optical drive laser failure if not used for a long time?
  • ChaosLegionnaire
    HC Overclocker
    • Jul 2012
    • 3266
    • Singapore
    i have an lg dvd burner, a gsa h10n. been using it for a long period (one year) to read dvds only. then one fine day when i popped in a cd to do system backup and recovery, i found out that it could not read or detect whatever cd i put in the drive but when i put in a dvd, it works fine.
    my question is what can cause the cd reading laser to fail if its not used for a long time? that xbox laser failure and burning 24 dvds topic prompted me to start this thread here to ask this.
    it cannot be a dusty cd reading laser, can it? that would affect the dvd laser as well, wont it? i tried using one of those cd/dvd cleaning discs but no dice... i suppose they dont really work and are just marketing gimmicks...
    looks like i have to get down to replacing the laser assembly too... its an old ide dvd drive so cant buy a new one as they're all sata...
  • cheapie
    null
    • Jul 2010
    • 849
    Re: optical drive laser failure if not used for a long time?
    The CD laser is used for a second or two when the tray is closed to determine if a CD is present.
    Your motherboard doesn't have a SATA controller?
      master hoarder
      • May 2008
      • 12175
      Don't know for sure, but I'd say it's a possibility. You would have to take apart the whole laser assembly, though. If it still doesn't work, maybe try a new CD laser.
      Probably. Seeing how they don't touch the lens (if they did, that would be a disaster, wouldn't it), I don't think they really do anything either.
      • cheapie
        null
        • Jul 2010
        • 849
        They do touch the lens. They have brushes on the bottom. I clean laser lenses with cotton swabs all the time. They don't explode or anything.
        • OscarAV
          HP Pavilion dm4-1065dx long time to get the power led on
          by OscarAV
          I just came here to see if someone has had the same problem I have, and if he or she solved It, to know how to do It.
          I have made a quick search for my laptop but I have not seen anything similar.
          I have an old laptop, an HP Pavilion dm4-1065dx which takes a lot of time to be ready to start if the laptop has been unplugged for a while. It has no battery. The battery failed long time ago. It needs to be plugged to work. But as I said, It can take a lot of time until the charging led gets on, and I can switch on the laptop. I am using an external monitor...
          09-23-2024, 05:53 PM
        • npielawski
          MacBook Pro late 2016 (820-00239) with multiple failure modes.
          by npielawski
          I will just preface all this by saying that I have a fairly technical background but have never attempted SMD electronics diagnostics and repair before, I really like the idea and want to learn.
          I have a MacBook Pro late 2016 that died maybe four years ago. Over the course of 30 seconds, it got slower and stuttered, until it froze for a second and died. No click from the trackpad anymore, nothing. I started getting interested in electronics repair and decided to give it a shot, so I opened it, removed the battery (one cell was puffy), took out the motherboard and experimented with...
          10-15-2025, 01:53 AM
        • EvazX
          ASUS ROG G513QY – RX 6800M powered but not detected intermittently + random crashes (Motherboard: 6050A3254002-MB-Axx)
          by EvazX
          I am working on an ASUS ROG G513QY laptop with RX 6800M dGPU.
          Originally, this laptop was completely non-functional. I replaced the motherboard (part number 6050A3254002-MB-Axx), and with the replacement board it started working fine.
          For a long time, the dGPU worked perfectly stable. I played several hundred hours on very demanding games such as Cyberpunk 2077 without any crashes, instability, or detection issues. Performance was excellent and there were no warning signs of failure.
          However, after some time, the replacement motherboard...
          08-25-2025, 06:09 PM
        • jagg
          Laptop MSI-16k5 Board model MS-16k51 V1.1 takes a long time to send video
          by jagg
          Hello, the laptop It turns on and off several times, it takes a long time to send video, possibly it is bios?
          Here are the bios and the schematics.
          Could someone help me verify that the bios is correct? thank you so much !!...
          11-22-2023, 03:36 PM
        • sew333
          Light bulb flicker when turning on after long time off.
          by sew333
          Hello. I have question. I dont know if i have faulty wiring,bad installation or its bulb. When i have lights off long time and turn on lightning ( bulb halogen ) , there is a for 2-3 second bulb dimm/flicker and its normal. Happens only when lightning is off long time and i turn on.
          When i turn off lights and turn on again its fine. That flicker/dimm happens only when lights are off long time.
          That happens for example if i have lights off 2-3 hours and turn on.
          Thx
          02-16-2021, 01:39 PM
