Killed a Supermicro... Award or shame?
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    I had a supermicro die on me on friday... but I was out of town until today and I was able to confirm the failure.
    Board: Supermicro PDSGE
    Cause of death: Possible overheat due to 775 peg failure
    What happened was my mom was playing sands of time on it (it was my parent's rig) and it gave the overheat beep alarm... she let it sit that way for 15 minutes before telling me because she thought it was a "paper jam" on the printer!
    Somehow the computer was still running, albeit "a tad slow"... thermal throttling extreme!
    I immediately cut power and long behold two 775 pegs had come loose some how. everything was blazing hot... let it cool for 15 while I packed my bqags for the weekend... come back, reconnect cooler, no POST.
    When I got back today, I tried using my spare P4 775 CPU and messing with the RAM... no dice.
    This board was a repair job to begin with; it had 775 socket damage which I somehow repaired (hence why topcat sent it as a freebie)... there was a white spot on one of the lga pads and I adjusted a few of the rebent pins... but that didn't help either.
    I don't get it... it was running up until I did a hard power down...
    And in case you're wondering... I moved the PSU, GPU, and HDD over to the remains of my HTPC on steroids project and gave them that to use. Being a desktop flat case, the HS is horizontal and less likely to come loose The real reason is it's the best I had in the spare pile minus Main rig V2 (currently in use) and Given how bad the dust bunnies were with it being a fiberboard plank away from berber carpet, I figured it would be a good fit. Plus they get a QAM tuner out of the deal (I'll probably pull that since I doubt they care to use it).
    Yes, a sad day over RD's world...
    sigpic
    (Insert witty quote here)
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16956
    Re: Killed a Supermicro... Award or shame?
    a moment of silence for the fallen Supermicro. if its any consolation, that board was given to me by the same company that gave me the brand new in box SM board in frankenmama.....the X7DWA-N dual LGA771 board.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      I always wondered how you got that board...
      *plays taps*
      sigpic
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        i would expect the cpu to buy the farm but not the board.
        i would even expect the cpu to thermal throttle till the end and just power off.
        had a very overclocked pentium d do that when the fan quit.one of the guys at the shop kept restarting it trying to get something completed.its still running!a 2.66 running around 4ghz.sick waste of power but a friend just had to have it as a trophy.
        • cheapie
          null
          • Jul 2010
          • 849
          Now, "kids", this is what that "Thermal Shutdown" setting is for.
          • ChaosLegionnaire
            HC Overclocker
            • Jul 2012
            • 3264
            • Singapore
            hmm, i think the crux of the investigation is to find out how the cooler's push pin pegs came out. hopefully, when they popped out, they didnt damage the board.
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              I tried a 3rd, known working CPU... no dice. Fan spinner. Probably the LGA socket went, given that in a way it was working on borrowed time.
              The pins came loose because moron here didn't install them right (twist and push, not push to click) I've since quit doing that...
              sigpic
                master hoarder
                • May 2008
                • 12170
                If you can test the motherboard out of the case, assemble everything out of the case (well, just the basic hardware actually) and if you have a heatgun or a hair drier, heat the area under the CPU sockets well before turning the board on. Maybe the LGA BGA got cracked from the extreme heat.
                • tmiha71
                  • Apr 2010
                  • 130
                  I wonder if it will post, if you REMOVE one (or two) caps from CPU vrm-out (when looking from CPU socket to LPT), from right-group of caps near CPU ?
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    I doubt that's it... all the VRM caps were poly or Sanyo... Maybe, but since I don't have an ESR meter, I can't.
                    sigpic
                    • Topcat
                      Topcat's Supermicro X10DAI Build - Plus NVMe BIOS Mod Inside
                      by Topcat
                      Yes, I know I don't post this stuff much anymore....the only reason I'm posting this one is because of a NVMe adapter incompatibility; seems rather planned by Supermicro.....or I'm atleast a bit suspicious. It's plenty new enough to have a UEFI bios but a short 'happy list' of NVMe controllers that will work with this board, as if by some 'miracle', all Intel....so lets start at the beginning; we'll get back to this later.
                      Of course the motherboard is as the thread title states; X10dai....but we'lre going to have some fun shoehorning this into a modern 'gamer case' that can actually...
                      09-29-2024, 03:55 PM
                    • nissimezra
                      Supermicro C9X299-PG300F bios dump
                      by nissimezra
                      Device Desktop motherboard
                      manufacture: Supermicro
                      motherboard: C9X299-PG300F
                      S/N: ZM187S026581
                      Problem: Black screen.
                      Description
                      The customer reported a message: usb device over current status detected.
                      I tried to download the bios from the manufacture, It has a bin file but didn't work. I'm not sure if the bin file design to be programmed directly to the chip or maybe I need to extract the body
                      I programmed this bin file but didn't work.
                      https://www.supermicro.com/en/suppor...99-PG300F/BIOS...
                      02-09-2024, 08:57 AM
                    • WatchItFool
                      M12SWA-TF threadRipper pro SuperMicro schematic
                      by WatchItFool
                      M12SWA-TF AMD threadRipper pro MOBO by SuperMicro
                      does superMicro ever have files?
                      looking for the schematic, component list, and maybe a boardview
                      08-04-2023, 01:06 AM
                    • shlomim412
                      Supermicro Server Power Distributor board
                      by shlomim412
                      Hello everyone
                      working on a supermicro server PDB
                      i attach a photo of how it looks
                      it suddenly died and the symptom is when pressing power on it sends a brief dc voltage and imediatly shuts down.
                      fan spins briefly and stops.
                      the power supply connected to it is working tested for sure (tested on another good pdb)
                      cannot find a short anywhere on the board, capacitors visually seem to be ok.
                      standby voltage is present (5v) also vdd to the power ic chip is present (also 5v).
                      any help would be apreciatted!
                      thanks...
                      02-27-2025, 04:01 PM
                    • pc_okay
                      Overheat +3VA_DSW / +5VSUS [System Power] ON GL504GS 2.1
                      by pc_okay
                      I have a messed up motherboard asus GL504GS 2.1.
                      Someone break pin of fan connector and 12V pin touch FAN1_PWM pin, and of course turn off pc..
                      Now pins are repaired but, still, the 3v/5v chip overheat, and FAN1_PWM is 12 ohm to ground.
                      FAN1_PWM is directly connected to IT8225VG-128.... There is just a condo on the way and it's okay.
                      So my deduction is IT8225VG-128 is dead and pull to much voltage from 3V linear of 3v/5v chip. (i already change 3v/5v chip for fun, and same problem of course...)
                      Can you confirm my guess?...
                      07-25-2024, 08:08 AM
