Old HDD discussion
  • Shocker
    Banned
    • Dec 2011
    • 635
    #41
    Re: Okay, SERIOUSLY?????
    27 and rising by the minute...
    ...36... (the two numbers mention seem to somehow be linked)
    • Shocker
      Banned
      • Dec 2011
      • 635
      #42
      Re: Old HDD discussion
      I attempted reformatting to see what would happen. The format process seems to be stuck at 20%. I'll swap the master/slave positions of the ST380011A and ST3120026A to see what happens.
      • Shocker
        Banned
        • Dec 2011
        • 635
        #43
        Done. Nothing seems to have changed much, except that the pending and uncorrectable counters on the ST380011A have gone up another 3.
        • Shocker
          Banned
          • Dec 2011
          • 635
          #44
          ...50...
          • Shocker
            Banned
            • Dec 2011
            • 635
            #45
            I found an option to erase the drive in HDDScan. I started it for the ST380011A and will see how it goes.
            • Shocker
              Banned
              • Dec 2011
              • 635
              #46
              It might be "healing" itself. The pending and uncorrectable counters have reset to 0 and the reallocation counter is unchanged. Although the ST340014A is dead, maybe this one will survive.
              • Shocker
                Banned
                • Dec 2011
                • 635
                #47
                Finished the wipe. In all reality, the drive seems fine. Currently formatting...
                • Shocker
                  Banned
                  • Dec 2011
                  • 635
                  #48
                  The aftermath
                  It seems fine now.
                  What's next???
                  • Shocker
                    Banned
                    • Dec 2011
                    • 635
                    #49
                    Re: The aftermath
                    It seems fine now.
                    Scratch that. The pending and uncorrectable counts are up to 90 and the reallocations have gone from 26 to 30. The runtime is 39,473 hours. Looks like this one has had it.
                    At least the ST3120026A is still hanging in there.
                    • rukmani
                      • Mar 2013
                      • india
                      #50
                      thank sir.....................
                      • Shocker
                        Banned
                        • Dec 2011
                        • 635
                        #51
                        • Shocker
                          Banned
                          • Dec 2011
                          • 635
                          #52
                          As it happens, I have another ST340014A with a broken ceramic capacitor (the rest of the board seems okay). Measuring that position on the ST380011A showed it to be +3.3V. My plan in mind is to take the capacitor from the same position on the dead ST340014A. But that's for later...
                          Also, I don't know how bad this is, but I discovered that the 7200.7 PCBs originally had three small inductors which were later (after October 2003 but before February 2004) replaced by 0Ω resistors.
                          • Shocker
                            Banned
                            • Dec 2011
                            • 635
                            #53
                            Re: Up to 10,000RPM
                            ...the Raptor is louder.
                            One word: Understatement.
                            Sure the ST3120026A is not the quietest drive ever but it's far, far quieter than that Raptor is when seeking. The WD800JD-00LSA0 (which should actually be called a WD800JS as it has SATA 3Gb/s support) is quieter again and has the same access time as the ST3120026A. I can't get AAM to work on that Raptor, so any plans of using it in my main system go out the window.
                            • cheapie
                              null
                              • Jul 2010
                              • 849
                              My main hard drive is a Seagate. I can't remember the model, but:
                              *Can't remember where I got it
                              *160 GB capacity
                              *7200 RPM
                              *1 platter
                              *SATA II (3 Gbps, but only running at SATA I/1.5 Gbps because my motherboard doesn't support faster)
                              *Made in 2009.
                              *Main system drive, 30% full.
                              Seagate ST-157A-1
                              *Bought for $50 on eBay 2 years ago
                              *3(?) platters
                              *42 MB (not GB)
                              *IDE
                              *PIO Mode 0 only
                              *Stepper motor for seeking
                              *Probably from about 1990
                              *Cat landed on it while running with the cover off, still worked until it happened a second time
                              • Shocker
                                Banned
                                • Dec 2011
                                • 635
                                #55
                                I'm guessing your main drive is either an ST3160813AS (7200.11) or ST3160318AS (7200.12).
                                The ST-157A is indeed a 3-platter drive, according to the Seagate Desk Reference. There's also a 2-platter 30MB model (ST-138A).
                                • Shocker
                                  Banned
                                  • Dec 2011
                                  • 635
                                  #56
                                  What's more, a set of tests I just did in HDTune shows that if you short-stroke the ST3120026A to 37GB, it only falls short of the WD360GD-00FLA1 by about 1ms. So I can only say 3 words about that Raptor: Not worth it.
                                  • cheapie
                                    null
                                    • Jul 2010
                                    • 849
                                    Turns out it's a ST360811AS, which is a 7200.9. I'm sort of surprised that the bearings are still good, considering that it's been spinning almost 24/7 since I got it.
