need help choosing music notation linuxmint base
+ More Options
Posts
  • ivtec
    • Dec 2008
    • 1967
    Hi guy.Need a Music Notation program to work with Linux mint, i found this one on the link but it seems i have to download pakages of some other linux distro can you guys shed some light and advise i like this one.thanks.
    http://www.rosegardenmusic.com/getting/
  • Time2Retire
    • Aug 2012
    • 256
    Re: need help choosing music notation linuxmint base
    Don't double post!
    • Mad_Professor
      A Mech Warrior
      • Feb 2011
      • 1587
      linux mint is essentially ubuntu with a face lift.
      According to the site it's community supported, so use the package manager in Linux mint and search for rosegarden. You might need to enable the community repo and then do a refresh of the package list and then search again.
      • Time2Retire
        • Aug 2012
        • 256
        I already explained this to him in his other post about this. That is why I scolded him for double posting.
        https://www.badcaps.net/forum/showth...250#post303250
        • ivtec
          install Linux on Windows 10 | Install Ubuntu on Windows 10 using Virtualbox ?
          by ivtec
          Has anybody installed Linux on Windows 10 using Virtualbox? and since my old PC will have support after oct 25 and won't update to 11 , i just want to use win 10 for Music notation program and use Progdvb iptv player .
          01-17-2025, 12:54 PM
        • mr.malcom
          HP 17-cd0606ng no Windows or Linux Boot, exept idle=poll Boot-Parameter
          by mr.malcom
          this is a very strange Problem:
          Notebook hang instantly on Boot. BIOS is accesable.
          Windows: instant after showing "loading circle", even Windows Boot Stick hang instant (even without installed SSD/NVME )
          Linux: instantly (if Linux Boot in leagacy Mode with log messages: Machine Check exception after 0.25 sec)
          i have tried:
          - only one RAM Stick, another working RAM, both RAM channel
          - BIOS Flash to newest Version F.50, BIOS Reset
          - Memtest86 hang instant at Test 2
          - HP UEFI Diagnostic wont find...
          02-26-2022, 05:19 AM
        • tsavpyn
          Requests to Intel Flash Programming Tool for Linux Ubuntu x86_64
          by tsavpyn
          Dear all,
          I forgot my BIOS password of my Surface Pro 3, I searched for solutions for a long time and knew that by using FPT to dump my bios to bin file and using decryptor, I can get my BIOS password.
          Now I have a problem that I am unable to dump my BIOS into bin file.
          My Surface Pro 3 currently runs on Ubuntu 22.04, with Secure Boot enabled and Boot From SSD Only.
          I searched for FPT but there is no Linux version and none of them work.
          I hereby request a copy of Intel Flash Programming Tool for Linux x64.
          I would really appreciate it if anyone...
          05-28-2024, 11:18 PM
        • h0m3w0rk
          Repairing a Music Store Professional GO! SUB 18A
          by h0m3w0rk
          I'm working on repairing a Music Store Professional GO! SUB 18A bass subwoofer, and I need some help troubleshooting an issue with the power amplifier board. The board uses an IR2153 driver and originally had two SLW20N50C MOSFETs. Unfortunately, these MOSFETs burned out. I replaced them with two TK20J60W MOSFETs; however, these also failed almost immediately.
          Here are some details:
          • SLW20N50C (original):
            • Rated for 500 V
            • Typical RDS(ON): 0.21 Ω
            • Continuous Drain Current: 20 A at 25°C (13 A at 100°C)
            • Pulsed Drain Current: 80 A
            • Avalanche
          02-27-2025, 07:42 AM
        • keepread
          SPD reading/writing under Linux and/or Windows
          by keepread
          Where can I find the mysterious 'eeprom' kernel module that some use under Linux to read/write SPD?
          I installed 'i2c-tools' and got 'decode-dimms' tool under Debian but not under Fedora, but both of them are missing the 'eeprom' module.
          Also tried the SPD.exe tool from EVGA, which correctly lists all of the DIMM slots but reads zeroes from all of them.
          Basically I need to dump SPD from some modules that were sold to me as DDR-1866 but are made of DDR-1600 chips, and they do not work. There is no access to RAM clock rate in the BIOS, so I am SOL unless I can rebin...
          01-20-2025, 08:07 AM
