black screen upon turn on pc with monitor off?
  • ivtec
    • Dec 2008
    • 1967
    Hi guys can someone please tell me why when i turn on PC i have to have the Monitor on other wise the monitor stays black displays 680x400 resolution,i have to turn off and on in the push buttom, when i have the pc configured for 1920x1080 in linuxmint mater 14? any input i'd apreciate
  • ivtec
    • Dec 2008
    • 1967
    Re: black screen upon turn on pc with monitor off?
    Hi guys no aknowledge of my problem?no help at all!
    • Mad_Professor
      A Mech Warrior
      • Feb 2011
      • 1587
      Didn't stick out in bold as a new thread.
      Well if you leave the monitor off during the boot up into windows or linux, the O/S will assume there is no display attached because it probe for EDID and didn't get a response. Newer monitors have EDID on the standby voltage to fix this issue.
      http://en.wikipedia.org/wiki/Extende...ification_data
      • ivtec
        • Dec 2008
        • 1967
        Thanks for your explanation,my display monitor is a Cob Hd 15" TV with VGA and HDMI i have it connected to VGA and the 36''Sony with DVI.
        i guess there is no EDID for this cheap display,
        well i have to remember to turn on the monitor prior to the pc or in case i forget just reboot it. thanks anyway.
        • ivtec
          • Dec 2008
          • 1967
          Hi guys i also found this article about EDID,
          http://www.extron.com/company/article.aspx?id=uedid
          • Time2Retire
            • Aug 2012
            • 256
            What type of video card do you have? I have a nVidia card on Linux Mint, and the nvidia-settings program will give me an EDID. It will output it in either ASCII or binay, but I haven't figured out what to do with it after I get it.
            There also is a Linux program that will fetch your EDID, and output some settings that you would insert into your xorg.conf file. When I ran it on mine, it gave me an error:
            http://maxolasersquad.blogspot.com/2...formation.html
            You may first need to create an xorg.conf file. To do that you first need to shut down X:
            Code:
            sudo service mdm stop
            This will shut down the X server. If you don't get a login prompt, switch to a different terminal with this key combo:
            Ctrl+Alt+F1
            You can use F1 thru F8. Then login and create a xorg.conf file with this command:
            Code:
            sudo Xorg -configure
            This will create a file in your home directory named xorg.conf.new. Start the Xserver again or just reboot. Then you can open your new file and add the info that get-edid gave you. You will need root privileges, so open it like this (from a terminal):
            Code:
            gksu gedit ~/xorg.conf.new
            After adding the new info, save and close it. Then copy it to the correct folder with this command:
            Code:
            sudo cp ~/xorg.conf.new /etc/X11/xorg.conf
            Restart the Xserver again or reboot. If the desktop doesn't start, then it rejected your changes. You will have to deactivate your newly-created xorg.conf file. Do this from a terminal by renaming it:
            Code:
            sudo mv /etc/X11/xorg.conf /etc/X11/xorg.conf.bak
            Then restart X again:
            Code:
            sudo service mdm start
            More info on get-edid:
            http://manpages.ubuntu.com/manpages/...get-edid.1.htm
            • andrestecno
              ASUS X201e - The screen does not turn on and remains black
              by andrestecno
              I'm dealing with an intermittent problem and can't find a solution. Sometimes my notebook starts up and everything works fine. However, after I turn it off and try to turn it on again, the motherboard starts, but the screen stays black. It seems like the notebook freezes and a green LED with a light bulb icon stays on.
              If anyone has the service manual or any suggestions on how to fix this issue, I would greatly appreciate it.
              Thanks in advance!
              07-18-2024, 07:14 PM
            • howardc64
              by howardc64
              Problem
              08-04-2024, 10:36 PM
            • DaniK
              Acer Aspire E5-574-52RH - black screen
              by DaniK
              I have this strange behaviour with Acer Aspire E5-574-52RH, i5 6200U, intel graphics, DA0ZRWMB6G0 Rev G, model ZRW.
              Laptop came in for a SSD upgrade, took everything apart to install the SSD.
              Everything started after modifying BIOS settings to boot UEFI instead of Legacy.
              Laptop works fine, i installed windows 10 and drivers/updates, everything works ok(when it works)
              The black screen problem is random, maybe 5 out 10 times, laptop remains with the black screen, no image
              Symptoms are:
              - random black screen after displaying Acer logo...
              02-21-2024, 06:27 AM
            • invert
              Lenovo Legion 5 15ACH6 - turn on but black screen
              by invert
              I want to fix a Lenovo Legion 5 15ACH6 laptop, the laptop turns on but the screen is black, GPU and CPU are cold.
              Bios changed a few times, unfortunately it didn't help but it should have. Please help.
              The hardware is AMD Ryzen 5​
              03-05-2025, 05:31 AM
            • Swedishpower
              Dell G3 15 3500 black screen
              by Swedishpower
              Hello
              I have search everywhere for a solution for my problem, but cant find it anywhere.
              When I was away to trow some garbage i always look in the electronic bin.
              and this time i find a laptop.
              Dell G3 15 3500, when I get home i look at the battery, add one harddrive, plug in the powercord.
              the lamp for charmig is white.
              Tryed to start it, the screen blink for a second, the keyboard lightsup, the fans and HD starts.
              but no Dell logo.
              I tryed with a hdmi cable to another screen, still black.
              I started to search solution and tryed...
              07-06-2025, 06:18 AM
