Windows XP computer no connection???
  • selldoor
    Slow Learner
    • 7870
    Re: Windows XP computer no connection???
    Ok your using a cable connection and the port on the pc seems to be ok.
    Check the cable hasnt been nipped or badly kinked have you another cable?
    Did you run IPconfig
    and msconfig
    Just read the second bit
    So what are you working on now?
    • Mojo515
      • Mar 2013
      • 35
      and msconfig
      the cable seems fine, i tried another one but i still get 'the following action could not be completed: Renewing your IP address'
      im currently using my laptop, my mother uses the desktop which is an older model,
      i did msconfig n made sure DCOM n DHCP were running, my internet provider said apparently its my computer, i dont believe that, the modem should grant direct internet to my laptop when i plug in the cable, this is tiring
      • selldoor
        Slow Learner
        • 7870
        can you do run cmd ipconfig and post a pic of the result
        • Mojo515
          • Mar 2013
          • 35
          • selldoor
            Slow Learner
            • 7870
            what make/model is the modem.
            In Your web bar what happens if you type home
            or 169.254.0.1
            EDIT
            Further idea as you did before to get the ip config but
            type in ipconfig /release
            Then after it has put info on screen type
            ipconfig /renew
            And note what it says
            • joshnz
              • Feb 2011
              • 969
              • New Zealand
              #26
              Hi what is the model of the modem/router?
              Also 169.254.0.1 is assigned by windows.
              Once I have the make and model of router/modem I will be able too look-up it's ip and we can go from there to do some testing.
              My pc
              CPU : AMD PHENOM II x4 @ 3.5Ghz
              MB : ASUS M4A89TD PRO USB3
              RAM : Kingston ValueRAM 16gb DDR3
              PSU : Cooler Master 850W Silent Pro
              GPU : ATI Radeon HD 6850
              • Mojo515
                • Mar 2013
                • 35
                or 169.254.0.1
                EDIT
                ipconfig /renew
                the model is 'ARRIS'
                since there's no internet typing in 169.254.0.1 it says 'Unable to connect'
                i did ipconfig /release then i did ipconfig /renew and it said -
                "Windows IP Configuration
                An error occurred while renewing interface Local Area Connection 5: unable to contact your DHCP server. Request has timed out."
                • joshnz
                  • Feb 2011
                  • 969
                  • New Zealand
                  #28
                  hi can you run ipconfig /all
                  and post result
                  My pc
                  • Mojo515
                    • Mar 2013
                    • 35
                    and post result
                    • Mojo515
                      • Mar 2013
                      • 35
                      i noticed the 'IP Routing Enabled' said No so i fixed that so now it says yes, but no change
                      • Mojo515
                        • Mar 2013
                        • 35
                        my internet provider said that my computer's no good that i need another one, but that never happened to me before, ive had computers where the motherboard died and i needed a new one, but never had to change a computer because of no internet connection, plus my computer had internet again when i reset the modem a bunch so i kno it cant be the computer
                        • joshnz
                          • Feb 2011
                          • 969
                          • New Zealand
                          #32
                          Ok well u have a mac address so that is ok I have had pc's forget thier mac before.
                          Is there other pc's connected to the cable modem that work if so could you run ipconfig and post what u get from ipconfig.
                          My pc
                          • Mojo515
                            • Mar 2013
                            • 35
                            nothing else hooked up
                            • joshnz
                              • Feb 2011
                              • 969
                              • New Zealand
                              #34
                              ok turn off modem and pc turn on modem once it has started turn the pc on.
                              if it connects run ipconfig and post what you get.
                              this will allow me to get settings needed to configure your pc to a static ip.
                              My pc
                              • Mojo515
                                • Mar 2013
                                • 35
                                when u unplug the grey internet cable from ur modem usually the 2 little computer icon that shows ur connected should have an 'x' over it right? i unplug the internet cable and there's still a yellow explamation on the 2 computer icon no 'x', nothing happens, i cant figure it out and neither can u guys, i give up, im calling a tech -_-
                                • joshnz
                                  • Feb 2011
                                  • 969
                                  • New Zealand
                                  #36
                                  We can figure it out hence why we are still asking questions.
                                  With the info
                                  You have given just now could be somthing wrong with windows or the network interface.
                                  The test above was to see if it would work again and if it did we could have set the pc to always use working settings and if the issue contined there is somthing wrong with modem or network cable or the pc.
                                  My pc
                                  • joshnz
                                    • Feb 2011
                                    • 969
                                    • New Zealand
                                    #37
                                    Also I had another test and that was to try another computer using the same network cable and everyting the same and if it worked fine it would mean there
                                    Is a fault with the pc.
                                    To find the fault with the pc means checking software as for the hardware the easyist solution is a pci or pcie network card depending on what slots you have.
                                    My pc
