Acer Z5710 issue
  • stevo1210
    • Oct 2006
    • 4156
    Acer Z5710 issue
    I've got this very awesome all-in-one Acer Z5710 desktop. Worked fine until a few hours ago. I was just browsing the net and it kept giving me BSODs and saying DRIVER_WHQL error or something like that under Windows 7. I found it to be a bit odd as this computer has never, ever done that to me. Then it kept boot looping/restarting every time Windows was at the loading screen until after a few attempts it made it to the desktop and then would BSOD and restart...which I found really odd.
    Finally it got into Windows desktop again (like the 5th time now) and it worked for maybe 5 minutes? Then I got another BSOD and instead of restarting it turned off pitch black/dead.
    Now when I try to switch it back on, it comes on for a second or two and switches off.
    Sadly, all my data is on this PC so I will have to remove the HDD tomorrow and do diagnostics work.
    So with the experience of every one here... what the hell could be wrong with my computer? I am thinking either the PSU has crapped out or my motherboard has called it quits.
    Parts aren't too expensive according to eBay AU but just a bit annoyed I have more shit to deal with now... and just to add, I haven't tampered with it since the day I got it... its been unopen!
  • Heihachi_73
    • Jun 2012
    • 713
    Re: Acer Z5710 issue
    It's an Acer. Chances are you'll find a ton of crapped-out Teapo caps in the PSU like the two Acer desktops I have (both lasted 6-7 years before failing to boot however, and in both cases, the m/b was fine and only needed a new PSU).
    • Time2Retire
      • Aug 2012
      • 256
      It's windows. Chances are you have a crappy operating system.
      • cheapie
        null
        • Jul 2010
        • 849
        That wouldn't make it fail to stay running for more than a second...
        • luke10050
          • Mar 2013
          • 209
          my first thoughts were graphics, but i guess unclean power could do that too
          • Time2Retire
            • Aug 2012
            • 256
            I was being (semi) sarcastic.
            • stevo1210
              • Oct 2006
              • 4156
              Tested with another known working 24 pin ATX power supply, did the same thing... turns on for a few seconds and off. Remove the RAM and all it does is beep... however it will stay on. Put a single RAM stick in again and it does the 1 second on thing again.
              Can I safely confirm it's the motherboard before spending $$$ on a new board? ($149 for board... computer is worth $800 RRP).
              • Elysarian
                • Mar 2013
                • 200
                removing the RAM isn't really a test (it'll fail to POST), you need to substitute a known good stick in there to test properly.
                I'd also check the mobo for bloaty caps.
                • thesloc
                  Banned
                  • Dec 2011
                  • 587
                  Why does everyone here immediately blame hardware before software?
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    Because it's a hardware forum and crap is so poorly built these days.
                    sigpic
                    (Insert witty quote here)
                    • Uranium-235
                      Comrade Glimmer
                      • Aug 2007
                      • 5042
                      • US
                      in this case, if you read the OP and saw:
                      "Now when I try to switch it back on, it comes on for a second or two and switches off."
                      thats pretty much why in this case, i'm going with hardware
                      yeah sounds like MB or PSU. Try a known working PSU
                      • stevo1210
                        • Oct 2006
                        • 4156
                        Well... probably should have read this earlier LOL.
                        There are four sticks in there... 1 was faulty. I ended up removing the RAM as stated earlier and then re-inserting the single faulty one where it did the on-off sequence and so I came to the "dead motherboard" conclusion as seen above.
                        I was a bit bored and restless so I decided to experiment with another 1 of the 4 sticks and it booted right up! Seems like faulty RAM all along. LOL.
                        Time for my computer to be put back on the table and back into service.
                        • Mirenia
                          Acer Helios 500 (PH517-51) - unexpected reboots when laptop is warm (cold solder joint issue?)
                          by Mirenia
                          got an Acer Helios 500 Laptop (PH517-51) for diagnosing with a strange issue:
                          The laptop runs for a while (1-2 hours, sometimes less) and then suddenly shuts completely off, like someone pulled the power cord and restarts immediately after on its own.
                          If this happened once, then the laptop only runs for a few minutes until restart.
                          This happens regardless while staying in windows or uefi or in a linux environment.
                          At first I thought of a normal overheating issue, but as I monitored temps with HWInfo64, nothing seems very hot.
                          01-05-2025, 05:15 PM
                          09-06-2024, 05:27 AM
                          Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                          This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                          09-07-2024, 05:00 AM
                          Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook 3 Specification for Upgrade or Repair
                          This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                          Acer Nitro Acer Nitro 5 Black Notebook 5 Specification for Upgrade or Repair
                          This specification for the Acer Nitro Acer Nitro 5 Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 Black boardview and Acer Nitro 5 Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                          09-07-2024, 04:10 AM
