can i download windows 8 and use the key in the bios? i'm guessing this is because the laptop was made in 2012 just before the release of windows 8.
windows 8 key embedded in the bios of a windows 7 compaq presario cq57
Follow the white rabbit.Tags: None -
Re: windows 8 key embedded in the bios of a windows 7 compaq presario cq57
If it originally came with 7, then no, it won't have a hate product key in the BIOS.I love putting bad caps and flat batteries in fire and watching them explode!!
Office PC: HP ProLiant ML150 G3, 2x Xeon E5335 2GHz, 4GB DDR2 RAM, 120GB Intel 530 SSD, 2x 250GB HDD, 2x 450GB 15K SAS HDD in RAID 1, 1x 2TB HDD, nVidia 8400GS, Delta DPS-650BB 650W PSU, Windows 7 Pro -
is the opposite ever true?Cap Datasheet Depot: http://www.paullinebarger.net/DS/
^If you have datasheets not listed PM meComment
well its written like an 8 key but it doesn't work
and it doesn't seem to work with 7 either!
Follow the white rabbit.Comment
It's probably a SLP OEM key, if that's the case it will only work on a manufacturer's install disk (or one that's been modified).Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSDComment
The Gods are looking out for you, because win8 didn't work...
<--- Badcaps.net Founder
Badcaps.net Services:
Motherboard Repair Services
http://folding.stanford.edu/
Team : 49813
Join in!!
Team StatsComment
Not true, you can use any Microsoft media disc, as long you know the OEM SLP Product key which can be obtain here.
http://forums.mydigitallife.info/thr...Key-Collection
http://www.digital-forums.com/showth...Key-Collection
http://forums.mydigitallife.info/thr...a-OEM-SLP-keys
or here, but it exports it out to a xml file.
http://d-fault.nl/Keys.aspx
But also you need SLP windows 8 slic table in the bios for it to work and links I posted above only work for vista or 7.Last edited by Mad_Professor; 08-08-2013, 04:57 PM.Comment
here is the MSDM table
and the SLIC tableCode:MS Digital Marker Table: 0x00000000DFEDB000 4D 53 44 4D 55 00 00 00 03 97 48 50 20 20 20 20 MSDMU.....HP 49 4E 53 59 44 45 20 20 01 00 00 00 41 43 50 49 INSYDE ....ACPI 00 00 04 00 01 00 00 00 00 00 00 00 01 00 00 00 ................ 00 00 00 00 1D 00 00 00 42 48 33 52 4E 2D 42 37 ........BH3RN-B7 46 44 4D 2D 43 37 57 47 54 2D 34 43 52 34 58 2D FDM-C7WGT-4CR4X- 36 43 4B 48 4D 6CKHM Signature "MSDM" Length 0x00000055 (85) Revision 0x03 (3) Checksum 0x97 (151) OEM ID "HP " OEM Table ID "INSYDE " OEM Revision 0x00000001 (1) Creator ID "ACPI" Creator Revision 0x00040000 (262144) Version 0x00000001 (1) Reserved 0x00000000 (0) Data Type 0x00000001 (1) Data Reserved 0x00000000 (0) Data Length 0x0000001D (29) Data BH3RN-B7FDM-C7WGT-4CR4X-6CKHM
