My motherboard is too quiet.
  • gilly1984
    • 751
    Re: My motherboard is too quiet.
    Just dismantled an old ibm crt monitor.
    Look what i found.
    The will make my little amp upgradeable.
    Aslong as i dont use smd that is.
    Do NOT touch heatsinks when testing for voltages as they may be LIVE!
    • gilly1984
      • 751
      Just put my headphones in my front mic input (pink) and re assigned it to headphones, Now its loud???
      Why is it loud through the reassigned mic (pink) but not the green headphone (green) socket?
      I am stumped.
      • glovecaps
        Asus ROG Strix Scar G533qm with a G733qm Motherboard, can I modify the Bios to accept G533 Bios
        by glovecaps
        I have a Asus ROG Strix Scar 15 (G533QM) that had a dead motherboard (Graphics card dead) and after trying to fix the motherboard with no success, I bit the bullet on a sale for a new motherboard. I ordered a motherboard for the 15 inch model which is the one that I have, and when the motherboard arrived it wasn't for a little while that I saw it was from the 17 inch model.
        My question is, can I update the Bios on this G733 motherboard to a G533 Bios.
        The reason for wanting to do this is that the keyboard isn't working as it should, and I think this...
        11-25-2024, 04:23 PM
      • Docus
        Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
        by Docus
        Hi everyone 😀,
        I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
        To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
        Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
        1. I already own the exact same model, but its plastic chassis is badly damaged.
        06-10-2025, 04:24 PM
      • Archimedes
        HP Envy 17-3290NR 3D Blank Screen - motherboard Louis V1.1 6050A2489901
        by Archimedes
        Subject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
        Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
        Fans are spinning. Blindly could install windows11 and got the device manager...
        07-30-2024, 05:14 PM
        ASUS P5GC-MX motherboard recap
        by momaka
        Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
        This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
        So here is what the motherboard looked like with its original caps:
        CPU VRM area up close…...
        01-27-2021, 11:59 PM
      • dragon3x
        After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
        by dragon3x
        Hi, I have some 32 bits computer motherboards that need repair, as they fail to
        power on.
        Here are some examples :
        (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
        switching supply area).
        (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
        than 6.3 V.)
        1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
        I replaced capacitors with aluminum-polymer.
        3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
        03-21-2025, 02:46 PM
