OC'ing a Q6600
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5045
    • US
    OC'ing a Q6600
    so as some of you know the PSU on my i7 died. I've been using an Asus P5N-E SLI for some time, and wonderfully at that. With a 6750 @ 3.2, I now have started to run into performance problems with borderlands 2, taking up all my CPU
    I ebay'd a Q6600 (2nd revision). I read on a lot of forums about people bumping it up to 3ghz on stock air and default voltage. Well I can't seem to get it past 2.7ghz @ 1.4-1.5v
    Every time it actually boots to windows without bluescreening, I notice the voltage on asus monitoring software is always lower than I set it, also lower on the bios screen too.
    I have a theory...I'm running two Thermaltake TR2-430's. Both have worked fine for years. One is on all the time (shorted atx on connector) that runs my GTX 285, the other one, in the case runs the MB and CPU. Could my PSU not be giving enough juice to the chip? When I start to run prime95, the voltage starts to spike, which kind of makes me think its drawing too much power for the PSU to handle. I thought 430 would be enough, and dispite the fact one or two people here I know has had problems with the TR2, I've had nothing but luck with it, hell I've used about 6 my entire life, 2 I have, one in my mothers, one in two of my friends boxes. All of them over at least 4 years old and running fine
    My temps are not a problem, I have a good cooler. I actually broke the fan on the cooler (arctic cooling freezer pro 7). But remembered a kid who used to volunteer with us at teh shop broke the amd mount for his and he just gave it to me, sure enough, in storage I had it with a perfectly fitting fan
    thx
  • gerg
    • Nov 2010
    • 278
    Re: OC'ing a Q6600
    I would try speedfan just to be positive on your temps I would also check the event viewer if it gives you any clue as to why it is blue screening in the first place. Do you have your memory and processor unlinked in the bios if i remember you unlink them before overclock on that board otherwise you are messing with the ram also. Sorry I can't be much more help then that....
    • Uranium-235
      Comrade Glimmer
      • Aug 2007
      • 5045
      • US
      Re: OC'ing a Q6600
      oh yeah they're unlinked, always have been. if they were not I would of never been able to bring my 6750 to 3.2, I also used CPUID's Hwmonitor to confirm the temps.
      • brethin
        • Dec 2008
        • 1907
        Re: OC'ing a Q6600
        You can get 3.4 on good Air cooling if you use a good board that supports 1600fsb. Your board maxes at 1333fsb so you are limited. I have 2 Q6600's running at 3.4 just on air and one will run at 3.6 but I dont push it. Both are ASUS boards. and both use DDR2-800 memory. Both are set to unlinked but the FSB is set to 1600 and memory to 800.
        • shovenose
          Send Doge Memes
          • Aug 2010
          • 6575
          Re: OC'ing a Q6600
          Get a new computer.
          i'm a dillweed
          • ChaosLegionnaire
            HC Overclocker
            • Jul 2012
            • 3266
            • Singapore
            Re: OC'ing a Q6600
            hmm i've taken a look at the specs and pics of ur board and i believe the fault may lie with ur board's number of cpu power phases... if u look at the number of power phases it has for the cpu, it only has 3 power phases. thus i dont recommend overclocking a quad on that board due to the 3 phase power. 3 phase power may be fine for overclocking duals but i dont recommend it for quads.
            what fsb and multiplier did u use to overclock the e6750 and q6600? im guessing u are using 400x8 to get 3.2ghz on ur 6750? if the e6750 can hit a higher fsb than the q6600 then the problem is likely inadequate power delivery to the cpu from the board's 3 power phases so its not ur psu. u mentioned there's a lot of vdroop and voltage spiking going on during transient loading? quite likely its the 3 power phases being inadequate to feed the cpu at 2.8ghz+.
            however, if u havent already tried this last resort which im going to mention below, then u shud give it a shot before confirming the board is indeed inadequate to power an overclocked quad:
            lower the multiplier of the q6600 to 7. try 400x7 to get 2.8ghz first. usually, with a lower mult, a cpu will need less voltage and power to overclock but the flip side is that it stresses out the NB instead as u have to push the fsb all the way to get high clocks and the NB/RAM might not be able to take it.
            other things u can do are purchasing mosfet heatsinks and sticking them on the mosfets to keep them cool. i also saw this heatsink air deflector u can put on ur heatsink to deflect the air coming out of ur heatsink downwards to circulate air around the vrms to keep them cool.
            if u still cant get it stable after all that jazz, then u may want to get a board with at least 6 power phases if u intend to overclock the q6600 to 3ghz and beyond.
            Last edited by ChaosLegionnaire; 02-15-2013, 11:55 AM. Reason: added more details.
            • Uranium-235
              Comrade Glimmer
              • Aug 2007
              • 5045
              • US
              Re: OC'ing a Q6600
              heh, you're using actual clock speeds, not QP speeds. Ether way
              the 6750 ran @ 1610, I had its multiplier maxed, I right now am running the Quad at about 2.58 stable and 1.48v (though actual voltage is shown lower). I did replace the input VRM caps with some nice new nichicon HM's to try and help with any OC'ing later on. And unlike a lot of pictures out there, my output VRM caps are polys. But yeah, it is 3 phase.
              Actually with the 6750 I had the NB at 1.7v, 405, but it never went over 49C. This is due to an inventive cooling solution of two high speed small fans blowing directly on the heatsink (one blowing directly onto another)
              • kc8adu
                • Nov 2003
                • 8832
                • U.S.A!
