PSU died, what should I look for?
  • LDSisHere
    • May 2012
    • 727
    • U.S.A.
    Re: PSU died, what should I look for?
    See if you can lay your hands on a working old school PCI (not PCI-E) video card to try in the board. I try to keep a few of these around just for this kind of situation.
    • DerStrom8
      Techie
      • Dec 2012
      • 76
      A friend of mine suggested that the other day. I'm not sure if I can find one, but I'll keep my eyes open.
      Thanks!
      • ThePCDoctor
        Retired Tech.
        • Sep 2011
        • 59
        A point of interest.....
        I've worked on PC's that were by all indications DEAD as a rock.
        Taking out the CMOS battery for a few seconds did nothing. NOTHING!
        The solution was to remove all power from the PC, then remove the CR2032 battery for twenty minutes or more. Then install a new battery and the PC came up like nothing had ever happened to it.
        If you have a digital VOM, make sure that your CMOS battery is showing at least 3.0vdc, or it should be changed.
        Just a thought!
        Doc
        Experience is truly the best teacher.
        Backup! Backup! Backup! Ghost Rocks!
        • DerStrom8
          Techie
          • Dec 2012
          • 76
          Just a thought!
          Doc
          Good thought. I haven't removed the battery for longer than about 10 seconds, and I haven't replaced it. I did, however, test it with my DMM and it read the full 3v, so I know it's not dead. I have never seen anything like this. I'll take a video of it starting up, if it will help.
          Regards,
          Matt
          • DerStrom8
            Techie
            • Dec 2012
            • 76
            Something struck me the other day, so I thought I'd check it out.
            I've been testing my motherboard for several days now with everything hooked up--the power supply, case switches/lights, video cards/VGA cable, keyboard, etc, but haven't had any luck. But I had an idea yesterday and I quickly contacted the original owner of the computer, and asked him which video port he generally used with that machine. Sure enough, he said it--"DVI".
            I borrowed a monitor from another friend that had a DVI input, plugged it into the graphics card and switched it on. BINGO! There was life!
            Apparently the output defaults to DVI, or perhaps it was a setting from before, when there's no operating system (which he just told me the other day). I plug in a DVI device, and it works.
            I KNEW it was something really simple, but for the life of me I couldn't figure it out! And neither could anyone else I asked
            So anyway, thanks for your help guys. Sorry for putting you through all that!
            Now I just need to get my hands on my own monitor with a DVI input (strangely my DVI-VGA adapter isn't working) and I'll be golden.
            Just wanted to let you know.
            Best wishes,
            Matt
              master hoarder
              • May 2008
              • 12175
              • Bulgaria
              #26
              It probably is, but IIRC if the video card's DVI connection supports only DVI-D (digital) and not DVI-A (analog), then a DVI-to-VGA adapter won't work.
              • DerStrom8
                Techie
                • Dec 2012
                • 76
                I was wondering if that was the case. Good to know.
                I'm thinking of buying this thing: Monitor
                It has both DVI and VGA inputs, and includes the cables. For a total of $74 (including shipping) I think it's probably worth it....
                Regards,
                Matt
                  master hoarder
                  • May 2008
                  • 12175
                  • Bulgaria
                  #28
                  We have the same (or at least very very similar) ASUS monitors at work. I installed them at my old job about a year or so ago and we haven't had any problems. I don't think they cost much more to buy new, though. And the new ones do come with both DVI and VGA cables.
                  My only gripe with these is the glossy screen.
                  • mariushm
                    • May 2011
                    • 3799
                    #29
                    $74 for a second hand lcd monitor is a bit much.
                    You can get 17-19" lcd monitors in US for 20-30$, just snipe them at eBay auctions.
                    Not worth paying $74 for a 20" one when you can get 22-24" ones new with 100-120$
                    100$ 20" http://www.newegg.com/Product/Produc...82E16824009314
                    120$ 21.5" http://www.newegg.com/Product/Produc...82E16824009317
                    125" 22" http://www.newegg.com/Product/Produc...82E16824005343
                    • DerStrom8
                      Techie
                      • Dec 2012
                      • 76
                      Thanks for the info. Brand new it costs between $108 and $150. I think $74, including shipping, is probably a better deal in my current position, even for a used one.
                      What do you mean by a glossy screen? Glaring? I think it'll work for me, anyway.
                      Thanks for the review!
                      Matt
                      • DerStrom8
                        Techie
                        • Dec 2012
                        • 76
                        I've been all over ebay and that's where I found the one I linked to. It's the best for the money at this point.
                        I also checked Newegg and Tigerdirect, all of the monitors are out of my price range. I appreciate the links though.
                        Best wishes,
                        Matt
                        • mariushm
                          • May 2011
                          • 3799
                          #32
                          Step 1. Look up auctions and add monitors to wish list
                          Step 2. Wait until the last 5 minutes of the auction expiry
                          Step 3. If the price is still convenient, open the auction in new tab/page, refresh the page every half a minute or so.
