Listen to this.... i think my F-USB is BUST!!!!
  • Rainbow
    • Aug 2005
    • 1373
    Re: Listen to this.... i think my F-USB is BUST!!!!
    Memory inserted backwards results usually in a blown MOSFET and/or a diode in memory/chipset power circuit.
    • stevo1210
      • Oct 2006
      • 4156
      When i measure this 5V lines, does my PC have to be ON or OFF? and whats measuring the 5V line help in this case?
      Thanks.
      Don't find love, let love find you. That's why its called falling in love, because you don't force yourself to fall, you just fall. - Anonymous
      • ifrythings
        • Apr 2006
        • 19
        The Pc should be on when you measure the 5V line.
        The purpose of this test is to determine if a part that feeds the 5V line to your usb died somewhere down the line.
        • stevo1210
          • Oct 2006
          • 4156
          Thanks ifrythings for the advice,
          I was wondering on what to do if there isn't a 5V line present when measured.
          I'm going to get a professional to measure the 5V lines just to be sure i guess.... i just dont want to blow anything up in the process of checking.
          I hope it isn't going to be too expensive to repair what smoked the other day.
          Thanks.
          • stevo1210
            • Oct 2006
            • 4156
            Now it won't even detect my DVD drive anymore.... wires are all plugged in properly.... jumpers on the drives are set correctly.... I went to turn it on this morning and my Creative DXR2 DVD drive won't be detected.
            Now i'm starting to really hate this board.... sometimes it powers but refuses to POST?!
            I'm going to look for a new board now.... probably an Asrock P4i65G i guess, since it's cheap and probably reliable....
            • shelby5041
              old trs80 computer lots of smoke
              by shelby5041
              hi
              my neighbor gave me an old radio shack trs80 model3 computer...it was stored in his attic for 35yrs...i powered it on and after 5min lots of smoke was coming out of computer...i took it apart and didnt notice any fire evidence so i assume a cap split open...i looked around only saw 1 suspect part...see photo...could this be the smoke?
              07-14-2024, 05:11 PM
            • Bubbsy 2002
              Kiddie smoke alarm (120v with 9v battery backup) experienced 180v power surge (Newfoundland Power company).
              by Bubbsy 2002
              Hi to all, I was diagnosing 2 smoke detectors that experienced power surge. I opened one up and found a weird fuse/resistor, which now has open circuit. I can't find this part.
              Forgot to mention they both light up and I believe the test function works, but when I put smoke to them no alarm!
              Any help in this regard would be greatly appreciated.
              Thanks,...
              01-02-2024, 09:11 AM
            • Behemot
              High-ambient-temp smoke sensor recommendation
              by Behemot
              Not sure if this is the best section, so feel free to move it. I'm tasked to get some "safety device" in case something goes wrong to insure a dry sauna does not burn again. This time the wall with stove on it has been covered with mineral insulation material as well as linings. (Harvia states their stove can be mounted directly on wooden walls! get that! ).
              Idiots wired extra (UTP, get that second time ) cable to the sauna ceiling. Is there ANY smoke detector which could survive on the ceiling with up to 100 (120?) °C there, or just all those house toys...
              10-14-2023, 12:12 PM
            • cnti
              Samsung 245B PLUS - BN44-00195A - bang and smoke - solved - tips
              by cnti
              Hi.
              BacCaps forum is awesome - thank YOU ALL for sharing knowledge!
              This is about DONG YANG PSU BN44-00195A failiure in Samsung 245BPLUS. It started with bang and smoke from the back of LCD. Downloaded diagram BM44-00192A - a bit different but I will use all parts names from this diagram [and real PSU].
              BIG CAP CP801 had 315V, on standby pin 5,2V. After shorting S_B ON (through 3,3k ohm resistor) 24V and 5,3V were missing, on CP801 was 312V.
              RM801 [real PSU: RM801 - 0,22 ohm 1W] - FAIL
              burned, measured 10M ohm.
              QM801 [real PSU:...
              10-19-2023, 05:33 PM
            • jaifraic
              Allen & Heath Xone:92 (DJ mixer) no output on main out & magic smoke
              by jaifraic
              I have a DJ mixer here, an Xone:92 by Allen & Heath.
              When I turned it on, only magic smoke came out, so I turned it off again.
              An optical troubleshooting has brought me quite fast to the
              source of the smoke: two resistors look disproportionately black (see first pic)
              Those are R73 and R74 on the master PCB. See second pic for the corresponding page of the service manual.
              Behind those resistors are five OP-Amps (U3, U4, U5, U6 and U9).
              My thought is that one (or more) of those is defective. I've measured...
              03-15-2022, 12:32 PM
