0x6F 0x64 0xCA 0x07 0x88 0xB3 0xB1 0x16
                        	0xB4 0xBA 0x1A 0xF1 0x85 0x52 0xB1 0xF5 0x07 0x55 0xB5 0x70 0x61 0xEF 0x44 0x8C
                        	0xAA 0x5F 0x78 0x14 0x66 0x98 0x9C 0xF3 0x58 0xD8 0xAA 0x48 0xE0 0x37 0xF8 0xF6
                        	0xAB 0x64 0xFA 0xDA 0x17 0x2A 0x62 0xE3 0x04 0x1D 0x32 0x2D 0xD5 0xEA 0x33 0x66
                        	0x5C 0x5B 0x3B 0x0E 0xF7 0x09 0x66 0x42 0x32 0xAA 0x14 0x99 0xC3 0xEE 0x1A 0x62
                        	0x3B 0x07 0x5F 0xF0 0x48 0x44 0xC4 0xE6 0x32 0x59 0x1F 0x14 0x3E 0xF1 0xB2 0x38
                  is it windows 8 capable?
                  • Mad_Professor
                    A Mech Warrior
                    • Feb 2011
                    • 1587
                    Code:
                    Signature	"MSDM"
                    Revision	0x03 (3)
                    Checksum	0x97 (151)
                    OEM ID	"HP  "
                    Creator ID	"ACPI"
                    and the SLIC table
                    Code:
                    Signature	"SLIC"
                    Revision	0x01 (1)
                    Checksum	0x94 (148)
                    OEM ID	"HPQOEM"
                    Creator ID	"ACPI"
                     Type	0x00000000 (0)
                     Key Type	0x06 (6)
                     Version	0x02 (2)
                     Reserved	0x0000 (0)
                     Magic	"RSA1"
                     Type	0x00000001 (1)
                     OEM ID	"HPQOEM"
                    Is this from your laptop?
                    It looks like it already has msdm and the slic in it, technically your "BH3RN-B7FDM-C7WGT-4CR4X-6CKHM" Might be the key for windows 8.
                    EDIT: looks to be a dummy key, it was found in 6 different HPs, a Dell and acer.
                    http://forums.mydigitallife.info/thr...ed-UEFI/page56
                    http://forums.mydigitallife.info/pri...0&pp=10&page=5
                    • goontron
                      5000!
                      • Dec 2011
                      • 4108
                      • US
                      its a dummy key that exists in compaq to damn it!
                      • sofTest
                        • Aug 2008
                        • 361
                        If the SLIC table says ver. 2.1, as yours do, it's licensed for Win7.
                        Be a mensch
                          HP Compaq Presario CQ57 Laptop Schematic
                          HP Compaq Presario CQ57 Laptop Schematic...
                          10-14-2024, 06:38 AM
                          HP Compaq Presario CQ57-497SG CQ57 Specification for Upgrade or Repair
                          This specification for the HP Compaq Presario CQ57-497SG can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the CQ57-497SG boardview and CQ57-497SG schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP...
                          09-06-2024, 05:27 AM
                          HP Compaq Compaq SG3-240ES Compaq SG3 220 Specification for Upgrade or Repair
                          This specification for the HP Compaq Compaq SG3-240ES can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Compaq SG3-240ES boardview and Compaq Compaq SG3-240ES schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                          09-12-2024, 03:44 PM
                          HP Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) Compaq Elite 8000 E5500 Specification for Upgrade or Repair
                          This specification for the HP Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) boardview and Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request...
                          HP Compaq Compaq dc7900 Compaq Q9400 Specification for Upgrade or Repair
                          This specification for the HP Compaq Compaq dc7900 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Compaq dc7900 boardview and Compaq Compaq dc7900 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                          09-12-2024, 03:30 PM