                          Step 4. Put your maximum price in the last 20-30 seconds and if you're lucky you'll win it.
                          Here's some suggestions:
                          This expires in 2 days and sounds like bad capacitors or a broken cfl light:
                          http://www.ebay.com/itm/HP-w2207-Wid...item4ac0c86270
                          24" if you can stand a small scratch on screen: http://www.ebay.com/itm/Samsung-T24B...item485010da3b
                          22" cheap at the moment:
                          http://www.ebay.com/itm/DELL-E2209WF...item1e76c8c10d
                          http://www.ebay.com/itm/Samsung-Sync...item19d8860ca0
                          http://www.ebay.com/itm/Dell-S2309WB...item19d8812d2d
                          http://www.ebay.com/itm/LG-Flatron-W...item35c3d720ce
                          http://www.ebay.com/itm/AOC-2217V-22...item3a7df545d0
                          http://www.ebay.com/itm/Dell-E228WFP...item2a289bdaf5
                          http://www.ebay.com/itm/Samsung-Sync...item27cf434da3
                          http://www.ebay.com/itm/Samsung-Sync...item2c6bfbcace
                          one green pixel in lower right corner:
                          http://www.ebay.com/itm/LG-Flatron-L...item3cce7c0b34
                          and i could go on and on... just check all categories, even the "broken or not working", some are improperly placed there.
                          • DerStrom8
                            Techie
                            • Dec 2012
                            • 76
                            Thanks for that. How did I miss those in my search??
                            I've got quite a few of them on my watch list now. Especially the last one in the long list--that's really catching my eye
                            Much appreciated!
                            Matt
                            • Topcat
                              Cooler Master ATC-S + Some other CoolerMaster Case - 2-fer in 1 Thread
                              by Topcat
                              This is a Coolermaster case double-header.... The reason this one didn't get added to my 'misc build' thread is becasue the Cooler Master ATC-S aluminum case....That case is a class-act way above & beyond anything in that thread! However, we have to get through a mediocre build to get to the treasure!
                              ...but here's the two Cooler Master cases in question; both of which were drop-offs for recycling.... The one on the left, I'm not really sure what model it is. It's nothing overly special, but it is well-made. The one on the right is an ATC-S solid aluminum, best I can determine...
                              03-12-2022, 10:58 PM
                            • anikin73
                              Cooler Master 500W atx psu repair. Total cannot start at all
                              by anikin73
                              I am attempting to repair this. Circuit is quite simple, but i a quite stuck at it for a long time. so today i try to ask for new ideas. my challenge is to under stand what mistake i made. I had repaired not lesson than 50 pcs of various brands ATX psu . main pwm chip is Cm 6805 Sip 9 .
                              5VSB is fine. When I short Pson, totally nothing happen. I check , the Cm 6805 VCC pin2 did have 16v, But totally nothing happen. I changed to a good chip from another good PSU. Same thing.
                              What other pin should I check such that it will result in no start up at all ?
                              07-07-2024, 07:06 AM
                            • dariolana
                              ATX PSU Cooler Master RS-700-pcaa-e3 shutting off after 5 seconds
                              by dariolana
                              Got this from my kid with a fault on primary side. Main power supply here is AC 220V. All caps were Ok, testing with 2 series lamp of 70W each, got a bright lamp . Checked main heatsink one by one with my component tester and found one 3 leg buddy MDP18N50 that passed away. Got same replacement after a week, tested, short was gone, now I got 310V on primary.
                              Happy as a dog, added one case fan for some load and the fan of the PSU. Tested purple wire, got 5.1V, great!. Shorted green and black, fan spins and after about 5 seconds shuts down. I was able to measure doing several iterations...
                              02-26-2024, 07:47 PM
                            • stomanata
                              Problem with PSU Cooler Master MPX-5501-AMAAB
                              by stomanata
                              Happy new year.
                              This PSU use WT7527V supervisor.
                              On purple cable i have 5V, but on #4 of WT7527V i have 0.21V.
                              If i try to start PSU with short between green and black it star for a second and stop.
                              For what other to check? I now that is needed more info but i don`t know what else to share
                              01-07-2024, 11:48 AM
                            • tony359
                              Cooler Master 1200W Silent Pro Gold - Bad power switch
                              by tony359
                              The PSU in question had a bad power switch. There was not physical feedback when switching on and - if memory serves - it was always ON even when in OFF position.
                              I researched a bit and got some replacements.
                              The replacement "got stuck" at first power up - as in "it's now always on".
                              It looks like this PSU has a pretty large inrush current as my lights flicker when I turn it on with no load.
                              Probably the switches I got are bad quality but I was wondering if someone could recommend a good replacement?...
                              06-18-2023, 11:42 AM
