Silicon Image 3112 + windows 7 = fail?
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Problem: I'm trying to use one of my Supermicro X5DAL-tg2's Silicon Image 3112 SATA150 controllers with a WD caviar blue 320gb... and after installing the driver (the OS is already installed on an 80gb PATA), I've had no luck at all getting the drive to intialize (always returns "incorrect function", even using diskpart at the cmd line). I've tried forcing the drive to SATA 150... and I'm 95% sure the drive's in good shape (it was sitting on a shelf in a partial built until today).
    Anybody else have bad luck with This controller (or the 3114 4 port version)? Or is it just me?
    Edit- Even for a single drive, I wish I had a spare working 3ware card for this thing...
    sigpic
    (Insert witty quote here)
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16958
    Re: Silicon Image 3112 + windows 7 = fail?
    its not just you. theres a reason I always disabled those controllers and used PCI ones. Horrible controllers, horrible drivers, and horrible performance.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      Yeah. Come to think of it, IIRC Shovenose had the same thing happen with the 3114 chip on his Tyan S2885 (same chip, only with 4 ports).
      It will wait then... until I get my next project built and a home for my tuner card made (it's occupying the slot where there used to be PCI-x 3ware card).
      sigpic
      • brethin
        • Dec 2008
        • 1907
        Thats one old ass controller to try and use with windows 7 but hey more power to ya for trying it. I used one with Windows XP x64 for several years and it worked fine but since its like 12 years old it would be a mirical if it worked with windows 7.
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          Well, it's built into the board... and silicon image had a chip specific 7 driver (and just for 7)... so I would have thought it would work.
          Idea: I may be able to put it in RAID mode (in the board's main BIOS), use the RAID driver (as oppossed to the non-RAID base driver), and set the drive in firmware (secondary BIOS) as a single drive. Kinda back to front, yes, but it may be what I gotta do... I know that will nuke SMART monitoring (since the computer will see a silicon image drive, not a WD HDD), but perhaps that's what's called for.
          sigpic
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            Drive is indeed dead... I/O errors while using a PATA to SATA converter, and also on a system with intel SATA (HP D530).
            RMA'ing the drive...
            sigpic
            • goontron
              5000!
              • Dec 2011
              • 4108
              • US
              ouch, how big was the drive?
              is it just the GNU/BSD-er inside me or does windows 7 not seem to work worth a damn with hardware older than 2009?
              Follow the white rabbit.
              • ddscentral
                • Mar 2008
                • 151
                • Lithuania, EU
                Never had a problem with older hardware on Windows 7.
                Windows 7 even takes some XP drivers .
                The oldest driver which I've installed on 7 was a driver for onboard Intel video, last updated in 2003.
                • ratdude747
                  Black Sheep
                  • Nov 2008
                  • 17136
                  320gb. WD3200AAKS
                  Nah, win 7 works with 95% of my stuff.
                  sigpic
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    replacement HDD came in a few days ago. Tried using the silicon image chip, worked great... a disk cloning later and all is well. For the past few days no hiccups or anything... actually this drive seems pretty snappy.
                    So to answer the title, no, Silicon image + windows 7 ≠ fail, but rather, any disk controller + a dead drive = EPIC fail .
                    sigpic
                    • goontron
                      5000!
                      • Dec 2011
                      • 4108
                      • US
                      lol. we have all had those days mate
                      • Sus256
                        HISENSE 65E7KQ PRO - no boot
                        by Sus256
                        Hi all!
                        HISENSE 65E7KQ PRO
                        RSAG7.820.13512 - chassis
                        MT9618BAATAB - cpu
                        RSAG7.820.12059 - power
                        HD650Y3U77 - panel
                        KLM8G1GETF - emmc
                        The TV does not turn on, the standby indicator is on. All voltages are present.
                        Emms is dead. Not readable, not detected.
                        Replaced emmc.
                        But with another dump there is no launch
                        Terminal log
                        UART
                        AC_ON
                        RPMB key is not yet programmed
                        HASH1_VERSION=0x00000000 64bit
                        E-B
                        FDE enabled
                        layout pattern onebin by SAR7,0...
                        06-01-2025, 02:11 AM
                        HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                        This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                        09-12-2024, 02:20 PM
                      • Jaime Morillo
                        Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                        by Jaime Morillo
                        Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                        The TV was stuck on the logo and I couldn't access the update menu.
                        I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                        The image result was good, but the image is inverted.
                        The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                        Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                        08-18-2025, 11:38 AM
                      • dragometin
                        Hitachi 40HYC42
                        by dragometin
                        TV Model: Hitachi 40HYC42
                        Power Supply: 17IPS71
                        MainBoard: 17MB95M
                        Panel: VES400UNDS-2D-NO3
                        When the set came in it was dead. Fuse was open primary side and the power mosfet was shorted. So I ordered a new power supply. Now it turns on, only displays "Hitachi" and then power off red and blue led flashing.
                        I had to modify the 0ohm resistors in the led backlight of the new PS like the original power supply.
                        Is there any variants on 17IPS71 power supply's?
                        UART output pins 10 and 12 on scart connector:
                        Code:
                        12:24:04.595
                        08-08-2024, 05:53 AM
                        HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook 400 Specification for Upgrade or Repair
                        This specification for the HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load, Asset Tag & Testntag boardview and 450 G6 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                        09-06-2024, 10:56 AM
