LG Bad Cap Help
  • killjoy0593
    • Sep 2012
    • 5
    • usa
    LG Bad Cap Help
    Okay so i self taught myself a lil about lcd tvs today and i go to fix a 37" tv i picked up. i find the bad cap, desolder it and then i couldnt find a 16v1000mf 105c cap anywhere but there is a 16v1500mf 105c cap on a motherboard i dont use anymore and was wondering if that would work just fine?
  • Koda
    • Aug 2011
    • 317
    • Macedonia
    Re: LG Bad Cap Help
    It could and probably would if its on the secondary side of the PSU, I have swapped caps on secondaries many times so far with great success. Although you should remember the rule about swapping caps with higher rated ones - never go more then 50%+ capacity and never go with smaller capacity then the original.
    Guns don't solve problems. I'll take 12
    • killjoy0593
      • Sep 2012
      • 5
      • usa
      Re: LG Bad Cap Help
      second side of the psu being furthur away from the pins that the power connector connect to?
      • MdPhoenix
        • May 2010
        • 50
        Re: LG Bad Cap Help
        I'm not a born-again expert (yet) but yes, generally farther away. You can usually look at the circuit and tell where you switch over from the high voltage to the low voltage. A rectifier is a good indication. If I'm wrong, someone please correct me. I've been out of this game for a long while, but the thread hadn't been answered and I wanted to try to help the guy out.
        • jaysonkurt
          • Sep 2012
          • 5
          • philippines
          Re: LG Bad Cap Help
          I wish it works fine. I know the trouble of doing this cause I've done it myself, unfortunately did not worked.
          Good luck.
          • killjoy0593
            • Sep 2012
            • 5
            • usa
            Re: LG Bad Cap Help
            I ordered a 1000mf 16v cap for it and soldered it to the board, it works now! got a 1800 dollar 37" tv for free basically lol
            • Koda
              • Aug 2011
              • 317
              • Macedonia
              Re: LG Bad Cap Help
              not free, you paid 0.4-0.5$ for the cap )))) Anyway congratz on the free tv, btw is it a quality low esr cap or just any cap you could find?? If it is a low quality cap, chances are you will bi replacing it within weeks/ months...
              • killjoy0593
                • Sep 2012
                • 5
                • usa
                Re: LG Bad Cap Help
                the capacitor actually costed me $1.39 with $7 in shipping and handling but because they screwed up and took so long to get it to me plus charge me $7 for s&h that wasn't supposed to be there i got a $25 coupon from them. And the capacitor is this. http://www.radioshack.com/product/in...uctId=12460839 im not sure if its has a lower esr or if its a normal cap.
                • mariushm
                  • May 2011
                  • 3799
                  Re: LG Bad Cap Help
                  Ughh... not really good. The capacitors Radioshack sells are not brand name, so you can't tell how good they are.
                  You should have asked for our advice and buy a good brand capacitor from this site or a reputable store from digikey.com or newark.com - about the same shipping fee and cheaper price.
                  What you have will obviously work for now, as your tv works, but it's quite possible it will have a small life.
                  • killjoy0593
                    • Sep 2012
                    • 5
                    • usa
                    Re: LG Bad Cap Help
                    and when it does ill just fix it again lol
                    • mariushm
                      • May 2011
                      • 3799
                      Re: LG Bad Cap Help
                      Yeah, that's an OK strategy... just flip a coin now to see if it's gonna take down other (possibly harder to find) components with it or not, when it goes bad.
                      • retiredcaps
                        • Apr 2010
                        • 9271
                        Re: LG Bad Cap Help
                        Digikey.com sells quality low ESR capacitors and their shipping prices are usually in the $2.75 USD ish range with deliverly in usually 2 to 3 days.
                        Badcaps.net also has a capacitor store.
                        --- begin sig file ---
                        --- end sig file ---
                        • quickname
                          Cyberpower 1500AVR UPS repair
                          by quickname
                          I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
                          I decided to verify that the batteries were...
                          11-12-2023, 09:57 AM
                          by Vesko356
                          08-11-2023, 03:27 AM
                        • cmlewis89
                          LG 47LB5DF blown power supply board
                          by cmlewis89
                          Hi folks,
                          I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...
                          09-03-2024, 07:50 PM
                        • omon
                          Please help find a replacement for Rubycon A0817 6.3V 1000uF 105C MBZ
                          by omon
                          I was hoping to get some help in identifying a replacement capacitor for a PET Rubycon A0817 6.3V 1000uF rated for 105C temp, MBZ series.
                          This is to replace one bad capacitor on a DELL 530 motherboard DG33M03 (manufactured by Foxconn, DELL part # FM586).
                          I'm attaching the pictures of the bad cap.
                          Thank you so much!...
                          04-28-2021, 05:43 AM
                        • withalligators
                          Looking for best replacements for Capxons, but can't find data sheets
                          by withalligators
                          Recapping the power supply board for a Samsung 305T monitor, everything is Capxon except 2 Rubycons. I can't find data sheets matching these online, so don't know what ripple numbers, impedence, etc, to look for. There are a few different looking GL series data sheet PDFs, but the listing that matches the capacitance and voltage is a much bigger case size. I've narrowed down selections with lead spacing and case diameter, and what's in stock at Digi-key
                          1 x Capxon 1000uf35v GL C720(is this a part number or batch number, can't find it anywhere) 105c
                          1 x Capxon 1000uf35v...
                          03-25-2022, 02:30 PM