is it windows 8 capable?Code:Signature "SLIC" Length 0x00000176 (374) Revision 0x01 (1) Checksum 0x94 (148) OEM ID "HPQOEM" OEM Table ID "SLIC-MPC" OEM Revision 0x00000001 (1) Creator ID "ACPI" Creator Revision 0x00040000 (262144) OEM Public Key Structure Type 0x00000000 (0) Length 0x0000009C (156) Key Type 0x06 (6) Version 0x02 (2) Reserved 0x0000 (0) Algorithm 0x00002400 (9216) Magic "RSA1" Bit Length 0x00000400 (1024) Exponent 0x00010001 (65537) Modulus 0x5B 0xAB 0x60 0x56 0xBC 0x58 0x1E 0xE8 0xC1 0xD2 0xA1 0x5C 0xE5 0x4F 0xBB 0xFD 0x1D 0xA9 0x8C 0x94 0xB4 0xAE 0x08 0x11 0xDC 0x13 0x59 0xD3 0x7F 0xF6 0x3E 0x87 0x31 0xB9 0x95 0x74 0x10 0xDA 0x3B 0xA4 0x5B 0xB5 0x19 0x82 0x7C 0x39 0xD7 0x0D 0x7C 0x22 0xAC 0x1C 0x2A 0x84 0xE9 0x0A 0x88 0x6D 0xFA 0xB1 0xE2 0xD8 0xE8 0x21 0x96 0xE1 0x2E 0x68 0x9A 0xBF 0x44 0x45 0x3E 0x3C 0x8E 0x99 0x90 0xDE 0x37 0x38 0x57 0x0B 0x92 0x15 0xBC 0xDE 0xFF 0xF2 0x07 0x7E 0xB5 0x40 0x8C 0x51 0x3A 0xC3 0x02 0x48 0xF6 0x13 0x12 0x72 0xFB 0x42 0x78 0xE6 0x47 0x88 0x54 0xC7 0xB0 0xF0 0x93 0x9E 0xFB 0x04 0xB7 0xB8 0xB8 0x90 0xDE 0xDB 0xED 0x32 0xE1 0xFB 0x54 0xA6 SLIC Marker Structure Type 0x00000001 (1) Length 0x000000B6 (182) Version 0x00020000 (131072) OEM ID "HPQOEM" OEM Table ID "SLIC-MPC" Windows Flag "WINDOWS " SLIC Ver 0x00020001 (v2.1) Reserved 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 Signature 0x30 0x90 0x1F 0xB4 0xA4 0xBE 0x80 0x1E 0xE9 0x33 0xEC 0x7F 0xFC 0xB1 0x28 0x0E 0xA6 0xCE 0x43 0x72 0x8C 0x79 0x30 0xB4 0xF4 0x59 0xEA 0x7D 0xCF 0xB7 0x11 0x8B 0xDA 0x70 0xC5 0xC8 0x3F 0x79 0x20 0x08 0x6F 0x64 0xCA 0x07 0x88 0xB3 0xB1 0x16 0xB4 0xBA 0x1A 0xF1 0x85 0x52 0xB1 0xF5 0x07 0x55 0xB5 0x70 0x61 0xEF 0x44 0x8C 0xAA 0x5F 0x78 0x14 0x66 0x98 0x9C 0xF3 0x58 0xD8 0xAA 0x48 0xE0 0x37 0xF8 0xF6 0xAB 0x64 0xFA 0xDA 0x17 0x2A 0x62 0xE3 0x04 0x1D 0x32 0x2D 0xD5 0xEA 0x33 0x66 0x5C 0x5B 0x3B 0x0E 0xF7 0x09 0x66 0x42 0x32 0xAA 0x14 0x99 0xC3 0xEE 0x1A 0x62 0x3B 0x07 0x5F 0xF0 0x48 0x44 0xC4 0xE6 0x32 0x59 0x1F 0x14 0x3E 0xF1 0xB2 0x38Things I've fixed: anything from semis to crappy Chinese $2 radios, and now an IoT Dildo....
Is this from your laptop?here is the MSDM table
It looks like it already has msdm and the slic in it, technically your "BH3RN-B7FDM-C7WGT-4CR4X-6CKHM" Might be the key for windows 8.
EDIT: looks to be a dummy key, it was found in 6 different HPs, a Dell and acer.
http://forums.mydigitallife.info/thr...ed-UEFI/page56
http://forums.mydigitallife.info/pri...0&pp=10&page=5Last edited by Mad_Professor; 08-08-2013, 06:41 PM.Comment
its a dummy key that exists in compaq toIs this from your laptop?
damn it!
This specification for the HP Compaq Presario CQ57-497SG can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the CQ57-497SG boardview and CQ57-497SG schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP...09-06-2024, 05:27 AM
This specification for the HP Compaq Compaq SG3-240ES can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Compaq SG3-240ES boardview and Compaq Compaq SG3-240ES schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...09-12-2024, 03:44 PM
This specification for the HP Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) boardview and Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request...09-12-2024, 03:44 PM
This specification for the HP Compaq Compaq dc7900 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Compaq dc7900 boardview and Compaq Compaq dc7900 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...09-12-2024, 03:30 PM
- Loading...
