Hi guys can someone please tell me why when i turn on PC i have to have the Monitor on other wise the monitor stays black displays 680x400 resolution,i have to turn off and on in the push buttom, when i have the pc configured for 1920x1080 in linuxmint mater 14? any input i'd apreciate
black screen upon turn on pc with monitor off?
Re: black screen upon turn on pc with monitor off?
Hi guys can someone please tell me why when i turn on PC i have to have the Monitor on other wise the monitor stays black displays 680x400 resolution,i have to turn off and on in the push buttom, when i have the pc configured for 1920x1080 in linuxmint mater 14? any input i'd apreciate -
Didn't stick out in bold as a new thread.
Well if you leave the monitor off during the boot up into windows or linux, the O/S will assume there is no display attached because it probe for EDID and didn't get a response. Newer monitors have EDID on the standby voltage to fix this issue.
http://en.wikipedia.org/wiki/Extende...ification_dataLast edited by Mad_Professor; 04-09-2013, 05:19 PM.Comment
i guess there is no EDID for this cheap display,
well i have to remember to turn on the monitor prior to the pc or in case i forget just reboot it. thanks anyway.Comment
Thanks for your explanation,my display monitor is a Cob Hd 15" TV with VGA and HDMI i have it connected to VGA and the 36''Sony with DVI.
http://www.extron.com/company/article.aspx?id=uedidComment
What type of video card do you have? I have a nVidia card on Linux Mint, and the nvidia-settings program will give me an EDID. It will output it in either ASCII or binay, but I haven't figured out what to do with it after I get it.
There also is a Linux program that will fetch your EDID, and output some settings that you would insert into your xorg.conf file. When I ran it on mine, it gave me an error:
http://maxolasersquad.blogspot.com/2...formation.html
You may first need to create an xorg.conf file. To do that you first need to shut down X:
Code:sudo service mdm stop
Ctrl+Alt+F1
You can use F1 thru F8. Then login and create a xorg.conf file with this command:
Code:sudo Xorg -configure
Code:gksu gedit ~/xorg.conf.new
Code:sudo cp ~/xorg.conf.new /etc/X11/xorg.conf
Code:sudo mv /etc/X11/xorg.conf /etc/X11/xorg.conf.bak
Code:sudo service mdm start
http://manpages.ubuntu.com/manpages/...get-edid.1.htmLast edited by Time2Retire; 04-10-2013, 06:04 PM.Comment
by andrestecnoHi everyone,
I'm dealing with an intermittent problem and can't find a solution. Sometimes my notebook starts up and everything works fine. However, after I turn it off and try to turn it on again, the motherboard starts, but the screen stays black. It seems like the notebook freezes and a green LED with a light bulb icon stays on.
If anyone has the service manual or any suggestions on how to fix this issue, I would greatly appreciate it.
Thanks in advance!
by howardc64Problem
This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached....-
by DaniKHi everyone,
I have this strange behaviour with Acer Aspire E5-574-52RH, i5 6200U, intel graphics, DA0ZRWMB6G0 Rev G, model ZRW.
Laptop came in for a SSD upgrade, took everything apart to install the SSD.
Everything started after modifying BIOS settings to boot UEFI instead of Legacy.
Laptop works fine, i installed windows 10 and drivers/updates, everything works ok(when it works)
The black screen problem is random, maybe 5 out 10 times, laptop remains with the black screen, no image
Symptoms are:
- random black screen after displaying Acer logo... -
by invertI want to fix a Lenovo Legion 5 15ACH6 laptop, the laptop turns on but the screen is black, GPU and CPU are cold.
Bios changed a few times, unfortunately it didn't help but it should have. Please help.
The hardware is AMD Ryzen 5 -
by Adam RussWeird issue with this tv. Was streaming to the from a computer when it stopped working and the screen went black. Ever since then there has been. o image. Just a black screen. The audio works and yhe backlights do come on when it's powered on, it's just a black image. It presented like a backlight issue. So I finally got around to getting new backlights and a backlight tester. All of them test the same as the good backlights with the same voltages. There are no blinking lights. Just the white led at startup and when buttons on the remote are pressed signaling it's receiving from the remote....
- Loading...
