How do I fixed a shorted MOSFET?
  • theOracle
    • Nov 2012
    • 163
    Dell slimline Inspiron 530s
    the original symptom was processor fan just tries to start for just a split second and then nothing except solid amber light on motherboard and power button
    the reason I think it is a shorted MOSFET is that helpful forum member c_hegge had me do a test, unplugging the 4 pin power connector near the processor, and sure enough, this allowed computer to boot, mr. hegge said this indicates a shorted MOSFET (of which I can locate about 12 or so of them on the motherboard)
    How do I fixed a shorted MOSFET? - just replace it like a cap? - how do I test it in circuit to know which MOSFET is bad? - and why would it have shorted in the first place? - due to a bad cap? - this must be a common problem of these MOSFETS, because both of our Dell slimline Inspiron 530s computers have the same exact motherboard (Foxconn G33M02 - Dell p/n RY007) and same exact problem!
    the computer has lots of those dang Chemicon KZG and Lelon caps too! (but none puffy or leaking)
    __________________
    the BIG 4
    ~~~ the top tier of low-ESR electrolytic capacitors ~~~
  • diodo49
    • Dec 2012
    • 17
    Re: How do I fixed a shorted MOSFET?
    The 4 pin power supply connector is used to provide +12 VDC to the processor voltage regulator. Posibly you may have a bad or shorted cap around the mosfet. Mosfets often most likely burn open after shorting. A bad cap not always is puffy or leaking, I have replaced hundreds of good looking caps. I use a MUL3333 cap tester.
    • theOracle
      • Nov 2012
      • 163
      I think these motherboards are gonna get tossed, a great reliable replacement is just $44 new, and there are literally 40 suspect caps on this board I would have to replace - not interested!
      __________________
      the BIG 4
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        Ok... just beware you could be replacing crap with crap. Depending on why a cap (or whatever failed, a replacement could have the same crap part and just be a ticking time bomb.
        But if time is of the essense, then I understand.
        sigpic
        (Insert witty quote here)
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          In my experience, MOSFETs remain shorted most of the time, they don't blow open afterwards. Especially a VRM 'fet which is rated for 50A in the "on" state, if not over. I'd say more likely a shorted MOSFET in the VRM than a shorted cap... Shorted capacitors are rare.
          A working TV? How boring!
          • c_hegge
            • Sep 2009
            • 5219
            +1
            The only time a MOSFET will go open after shorting is if it's being used as a high voltage switching transistor, and it blows itself in half. On a low voltage VRM, it will ALWAYS remain shorted.
            • RJARRRPCGP
              • Jul 2004
              • 6304
              The Lelon caps are probably just the tiny ones by the PCI slots.
              And back in August, 2011, a Dell Inspron 530S was brought to me with the board failing to boot in dual channel mode!
              https://www.badcaps.net/forum/showthread.php?t=16209
              Foxconn had to use Lelon for the tiny ones.
              ASRock B550 PG Velocita
              Ryzen 9 "Vermeer" 5900X
              Arc A770 16 GB
              eVGA Supernova G3 750W
              Alienware AW3423DWF OLED
              "Β‘Me encanta "Me Encanta o Enlistarlo con Hilary Farr!" -MΓ­ mismo
              • Nooy
                VGA MOSfet permanently shorted and loss of MOSfet pad
                by Nooy
                Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
                I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
                02-14-2024, 02:26 AM
                HP Slimline Slimline Desktop - 260-p025il (ENERGY STAR) Slimline i5-6400T Specification for Upgrade or Repair
                This specification for the HP Slimline Slimline Desktop - 260-p025il (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Slimline Slimline Desktop - 260-p025il (ENERGY STAR) boardview and Slimline Slimline Desktop - 260-p025il (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                09-12-2024, 03:44 PM
                HP Slimline Slimline Desktop - 290-p0003ur Slimline 290 i5-8400 Specification for Upgrade or Repair
                This specification for the HP Slimline Slimline Desktop - 290-p0003ur can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Slimline Slimline Desktop - 290-p0003ur boardview and Slimline Slimline Desktop - 290-p0003ur schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                09-12-2024, 02:15 PM
              • chestercc
                Alienware M18x Shorted CPU Mosfet
                by chestercc
                I've got an old Alienware M18x R1 which shorted out the charger whenever it was connected. Tracked down the short to two shorted caps and burned CPU power controller caused by a shorted mosfet on the CPU's graphic power supply.
                I've replaced the faulty mosfet, two shorted caps and the CPU Power controller (NCP6151S52MNR2G).
                Issue is now whilst there is no short if I attempt to power the system on the fans spin for a couple seconds there are no lights and no further action - the PCH is heating up but there is no CPU power coming out but there is an enable signal...
                07-16-2022, 06:05 AM
              • mat2k
                iMac 2017 PSU - shorted PFC mosfet
                by mat2k
                I am trying to fix an iMac 2017 PSU, initially came with a blown fuse and shorted PFC MOSFET (6R199P). After visual inspection and some measurements I replaced the FET with a P20NM60 and tested with 100w series lamp, and it lasted 1 second before going into dead short. The PFC controller chip (NCP1605BG) and its passives appear fine (passives measure OK), but I do not know if there is a simple way of testing the NCP1605 as I wouldn't like to blind-replace it.
                There was some slight blackening of the solder on the PFC controller passives so I reflowed them all with some flux. I am waiting...
                03-13-2025, 11:31 AM