                Re: OC'ing a Q6600
                you buying?if so great.
                sounds like a spoiled brat answer to me.
                back on topic a neighbor has a q6600 at 3.5 with one of those corsair h60 coolers and a .2v vcore bump.i bet there is more in there to get.it probably would do it on stock vcore but he bumped it to resolve bsod on youtube video.a flash update fixed that.
                Originally posted by shovenose
                Get a new computer.
                • Uranium-235
                  Comrade Glimmer
                  • Aug 2007
                  • 5045
                  • US
                  Re: OC'ing a Q6600
                  Get a new computer.
                  uh yeah dickweed. As I mentioned earlier. I have an I7 920 @ 4ghz (and this is C0, not D0, and that is not an easy OC)
                  But as mentioned months ago, I got 12V2 burn from the PCI-E cards and it ended up taking one of my GTX 285's with it
                  I still have to fix the connector somehow. and in the mean time I technically can afford a new PSU, but have to get inventive with the connector...and get a second 500GB drive to replace the mirrored 500 I killed. So all in all, this is the only gaming system I have right now and I want to get the best out of it I can
                  I got the chip off ebay for $58, took my 6750, put it in my media rig, and am taking the 6600 from there and selling it to a customer of mine for $30, combined with an asrock ddr3 lga775 board (meh, polymer vrm, good enough for a 65w cpu-rest smaller caps are OST, I can live with it, already posted it just fine). Her going from a 775 3.06/533 /w 1gb ddr2 4200 to 4gb 1066 ddr3 and a 6600 on winxp, I bet she will notice a difference. Including the WD blue 500 with the 16M cache over her samsung 80gb with a 2M cache from '07
                  • ChaosLegionnaire
                    HC Overclocker
                    • Jul 2012
                    • 3266
                    • Singapore
                    Re: OC'ing a Q6600
                    owww 2.58ghz @ 1.48v? thats quite a high voltage to keep stable at 2.58ghz. for most ppl, 1.4v is enuff to reach 3ghz. hope its just the board struggling to keep the voltage loadline regulated and NOT u getting a bum chip that cant oc well...
                    • swammyw
                      predator helios 300 shuts down under heavy 3d load, temps are fine
                      by swammyw
                      Hi i need help troubleshooting predator helios 300 mboard: LA-F991P
                      gtx1060 6gb
                      laptop shuts down when benchmarking UNIGINE 3d after 2 minutes
                      and temps are normal when monitoring while running, when laptop shuts down it makes bios reset process when turned back on (i have to take battery out otherwise it wont start) otherwise it seems to work fine, rtc battery shows 2.8v
                      i updated bios ,tried whitout battery ,whitout rtc battery, with another charger but it did not help with problem, anyone had similiar problem? thanks
                      12-08-2022, 06:46 PM
                    • Uranium-235
                      Comet Lake laptop insane temps and memory
                      by Uranium-235
                      I got a new MSI A10M-265. So far it's been pretty good. 15" screen, lighted keyboard. First thing I did was clean the cpu/hs off and apply AS5
                      This thing has a boost frequency up to freaking 4.9. When it does the temps max at about 97c
                      I've been using ThrottleStop to cap the multiplier to 35 (3.5ghz). It's been keeping it about 94c. Is this a little extreme? is it designed for this? I've gotten mixed results in online searches. Some say it's ok as long as it doesn't hit 100c, which mine has never hit
                      Also weird, the single 16gb 2666 stick does not work...
                      08-24-2020, 01:15 AM
                    • Uranium-235
                      HP G71 temps widly change
                      by Uranium-235
                      So got this top to work on, was for a friends friend so I decided to clean it out, it was bug bombed and a bunch of roaches were inside it. All dead, though. Not as bad as another asus ROG laptop I worked on some time ago that was just full of live ones
                      aaanyhoo I decided to upgrade the PDC T4300 to a china bought T8300 Penryn-3M
                      updated the bios ahead of time. Saw it fine. Cleaned some real full junk from the heatsink that was 100% covered with a mesh of dust, dirt, dog hair, and cockroach bodyparts
                      fan was bad, replaced that too
                      got...
                      07-03-2019, 10:56 PM
                    • Ven
                      Dell Latitude 3510 Overheating & Fan Control Issue – Need Help
                      by Ven
                      Dell Latitude 3510 (Intel Core i7-10510U) CPU Overheating
                      Issue Description:
                      1. CPU Overheating to 100°C
                        • When I start the laptop from a cold state, it takes about a minute to reach temps around 80-90-100°C, and CPU thermal throttling triggers.​
                        • When the CPU fan is running at full speed (by disconnecting PWM and TACH cables), CPU temperature stays around 50-60°C.
                        • However, when the fan is connected normally to the motherboard, it does not kick in at high temperatures.
                        • I also noticed a few times that the fan kicked in for a very short time, but it does not stay on consistently.
                        • Thermal
                      02-12-2025, 03:57 PM
                    • Jo3nokokok
                      Prochot Ext Asus m409da
                      by Jo3nokokok
                      Can someone help me.
                      I have asus m409da or x409da amd ryzen 3 3200u
                      The problem originate from bad cooling, from start its already overheating a lot booting windows causing it to reach 100°C
                      And the fan started to fail and i kinda moded the laptop with older laptop fan, its not great but get the jobs done
                      And after some time, my relative use the laptop and last time i used it it still great but idk the specific.
                      But the person that use this laptop start telling me like the battery was starting to go bad etc2 and now i exchange the...
                      07-17-2025, 12:09 AM
