Mirror monitors help
  • ivtec
    • Dec 2008
    • 1967
    Hi guys:i installed xubuntu on my old vaio and i like it very much,so i also installed it on my desktop with Intel hd card,i can get 1920x1080 60hz on VGA monitor but i can't get it to mirror to my Sony HD TV 1920x1080 30HZ,i get a blank screan all the time,
    i got this info you guys know if i install this i will be able to overcome this problem? thanks
    http://www.webupd8.org/2012/11/insta...upport-in.html
  • BigOof
    Pioneer RM-07 Active monitors cutting out from time to time
    by BigOof
    I have a pair of Pioneer RM-07 monitors that I bought a while ago. When I was testing them I noticed that one speaker would cut out and I thought it was just a bad cable connection. At the price they were being sold for I was willing to take a risk on them. However, 6 months later and the one monitor still has the same issue. Most of the time it works, but there are times that the power LED is on but I get absolutely no sound. I can hear the relay clicking on/off sometimes and then it will/won't work depending on what it feels like. I've tried XLR and RCA inputs with the same issue. There's no...
    12-18-2024, 04:35 AM
  • pavithra_uk
    HP CP1025 faded mirror
    by pavithra_uk
    This is what happened to 45 degree angled mirror of laser assembly. mirror surface coating is almost completely etched away.
    what can be the possible solution for this?
    Printer - HP colour laserjet CP1025
    Symptoms - faded printouts...
    11-09-2022, 10:38 AM
  • buchman
    How to connect 6 monitors to a PC?
    by buchman
    I built an AMD PC and I have GTX 1070ti graphics card with only 4 outputs to 4 monitors, I want to connect 2-3 more monitors, what are the cheapest options do I have?
    Thanks in advance.
    03-27-2021, 09:29 AM
  • rui4892
    panasonic TX-47AS650E solarized and mirror image after change mainboard.
    by rui4892
    hello everybody.
    my previous post disappeared, perhaps due to the server transition... but let's move on...
    I bought a similar board on ebay but this one is programmed for the 48FHD panel, my panel is 47FHD... in the service manual I can't find information on how to change it... or what to change... thank you.​
    11-27-2023, 04:48 AM
  • capsulej
    Dell 2007FP monitors
    by capsulej
    I have a bunch of these monitors that all seem to have the same issue with bad inverter boards. Either the monitor will power on and not display a picture or it will display a picture for 2 seconds and then shut off. I know this because swapping the boards out with a working unit fixes the problem.
    Apparently this is caused by the dell soundbars overloading the monitors power rails as they are of poor quality. I would like to fix the boards if possible but im not sure what to look for.
    https://imgur.com/a/yH12ti3
    10-15-2019, 09:04 PM
