I'm building a new system based on the Asus Rampage IV Extreme. I've got it water cooled so no air blowing on the ram directly. I've got 64 Gb of G.Skill installed with heat spreaders. The case has 1 120MM fan blowing in and two sucking out. 3 80 MM blowing in and two sucking air out. The power supply pulls in outside air and blows it out the back so no help there. The memory came with two fan kits to blow air down on the ram but I can't use them because the video card is two close to the side of the ram.
The question is with no overclocking of ram will this be enough? If and when I overclock would it help to get this on each ram stick http://www.newegg.com/Product/Produc...82E16835233033 . Or does someone know of a fan kit that attaches to the side of the ram modules.
