E-POS E-880 Series: Bios Needed
  • speedypro
    • Feb 2013
    • 561
    Can anyone source me the bios for this e-pos system? Name on MM: AM880-900. Name in bios: Phoenix BIOS E686 and number: 243716081. Bios chip is damaged.
    Full-time computer repair tech (10am - 6pm) and full-time, (8am - 11pm), Ruby on Rails Developer
  • Ami Sapphire
    Extreme Lurker
    • Sep 2010
    • 180
    Re: E-POS E-880 Series: Bios Needed
    Okay, I keep running into the AmazePC AM880.
    Recovering a BEFSR41 v1 and v2 router from solid red DIAG Light
    I have two v2s and one v1.
    I am still looking at these boards nearly every day.
    What I'm doing: Planning an upgrade of my mining setup from Block Erupters to Red Furys. Though, if the Block Erupters don't sell, I will keep using them for a while.
    • speedypro
      • Feb 2013
      • 561
      You removed the download link, why? Anyways, I need the chip also, who do you know sells them?
      • Ami Sapphire
        Extreme Lurker
        • Sep 2010
        • 180
        I also ran into a mini POS that went by 880, lol. Threw me off, though. Here's the old text, for future reference:
        The AM880. Either versions: 1.2, 1.3, 2.0
        Found them through here: http://www.helpdrivers.com/desktops/Amazepc/AM880/
        Downloaded them and put them on my server: http://cwcyrix.no-ip.info/am880-bios
        Man, it was tricky finding these BIOS files. But that's what I do.
        Also attached these files, since that didn't cross my mind then, either.
        I was wondering why the number never surfaced in any search. You mentioned the serial number. The actual BIOS chip part number would be mentioned under the sticker... unless they actually removed that from the chip. I'm thinking it's a PLCC-32 flash chip, though.
        • tlindi
          Toughbook CF-18KHH65LE (Customer Special Configuration) Supervisor Password needed remove HDD locking and BIOS Access ...
          by tlindi
          Sublect line continuation: ... Jaguar IDS PC aka Panasonic
          >Read BIOS guides, methods, resources and tools
          Ack
          >Try the method at BIOS guides, methods, resources and tools before requesting help
          Ack
          >Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
          python ./main.py "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.BIN" --output-dir "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.txt"
          01-30-2025, 04:26 AM
        • macabook
          by macabook
          🧩 Initial Issue
          07-24-2025, 02:17 PM
        • techlab
          HP Elite Dragonfly Bios Crashed - HELP NEEDED
          by techlab
          Hi Guys,
          Looking for some help with an HP Elite Dragonfly.
          The customer explained it was updating the BIOS, the flashing completed, but afterwards the laptop wouldn’t power back on.
          • The laptop has no power but does take the correct voltage.
          • It shows 5 flashes white/amber, which indicates a BIOS issue.
          • I backed up the original BIOS to extract the feature byte etc.
          • I then flashed the BIOS with a clean version from HP’s website, but the laptop still gives 5 white/amber flashes.
          Just wanted to pick your brains on this — has anyone come across this before or...
          Today, 05:29 AM
        • TacticalFahrrad
          [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
          by TacticalFahrrad
          I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
          06-30-2025, 04:09 AM
        • jbonavita
          by jbonavita
          Some issues
          Things I tried
          04-29-2025, 09:38 PM
