Different µF | Any problem?
  • hanief
    • Jun 2006
    • 6
    I never tried before. But I just wondering what if we replace any badcaps with a bit higher uF or a bit lower uF... What will happen?
  • gonzo0815
    • Feb 2006
    • 1600
    Re: Different uF | Any problem?
    Heay thi question is answered many times here, if you are interested in that stuff look a little around and read or search.
    Any way, as i am answering i will do it last time for you
    Reducing a little bit should not necesarily be a problem, as caps ahve usually +20% tolerance. In generall you afre reducing enrgy sorrage thus the time the capacitor can deliver the current without charged, this is good for transients. And the o/p voltage will be probably noisier e.g. would have higher ripple current.
    If you do enlarge the capacitance, this should improve the mentioned capabilities of the circuit, but you should not overdo this, as it is not obvious if the particular circuit can handle this w/o problems.
    • denyu
      • Aug 2006
      • 13
      Thanks that help us who don't understand word searc
      • tvguy12012012120
        Samsung UN55NU6900F Standyby voltage is 1V higher than expected, is this a problem?
        by tvguy12012012120
        This is the zombie UN55NU6900F I wrote about in this original post.
        It originally was completely dead with no standby voltage. After some poking around, I found the solder at RM819 (see pictures) failed. I removed it from the board, it tested fine, resoldered it, and now the TV works.
        The expected standby voltage at the reference pin is specified to be 11.8V but it's reading 12.8V. Couple questions:
        1. What could cause the standby voltage to be 1V higher than expected
        2. Is this a problem
        3. Could it have led to the failure at RM819, or was that...
        02-12-2025, 11:22 AM
      • theone111
        by theone111
        3. Problem: TV shuts down
        07-22-2024, 10:36 AM
      • Zeonalbasta
        Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
        by Zeonalbasta
        i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
        The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
        09-13-2024, 01:17 PM
      • Gibon378
        Problem with stopping audio and video for no reason
        by Gibon378
        PC Specs:
        • CPU: Ryzen 5 1600
        • GPU: GTX 1080 Palit JetStream
        • MOBO: ASRock ab350 PRO4
        • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
        • PSU: XFX 650W (don't remember what model)
        • OS SSD: ADATA SP920
        • OS: Windows 10 21H2
        Problem description:
        Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
        11-19-2022, 09:41 AM
      • perzyk23
        Lenovo T580 - LCD Panel problem - error 0288
        by perzyk23
        Good morning,
        I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
        10-25-2024, 12:42 AM
