Tyan S2927 Bios Update
  • 370forlife
    Large Marge
    • Aug 2008
    • 3112
    Wow, haven't posted in here in a while!
    Anyways, I recently bought a Tyan S2927 and a pair of Opteron 2419's to go with it. When I put it together, the board wouldn't post or do anything. I sent it back to the seller who tested it again and lo and behold, it worked. So checked what version Bios it currently had (V2.02 I believe) and looked on Tyan's website for the newest. Sure enough, the newest is V2.05 that adds support for Istanbul Opterons. So after buying a cheap 2214 HE to get it running, I am now attempting to flash the bios with the latest update.
    This is where the problems are beginning. Tyan decided the S2927 does not need to be compatable with their bios flashing utility, and instead instruct you to create a windows 98 boot disk (like we all have one of those sitting around,) and flash the bios that way. Hmm, I don't even have a floppy drive... The board does not seem to support booting from USB either.
    Anyone have any idea how I can do this without having to buy a floppy drive?
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    Re: Tyan S2927 Bios Update
    Is there a way you could put those boot files on a regular CD? Cause I know I have an old Windows 98 disc that will boot without needing a floppy disk. That is pretty lame though
    • rhomanski
      nowhere man
      • 5157
      • U S of A
      I went to a local shop last year and they were kind enough to give me a floppy drive for free. Seems they have plenty laying around.
      sigpicThe Sky Is Falling
      • goontron
        5000!
        • Dec 2011
        • 4108
        • US
        hirens boot disk?
        15.2 has usb and fat32 support.
        Follow the white rabbit.
        • 370forlife
          Large Marge
          • Aug 2008
          • 3112
          Does hiren's allow you to run MS-DOS programs from USB? The bios Tyan gives you comes with a batch file, the DOS flashing program and the BIOS file.
          • 370forlife
            Large Marge
            • Aug 2008
            • 3112
            Finally got it figured out.
            I downloaded the Bootable BIOS Flashing CD from Bootdisk (http://bootdisk.com/popfiles.htm for anyone interested,) added the contents of the BIOS download from Tyan to the .iso using UltraISO, and burned it.
            Booted up, received an A:\ prompt, changed it to R:\ and simply ran the flash.bat and it took it from there. Restarted, everything still worked, shut down, installed the 2 Opteron 2419's and it booted up no problem.
            • mikeybass
              by mikeybass
              04-23-2025, 04:30 PM
            • akwky
              by akwky
              Hi!
              04-14-2025, 01:56 PM
            • al3m0di
              Update bios EFCN58WW to EFCN59WW
              by al3m0di
              Update bios EFCN58WW to EFCN59WW for solving The Connected AC adapter has a lower wattage than the recommended AC adapter
              I have a Lenovo Legion 5 15imh05a device that I bought used online. It came with a 20V 8.5A 170W charger.
              The BIOS version is EFCN58WW.
              When I turn on the device, it displays the message:
              "The Connected AC adapter has a lower wattage than the recommended AC adapter..."
              The device rarely charges the battery, and even when it does, it doesn't show that it's charging.
              I've tried
              07-29-2024, 10:32 AM
            • trix11
              Dell Precision T1650 MT Workstation bricked after BIOS update
              by trix11
              I have a Dell Precision T1650 MT workstation (of the following spec.) that was bricked yesterday when attempting to update the BIOS from A27 to A28 per:
              - https://www.dell.com/support/home/en...-t1650/drivers > Dell Precision T1650 System BIOS
              - Dell Precision T1650 mid tower Workstation
              - Xeon E3-1225 V2
              - 32Gb PC3-12800E RAM
              - 4Tb SATA HDD
              - motherboard: Dell part: 0C3YXR CN-0C3YXR-72200-39C-01GR-A02
              I see now that others have experienced like issues e.g.:
              - https://www.dell.com/community/Prec...
              10-24-2022, 10:35 PM
            • Julian Bailey
              BIOS update wont complete - Dell Latitude 7420
              by Julian Bailey
              Hi all
              Anyone come across this issue where a BIOS flash will only part complete?
              It will update the system BIOS and Primary EC BIOS fine but fails to update the Intel TBT Retimer, Intel TBT Retimer 2 and ME Firmware.
              NVMe m.2 drive isnt detected in the BIOS, but you can get into the BIOS fine and it all works in there as intended.
              The drive works fine in another laptop.
              Link to a video I made of what its doing here:
              Any ideas on how to overcome this?
              Cheers...
              06-02-2025, 01:39 PM
