Video cable wire gauge
  • Logistics
    • Apr 2007
    • 721
    I've noticed that the majority of the time the wire gauge is not shown on vga cables. Is there a way to determine this by the other writing on the cable? I noticed they all tend to say 2919 on them, but I found one that said 2990 and tried it. Works fine. I did find a single cable that said 28-gauge, but it looked chesp so I decided against it.
    Just looking for cables with healthy gauge.
  • mariushm
    • May 2011
    • 3799
    Re: Video cable wire gauge
    That's the least of your problems when you look at vga cables.
    The better vga cables have ferrite rings at both ends, have signal and ground wire pairs shielded from each other, there's shielding over the whole cable to reduce interferences...
    The gauge of the wire doesn't matter much if the shielding is only the pvc around the copper wire.
    Also don't rely on what's written on the cable for stuff made in China. Like the cheaper network and audio cables available these days, vga cables are made with CCA (copper clad aluminum) instead of only copper so a thinner vga cable may actually be better than a thicker but cheaper cable.
    • Elysarian
      • Mar 2013
      • 200
      I've had cheapo (ebay/chinese) cables that won't go above 800x600 and others that just plain don't work...
      Gauge-wise I've seen 26AWG on 6-foot (2 metre) cables in the past - thicker on longer cables is better to reduce the voltage drop over the length but you will sacrifice flexibility.
      The main reason the gauge isn't printed on the outer is generally because there are other signal wires in there that may be thicker or thinner depending on purpose (technically only need a maximum of 10 conductors for component video: 2 each for red, green, blue, h-sync and v-sync)
      • emeskay
        Lenovo Yoga 710 15ISK, 80U00002US battery cable wire broken.
        by emeskay
        We have an Lenovo Yoga 710 15ISK that we use as a secondary laptop. To cut a long story short, around May 2023, while traveling, I connected the laptop into an electrical outlet that was already switched on. Something made a "pfft" sound and the laptop refused to turn on after that. After getting back home, I gave the the laptop for repair to an informal repair person. He replaced the adapter and an internal motherboard part, but after he returned it I noticed that the LCD did not look normal. Essentially, every alternate horizontal line on the screen had gone missing. The laptop was...
        08-06-2024, 07:13 AM
      • Tr0ll
        by Tr0ll
        Original T-con:
        First replacement T-con:
        10-07-2023, 07:48 PM
        HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera EliteDesk 800 i7-7700 Specification for Upgrade or Repair
        This specification for the HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our...
        09-12-2024, 02:00 PM
      • Ublala Pung
        Lenovo V15 and V17-IIL and probably others with 10th or 11th gen CPU suffer from a design flaw
        by Ublala Pung
        The Lenovo laptops V15 and V17-IIL with I5 or i7 CPU and probably many other Lenovo laptop from this time with 10th or 11th generation Intel CPU suffer from a design flaw regarding the display/camera/microphone connector on the motherboard which is badly placed and the cheapest of the cheap connectors imaginable. As the cable is too near to the display and the connector does not fix it proper in place the cable develops little defects and those over time lead to a plethora of possible quirks or failures starting from the named RAM problem or sudden switching off in special when the display is...
        04-23-2025, 04:47 PM
      • bulkchart32
        i cannot get rid of the interference in the video on this 1.1v and i have tried everything!
        by bulkchart32
        i recapped the entire foxlink psu with rubycon caps of the exact uf needed. i also purchased a delta psu to see if the different brand would change anything and it did not. i recapped the entire motherboard except for about 5 of the 22uf caps. i used rubycon on everything except the five in front of the processors. i used 5 nichicon polymer caps there. i soldered a wire to each screw hole of the psu and soldered one wire to the metal outer shell and one to a screw hole on the motherboard(to make sure it was all grounded well). i also recently tried disconnecting the power cables from the dvd drive...
        06-19-2025, 02:37 AM
