i used to have a reel of it, from the days of installing tv antenna's.
now i have a 250m reel of CT100 from dish installing - now that is some good shit!! copper core, copper braid, copper foil!!!
Not really a ghetto mod per say, but it doesn't fit anywhere else...
Im using my neighborhoods cable plant/DSLAM (as in cable TV) as a very large random wire antenna. The ground is bad at the plant, and was grounding out though the metal siding of my house. I lifted the ground and now, not only am i able to hear the QAM (over the shielding!) with an SDR, but im able to pull in radio stations from Nebraska and Colorado with ease. Along with some signals from the Echostar uplink center. Not that i really need to use this to pull signals from Echostar.......
that gives me an idea, are railway tracks usually grounded, or just left alone?
(approximated max current consumption, keep some margin)
I used a 20V 4A laptop power brick for the 24V, works ok.
12V is from an ATX PSU.
12VSB is from a 1.5A adapter because I use the PSON signal to turn on the ATX power supply. Otherwise short the green wire of the ATX PSU to ground and you can tie the 12VSB to the 12V line.
The original iMac PSU has a built-in thermal sensor. The value of the sensor is not shown in software (all sensors are here on HWMonitor except this one). I couldn't figure out how it works so I use a software to control the CPU fan (or else it will go to full RPM after 30 seconds). Allows me to adjust the speed for decent cooling of the GPU as well, I want it to die as late as possible.
It appears you are using a Bestec PSU. If it's a ATX-250-12E, you won't even need a 12V adapter for the 12VSB - the 5VSB on the Bestec ATX-250-12E will naturally reach 12V after a few years of use
Good catch, it's an ATX-300-12Z though. Crap PSU but got 2 of them so one has its use now...
Bought a Geforce 8400GS, turned out to be a artefacting lemon.
Before:
It had its moments when it wouldn't artefact though. Took advantage of that, and ran 4 rounds of Furmark,one after the another, bringing the card to 86*C each time.
Surprisingly, the artefacts went away,never to come back, but just to make sure, I added a 12cm fan (which is kinda loud, but I didn't want to risk anything at this point) on the case side panel, and now everything is well, keeping the card at a cool 56*C (as opposed to over 70 without it before running Furmark).
Here's a photo after the fix. Excuse the image quality, I'm using a DIY S-Video cable and that was the sharpest quality I could get. (I use the PC to tape shows and other things using the VCR to which the PC is connected.)
I'm really going to laugh if this fix will be a long-term one, especially since I didn't pay a lot ($2.50 - 10RON) for it, and because the chip uses the G86 core.