                                    • Shocker
                                      Banned
                                      • Dec 2011
                                      • 635
                                      #58
                                      In fluid-dynamic bearings (used by Seagate drives since the Barracuda ATA IV) there is no solid contact between bearing surfaces in-motion. As I remember, FDBs contain an oil circulated by the rotation and grooves in the bearing surfaces. The shaft entry point is not sealed - the oil contains magnetic particles and the casing is magnetised.
                                      • cheapie
                                        null
                                        • Jul 2010
                                        • 849
                                        That would explain why old hard drives are so noisy then - must be ball bearings.
                                        I'd like to know why seeking gets louder with age though. It even seems to apply to old drives too - the self-test on that one ST-251 that had never been used was quiet, and then you have more used drive that sound more like whhhhiiiirrRRRRrrreeEEEEEeeBANGBANGBANGerrrrrrrrr...
                                        • Shocker
                                          Banned
                                          • Dec 2011
                                          • 635
                                          #60
                                          Correct.
                                          Head assembly still uses ball bearings. Fluid-dynamic bearings can only sustain rotation in one direction and rely on the rotation to circulate the oil.
                                          • reformatt
                                            Intel iMacs, 3rd party SSD failures and Fusion setups
                                            by reformatt
                                            I thought I'd throw out some of my personal experiences in the last 12 months with Intel iMacs, 2.5" SATA SSD drives and Fusion drive data recoveries.
                                            As a backgrounder, Apple never fitted a 2.5" SSD's to these iMacs. Apple's SSD option was a system of 32GB NVMe blade drive (NGFF connector) and Seagate 1TB 2.5" HDD, married together in software to become a Fusion drive. Non Fusion systems have just the 1TB Seagate HDD.
                                            So, the most common reason an iMac comes across my bench is because it's either ridiculously slow, or it fails to boot at all. The most...
                                            12-18-2024, 10:34 PM
                                          • someonenotyou
                                            How to transfer information from one BIOS to another?
                                            by someonenotyou
                                            Hi.
                                            I am starting to learn about UEFI BIOS.
                                            At the moment I have Lenovo laptop with bad BIOS.
                                            I tried to clean ME region and transfer EC region from a known working BIOS, but the laptop does not POST (just fan spin).
                                            So there is something else bad.
                                            If I flash a know working BIOS, the laptop POSTs and boots into Windows.
                                            But the problem is, that the serial numbers, Windows key, and every thing else is from another laptop.
                                            Where do I start to transfer the S/N, Windows key and other information from one BIOS to another?
                                            Thank y...
                                            03-04-2025, 03:41 AM
                                          • SluggerB
                                            Tivo HD will not transfer files ....
                                            by SluggerB
                                            Not sure where to post this, thought this might be the best place
                                            Tivo setup:
                                            Tivo 1 - Tivo HD, Monthly service (ancient, over 10 years old)
                                            Tivo 2 - Tivo HD, Monthly service (ancient, over 10 years old)
                                            Tivo 3 - Tivo HD XL, eBay Tivo with Lifetime service (newer but still old)
                                            Yes I am the idiot that paid monthly for all these years. I found a broken Tivo HD XL with lifetime service on eBay for $40 (Tivo 3), I bought it, it was a bad power supply, I re-capped it, good as new. So the plan was to cancel Tivo 1 and use Tivo 3 in it's stead. So I...
                                            07-02-2022, 08:09 AM
                                          • wshadow
                                            HP Mini 800 G5 - Transfer identity & WinLic between two mainboards
                                            by wshadow
                                            I got two HP Mini 800 G5 machines, both 65W mainboards (have all 12 FETs populated on the CPU power rail).
                                            One board is always throwing errors in MemTest86, no matter which known good CPU/RAM combo installed. Board is fried. Period. Will be scrapped.
                                            The defective board contains a Win10Pro license in BIOS.
                                            The other board is working perfectly fine, but only includes a FreeDOS "license".
                                            I want to transfer the Win10Pro license from the fried board to the working one. If that includes transferring S/N etc, I'm fine with that, will...
                                            09-15-2025, 09:04 AM
                                          • Kemer
                                            Led status indicator light transfer plastic
                                            by Kemer
                                            Hello, the LED status indicators on my Lenovo Z580 are not working. Actually the motherboard LEDs are working but the light doesn''t coming to the front view. The plastic part is which you can see in photo must transfer the light to the frontview but just half of the plastic is illuminating.
                                            There are three status indicators on the front (power, battery, caps lock), and none of them are illuminated.
                                            The plastic piece doesn't appear to be broken.
                                            1. What are your suggestions for resolving this issue?
                                            2. Is the plastic piece made of special ma...
                                            08-19-2025, 07:02 PM
