One of those laptop threads
  • stevo1210
    • Oct 2006
    • 4156
    Re: One of those laptop threads
    Are Sandisk and Kingston SSD drives of good quality? They seem resonably priced. $89 for 120GB!
    On another note, upon closer inspection of my L500, it seems like someone has spilt some form of beverage into it... maybe coffee. The smell and nicotine residues indicate a smoker as well. Keyboard has definitely copped it. Motherboard looks very clean, no stickiness and I can only see the usual dust bunnies and light nicotine staining. I haven't checked the back bit of the board closest to the LCD yet though. Now... what should I do here?
    More like, what should I wash the bottom half of my laptop with? Isopropyl alcohol and water or car washing detergent and water? Just looking for a light cleaner which won't attack my motherboard and keyboard. Yes, I will be drying it out for a few days. I am aware TC uses mean green to clean his boards... but we don't have "mean green" here in OZ.
    Don't find love, let love find you. That's why its called falling in love, because you don't force yourself to fall, you just fall. - Anonymous
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      I'd say yes, go for kingston. Sandisk is OK (I've had less than stellar luck with their flash drives in the last 5 years).
      sigpic
      (Insert witty quote here)
      • c_hegge
        • Sep 2009
        • 5219
        Kingston are probably OK. I normally recommend Samsung or Intel, but we have sold a couple of Kingston SSDs at work and they've been fine. Once you get an SSD in one PC, you'll want one in all your PCs.
        As far as cleaning it is concerned, I usually just wipe laptops down with a cloth and some window cleaner. That gets most of the dirt off. Sometimes, Isopropyl may be required, but it can take paint off. It's fine to use on motherboards, though.
        • ttt9090
          • Apr 2013
          • 16
          • canada
          Hey Stevo,
          I refurb & repair computers for a living.
          Mostly laptops & tablets these days.
          I can't tell you how many laptops I receive from folks who just want to ditch them for parts, because they've had a hdd crash & went out & bought a new one.
          Just a guess, but I'd say that around 50% of the time, tere isn't anything wrong that a bios update, format & re-install doesn't cure.
          Then maybe another 25% of them are cured by re-seating and or replacing one or more Ram chips, blowing out fans with compressed air, etc.
          Out of the remaining ones, maybe 15% have a de-soldered or cold joint on the graphics chip. and finally about 10% have an actual (beyond repair) faulty hard drive.
          If I suspect a faulty hdd, I pull it out & shake it. If it has a rattle, I throw it in the parts bin. If it doesn't I attach it to one of my external hdd carriers (which I leav out of the case all the time to ease attaching various drives), and plug it into a USB port on another machine & boot up G-Parted.
          I attempt a wipe & format (don't forget to set boot flag).
          If that doesn't work, I try hddllf & select low level format but only choose a quick wipe, (full llf takes forever).
          AFter this I do a re-partition using mini partition tool, then attach to windows box & test.
          This is only my experience & I know you'll get lots of people telling you these are not good methods.... each to his own.
          My business is in an area of many small towns scattered over aprx. 200 mile area and I can't afford to have customers have bad experiences.
          I have zero complaints on such issues that have ever been a result of hardware that I have refurbed.
          Take it for whatever it's worth, as I said, just my personal experience.
          Good luck with your machine and if you need any help feel free to PM me.
          I'm happy to try to share as I get good help from others here.
          • brispuss
            Ryobi 36V (aka 40V) 6Ah Faulty Battery Pack
            by brispuss
            Purchased a Ryobi 36V 6Ah battery pack maybe just over a year ago.
            Battery pack had been used on about 3 or 4 occasions for powering a cordless lawnmower. I was wanting to use this battery pack again recently, but on checking the battery charge state via the battery pack test button, there was no LED indication at all of charge state which suggested the pack was fully discharged.
            I found this to be odd as I usually fully recharge battery packs shortly after use. So either the pack developed some sort of fault which completely discharged the pack cells (after recharging),...
            12-28-2022, 02:58 AM
            Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook Specification for Upgrade or Repair
            This specification for the Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum boardview and Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from...
            09-06-2024, 09:30 PM
            Microsoft Surface Laptop Surface Laptop 2 Notebook 2 Specification for Upgrade or Repair
            This specification for the Microsoft Surface Laptop Surface Laptop 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 2 boardview and Surface Laptop 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
            09-06-2024, 08:47 AM
          • RdeveLabs
            MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
            by RdeveLabs
            To all the members here...
            Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
            So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
            05-05-2025, 04:59 AM
            Microsoft Surface Laptop Surface Laptop 4 Notebook 4 Specification for Upgrade or Repair
            This specification for the Microsoft Surface Laptop Surface Laptop 4 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 4 boardview and Surface Laptop 4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
            09-07-2024, 06:11 AM
